Bobcat 225nt onan p216 no spark
Results 1 to 25 of 25
    Jun 2018
    First time posting.. my bobcat shutdown in a middle of a rod 3 days ago. I tried to restart but nothing pulled plug held to side of block and no spark. Searched web for this issue ran test for Coil primary and secondary resistance checked out good ( coil was just replaced a month ago ) ran test for module behind flywheel it checked out good also. So I got 2 new plugs tried to start and I noticed after spinning the motor over a couple times smoke coming from behind flywheel cover.. pull the cover and found a wire had been rubbed by flywheel teeth and arced to flywheel. Fixed wire put all back together still no spark!!!
    Any ideas are greatly appreciated thanks in advance.
    Re: Bobcat 225nt onan p216 no spark
    Are you getting 12 volts of battery power to the coil?
    Here is a link to a no spark issue on a very similar engine P218G. http://www.mytractorforum.com/11938713-post2.html
    Here is a more extensive test procedure.
    http://www.mytractorforum.com/attach...1&d=1527019270
    L-tec PCM-VPi 40A plasma
    ESAB REBEL EMP 215ic
    ESAB Mig Master 250
    Victor Performer O/A
    Jun 2018
    2.8-3.2 volts when cranking.. so is it the stat or that’s bad?
    Idk atm. Others should come along to help. My tractor forum has a lot of knowledgeable members that should be able to help you pinpoint the problem if you can not get to the cause here.
    ESAB Mig Master 250
    Jun 2018
    Ok... thank you for replying N2 this things got me puzzled on why it lost spark the way it did. The wire that the flywheel chewed up was for the voltage regulator if that helps anyone
    Does it have spark when starter is turning it over?
    Bemidji MN
    Oil level high enough? Don't those motors have a low oil pressure shutdown sensor?
    Airco 300 - Syncro 350
    Jun 2018
    No spark when starter is turning it over yes it does have low oil pressure shutdown i do have 12 volts at low op shutdown I also tried jumping around low op sensor but not 100 percent sure on how to test low op sensor I just changed oil and filter about week before it shutdown. Thanks for the replies
    There should be a way to run a hot wire directly to the coil to see if you can get it to start. If it starts then it may be something in the 12 volt circuit that supplies the ignition coil. Safety switch or sensor etc.
    ESAB Mig Master 250
    Jun 2018
    If I hook a jumper wire around the O.P shut off sensor I got 12 volts at top of coil when switch is on run/idle and run 10.25 volts when cranking..
    Without the jumper on O.P sensor I have 0 volts at coil when switch is on run/idle or run but 10.25 volts when cranking...
    Still no spark either way
    Quote Originally Posted by Bo Johnson View Post
    Instructions state to turn flywheel "slowly by hand".
    Save Second Base!
    Jun 2018
    I did Duane to check the module behind the flywheel and I got a reading of 12 volt for 1/2 the revolution and 1.5 volt for remainder of revolution. Which I think this is correct the post I made stating I wasn’t getting 12 volts at coil was incorrect do to I was trying to hold meter and crank all by myself I got some alligator clips and fitted on my meter to get a better test result
    Jun 2018
    When I get home from work I’m going to re run the module and coil test and I’ll repost the results
    Feb 2011
    I had that issue with my 225nt a while back. Coil tested bad. Replaced and no more issues.
    Jul 2012
    What happen one time is there were some screws sitting on top of machine and one fell and landed on top of coil and ground it out. Then engine died and would not start, after some searching found the screw removed it and up and running.
    Did this ever get resolved?
    ESAB Mig Master 250
    Jun 2018
    No n2 I’ve been super busy at work!! I’ve got my buddies Hobart champion elite trying to finish the job my bobcat went down on me on I’ll run test and respond ASAP
    Soda springs,Id
    There's a little black thingy attached to the crankshaft under the flywheel with a magnet in it that triggers the ignition module. If it gets weak you wont get spark.
    Mike
    Jun 2018
    Thanks mike I think that black box is the ignition module. From my interpretation of what I’ve read the way to test that box is connect a jumper wire from the positive post of the battery directly to positive post of your coil. Then connect a meter black lead to engine ground red lead to negative side of coil. Roll the motor slowly by hand or 5/8” socket. Your meter should read battery voltage for half the revolution (12volts) then 1.5 volts for second half of revolution. Over and over again slowly looking for any changes or misses in volts.
    Jun 2018
    I got to run the module test and the actual readings I got was 12.44 VDC for 1/2 of the revolution and .88-1 VDC for rest of revolution. From my understanding this should tell me that the module on the bottom of the crank is working properly. If anyone sees I done something wrong or didn’t test properly please reply. I’ll run test on coil tomorrow evening when I get home.
    I thought it is suppose to be in a range between 1.0 to 1.5 volts ?
    ESAB Mig Master 250
    There is not a whole lot to it. Either the coil, spark plugs / wires, electronic module magnetic pick up, bad or loose wire connections or wiring, bad safety sensor or ignition switch or low battery voltage.
    ESAB Mig Master 250
    Jun 2018
    I think your right n2 about 1.0-1.5 vdc I’m getting just a touch off from that but idk if it’s enough I’ll test with another meter before I buy a module cause I’m defiantly getting the 12 vdc which should be enough to get the spark.. idk I just don’t want to waste money where it’s not needed. I also agree it’s a simple system that’s why I’m so pissed I can’t figure out why I’m not getting spark.. lol
    I think your right n2 about 1.0-1.5 vdc I’m getting just a touch off from that but idk if it’s enough I’ll test with another meter before I buy a module cause I’m defiantly getting the 12 vdc which should be enough to get the spark.. idk I just don’t want to waste money where it’s not needed. I also agree it’s a simple system that’s why I’m so pissed I can’t figure out why I’m not getting spark.. lol.
    Those do go out on occasion, especially when the engine has been run hot. This can happen from oil or dirty air cooling fins or blocked air passedges that supply fresh air to the engine. If you suspect the module to be bad replace it and all necessary parts that accompany it. Clean the engine real good and fix any oil leaks if they exist. If you have to tear into the engine to get to the module you might as well go the extra mile and make sure the engine will stay cool and healthy.
    ESAB Mig Master 250
  25. #25
    Jun 2018
    Because of the dusty condition I work in i constantly clean my fins and use proper oil for outside temp conditions but yes I agree since it’s down I need to fix a few minor things and clean before firing it back up if I can get spark again. I’d really like to switch to a Kohler eventually but now is not the time
