How to mix helium and argon
Results 1 to 11 of 11
    Mar 2017
    Sierra Mountains
    I'm getting into 1/4" to 3/4" aluminum and need to mix some helium with the argon. What do I need as far as gauges and flow meters? How do you combine the two gases to one welder?
    Mar 2017
    bar stool
    Re: How to mix helium and argon
    You buy an older Smith (Pre ITW) gas mixer for Argon Helium and hook it up.
    There are minimally 7,953 other ideas how to do it on the inTurdnet. NONE work like a gas mixer does.
    Feb 2012
    Sparks, NV
    Quote Originally Posted by PorkBarrel View Post
    I'm getting into 1/4" to 3/4" aluminum and need to mix some helium....
    Victor style WYE
    _____Gauntlets_____
    ____Genesis 4:22___
    Sep 2005
    Cave Creek AZ
    The Smith gas mixer is the only way to do it with any sort of accuracy. The wye method is just a guessing game, repeatability and accuracy are questionable at best. Otherwise, just buy the gas mix you need.
    "Y" method is called blending.
    Mar 2014
    Porky,
    Here's how I'm set up to get some Helium blended into my Argon to help out welding heavier aluminum. All it takes is a little bit of playing around and you'll find where you want your flow meters set. Since Helium is so expensive you want to try and use as little of it as necessary.
    Also, you don't need a wye connector with valves on it like you see in the picture. That's just what I already had on hand.
    Name:  10 16 11 004.jpg
    Sparks, NV
    If you find an argon CO2 Smith mixer, her is the conversion chart for argon helium
    Rent a cylinder that already mixed.
    Mar 2017
    Sierra Mountains
    Jody suggested getting the gas mix 50/50 that way I can utilize flow meter for both. Another one also mentioned. Thanks for all the great ideas!
    Yes. set your argon flow at your desired half, then add enough helium to flow the other half. As long as you confirm the total you should be good. Actually I go 50/50 at the flowmeters, then confirm total at the torch.
    Mar 2017
    Sierra Mountains
    Thanks. I printed and will use as reference.
