Spreader bars
Results 1 to 14 of 14
Thread: Spreader bars
    Spreader bars
    I just bought two 660 lb. lifting magnets to load steel onto my CNC Plasma table. Now all I needed was a spreader bar to use them. I checked the local Craigslist and similar sites to no avail. So I had some sch. 40- 1-1/4 pipe and some 3/8" plate laying around, a few minutes in the computer and this is what I am building. I know it is overkill for a 1/2 ton hoist but better too strong then too weak!
    Sent from my P00I using Tapatalk
    Jun 2008
    New Plymouth ID
    Re: Spreader bars
    Looks good, when it comes to spreader bars overkill is good. are you going to pin the pipe to the endcaps?
    I came real close to leaving this world when a jerryrigged spreader bar came loose. the pipe passed about an inch in front of my face and the chain rang my bell. I had a row of gooseeggs up the back of my head were every link of chain had connected. Your set up looks safe though.
    Re: Spreader bars
    Quote Originally Posted by idacal View Post
    No I am welding them. If it ever warms up here I will paint them.
    Re: Spreader bars
    If you want to shorten up the lift. Remove chains and shackle from hook and weld eye on center of your pipe.
    Will give more headroom.
    Jul 2014
    Re: Spreader bars
    I have 9 ft. of headroom and only have to lift less then 3 ft. to clear the CNC table. The hoist does not have hook it had been replaced at some point with a eyebolt, hence the shackle. I also do not trust the pipe with a center lift point, seen pipe bend before.
    Mar 2004
    Re: Spreader bars
    I think your hook shackle is upside down. The way your have it the two small shackles are being side loaded. It looks like you are good to go anyway unless you are lifting one inch plate:'))
    Re: Spreader bars
    Quote Originally Posted by lotechman View Post
    The shackle arrangement is just temporary until I can find or make a ring. It is almost impossible to find anything where I live.
    Outside of Raleigh, NC
    Re: Spreader bars
    Quote Originally Posted by gxbxc View Post
    Great link and ideas. Thanks for sharing.
    Miller Trailblazer Pro 350D
    Miller Suitcase MIG
    Miller Spectrum 2050
    Lincoln 210MP
    Aug 2008
    Re: Spreader bars
    When I saw the title "Spreader Bar".......................................
    Jan 2005
    St. Johns, Michigan
    Re: Spreader bars
    Get your mind out of the gutter Samm! LOL
    Pete
    ESAB SVI300
    ESAB MIG 4 HD
    MILLER PASSPORT 180
    MILLER DYNASTY 300DX
    MILLER COOLMATE 4
    MILLER 30A
    MILLER SPECTRUM 2050
    C&K WF-3
    Re: Spreader bars
    I was thinking about the ones between the front frame rails on a deuce roadster....
    Not there
    Re: Spreader bars
    At 41 lbs/square foot one inch plate "really" isn't that heavy.I jerk around 4 x 8 sheets of 1/2 with a crappy Torin 2 ton hoist and my old self. You're good. Get to work
    Re: Spreader bars
    Well l eliminated setup I had with the three shackles connected together. After searching in my scrap piles for several days I found enough 3/8 steel and cut this out on my CNC table. I have stayed with the 3/8 shackles so I can upgrade the capacity in the future if needed. Hangs nice and straight . I am using the same top piece for both my 2 foot and 4 foot spreader bars, trying to minimise duplications.
