Dump truck hinges
Results 1 to 6 of 6
    Dump truck hinges
    I can't find it anymore. There has been discussion of dump truck hinges. Someone had a source where they bought them. I suppose I could copy the old worn out ones , but I'm moving the old body to a new truck , I'd like to freshen things up. Where can I buy them? My body, and load weigh 16000.
    Willie
    Kentucky
    Re: Dump truck hinges
    What type did it have ? My grain bed uses a shaft all the way across. Most tri axles use two short pins one on each side
    This had a fabricated hinge with 4" long pins. It is a box on the end of the truck frame, with a corresponding male half welded to the body channel frame. It is a C65 old truck, the "new" Truck is a GMC Top Kick 28000 LB GVWR
    Soldotna Alaska
    Give these guys a call and see what they have in your size for hinges
    https://goo.gl/images/je9Hg9
    trailblazer 302
    thunderbolt ac dc machine
    Hobart fluxcore
    AHP tig 200x 2015
    Thank you. That is what I'm looking for. It appears they want to sell the whole body, but perhaps they would sell parts. I'll call them.
    Dec 2016
    raleigh nc
    Google Godwin truck bodies in Dunn NC , they have complete kits available for any size body . Call and ask for the parts department , if you get the lady consider yourself lucky as you will have a pleasant experience , if you get the guy be patient. He knows his stuff but he will piss you off in the process.
