Bending metal
Results 1 to 16 of 16
Thread: Bending metal
    Oct 2013
    Bending metal
    I have a tractor with two semi circles of metal that are used to attach check chains on either side. They are attached by two bolts each. The are bent and now need to be straightened in order for my new PTO guard to fit. I could try hammering them back with a sledge hammer while cold or heat them up with a torch before hammering them out. Which would be better for preserving the strength of the metal?
    Oct 2013
    Re: Bending metal
    This is a pic. I need to bend back in place the metal with the chains attached to them.
    Jan 2011
    Hutchinson Kansas
    Re: Bending metal
    Just take the chains off and hammer it back.
    Re: Bending metal
    Remove chains and you could hammer as stated above or flatten in a hydraulic press.
    Or make two new ones.
    Soda springs,Id
    Re: Bending metal
    They appear to me they'd function better and with less tendency get bent with the twist like the right one has.
    Mike
    Oct 2013
    Re: Bending metal
    They appear to me they'd function better with the twist like the right one has.
    Mike
    I thought they were designed that way until I bought a PTO guard . The guard uses the same bolts to attach, but unless the above pieces of metal are straightened, the guard won’t fit.
    Sep 2011
    USA
    Re: Bending metal
    Take them off heat and beat them
    ________________________________
    Everlast PA140ST
    Everlast PowerPlasma 50
    And no you can't Borrow them
    Kentucky
    Re: Bending metal
    There's a 50 50 chance you will throw the pto guard away before long the one thing they are really good for is skinning your knuckles when you are hooking up stuff
    Mike
    Mar 2009
    Iowa
    Re: Bending metal
    Unbolt, press flat, bolt back on. Jobs like that were always a pleasure to do.
    My name's not Jim....
    Jun 2018
    Pasco Fl.
    Re: Bending metal
    How long do you think it will be before their bent again, probably the first time you hang an implement on there. I could be wrong but I don't think thats where the chains should be connected, either that or somethings missing back there there.
    CR
    Soda springs,Id
    Re: Bending metal
    What is that called that's over the PTO shaft now?
    Mike
    Jan 2015
    Hamilton Ontario Canada
    Re: Bending metal
    Mike
    That is a dust cover it comes off when you are using the PTO. The PTO cover keeps stuff out of the U joint when it is attached.
    Welders: IdealArc AC/DC 250
    Lincoln AC 225 converted to AC/DC
    O/A torches
    Lots of Hammers Clamps and Grinders
    Tampa, Florida
    Re: Bending metal
    I agree with the others, I’d unbolt it, set it on a sturdy flat surface, and have at it with the BFH.
    Sure, a little heat never hurts, just don’t get ‘Er too hot or she might twist round the other way on ya! Cooling shrinkage and the like.
    -Mark Smith
    Vulcan ProTig200
    Century FC90
    Oct 2013
    Re: Bending metal
    These hold check chains and not stabilizer chains and they are located in the correct place. They are not seen on most newer tractors because newer tractors use stabilizer chains to act as check chains. The purpose of theses check chains is to allow the implement to freely move left and right but limit or check the movement so the lift arms don’t hit against the tires. If I pulled a plow they would be used and I might bend the metal. But I just need to have them straight to get my PTO guard installed. I was wondering if heating the metal would weaken it so they would be more likely to bend again. I was also worried about the bolt spacing if I removed it for straightening. I was thinking about leaving it on the tractor bolted in place to keep the bolt spacing and heating it so it would bend easier and cause less stress on the bolts.
    Re: Bending metal
    Remove and make another set with thicker material. Get two longer bolts then.
    Re: Bending metal
    From what I see in the picture I'd use a 16" crescent wrench and twist them back straight without even removing them.
