What requirements to run an LN-25?
Results 1 to 9 of 9
    Oct 2012
    Sacramento, California
    Will the blue star 145 on my truck push the LN-25 running 045 flux core?
    I have access to a blue star 185 also.
    Mar 2006
    Yuma, Arizona
    Re: What requirements to run an LN-25?
    Not sure what the blue star is.
    I ran my LN-25 with my Ranger 9.
    It required 1 work lead and 1 clip to the work. The clip was voltage sensing. Worked great.
    Google search looks like the Blue Star is CC not CV. You can do it with the LN-25. It has a switch to choose. It is a bit more rough on CC. I tried it.
    .045 with 140 amps kind of limits you to 1/8" mild steel.
    Lincoln Precision TIG 275,Undercart cooler,Foot/Finger Amptrollers
    Lincoln Hobby-Weld 110v
    Lincoln SP-200 MIG and Hi-Freq Tig
    Oct 2012
    I'm needing a lot more than 1/8th...
    Mar 2006
    Yuma, Arizona
    170-190 Amps will get you to 1/4"
    I am using the Miller website for these specs since you are using a Miller power source. Double check it yourself. I am a Lincoln man myself. They have a weld calculator on the Miller website.
    Oct 2012
    I'll be doing 1" diamond plate to 1/2" diamond plate..
    Or rather a 4x8 sheet of 1" diamond plate, to a loading dock floor that's 1/2", for a ramp.
    It'l take more than one pass.....
    Bemidji MN
    Quote Originally Posted by Fnord5 View Post
    In my opinion, with the small machines you have available, wire feed will put a hurt on them.
    Between the two, I'd take the 185 and stick weld them. 1/8" and/or 5/32" 7018 would work well.
    Airco 300 - Syncro 350
    Apr 2008
    NW ON Canada
    The gas drive machines you listed don't have the ummph to push .045 wire in CC mode. You won't like it.
    You need a larger machine (250-300 amp with CV) to run .045 wire all day long.
    If you only have the small blue star machines to work with, run 7018 stick with them.
    Jason
    Thermal Dynamics Cutmaster 52
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
    Ironworkers Local 720
    Mar 2006
    Yuma, Arizona
    Per Miller's website:
    Spray Arc Transfer
    1/2" and up
    (generally used for thicker metals in the flat or slightly horizontal position)
    Wire Size & Wire Feed Speed:
    .045" (1.1 mm) at 390 ipm
    Shielding Gas & Voltage Range:
    98% Argon/2% O2: 29-30 Volts
    Amperage Range:
    315
