Gas question
Results 1 to 5 of 5
Thread: Gas question
    Gas question
    Hi guys , encountered a rookie problem today l think, was using mig welder outside for a very small job , when finished l turned the gas off but left welder running , aftera short time there was a sharp bang , and gas pipe from regulator to welder burst , its thin plastic pipe that came with welder .
    Never happened before , had unit for a few years just wondered what cause was , is it simply that welder was left on ?
    Thanks. Jim
    Bemidji MN
    Re: Gas question
    Your regulator may have failed and over pressured the tubing.
    After closing the valve, there is still a little high pressure between the valve and regulator - may have bled through.
    Airco 300 - Syncro 350
    Jun 2009
    Draper, UT
    Re: Gas question
    was the welder and hose in direct sun? maybe the hose softened in the sun and with both the solenoid and valve closed the pressure increased to the bursting point of the softened hose.
    MillerMatic 252, HTP 221 w/cooler, Hypertherm PM45
    "No matter where you go, there you are" [Buckaroo Bonsai]
    Soda springs,Id
    Re: Gas question
    Replace the plastic one with a rubber hose. After it's installed turn on the gas and then turn it off and watch the low pressure gauge. If it starts increasing the reg is bad.
    Mike
    Re: Gas question
    Many thanks guys , yes it was in sunlight, (warm here for a change ) so hose would be soft , will replace with rubber hose and check regulator.
    Many thanks. J
