Interesting....
Results 1 to 8 of 8
Thread: Interesting....
    Jan 2006
    In A Nice Comfy Chair
    Interesting....
    Found this this morning...
    https://www.heatshieldproducts.com/wrist-welding-pillow
    Hmmmmmmmmmmmmmm
    Look around the site...
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
    Nov 2012
    new york city
    Re: Interesting....
    that welding pillow makes me sleepy just looking at it. at work we've been using something similar to insulate steam/hot water lines. the theory is the steamfitters/plumbers can remove the insulators and replace it after work is done rather than ripping off the fiberglass and throwing it out.
    i.u.o.e. # 15
    queens, ny and sunny fla
    Mar 2014
    Re: Interesting....
    Welding pillows, auto darkening hoods, pulse, spinning stuff in a positioner.....pretty soon this welding thing is gonna be so easy that every girl scout troop in the country will be opening a welding business and putting the rest of us out of work.
    Re: Interesting....
    I wonder if they have a welding maxi-pad? Haha.
    I could see it if you have a bunch of parts you are going to do on a rotating fixture, but I usually just get a piece of metal the right height and rest on that.
    Sincerely,
    William McCormick
    Feb 2017
    Re: Interesting....
    Re: Interesting....
    You could tape your glove to the rod holder, stick the rod to the work, and then shut off the welder, fluff up your pillow after a hard night out and never get caught Haha.
    I have a higher ethic myself. I just take a nap when it gets real hot. This was a day a couple of years ago, I was working on top of switch gear, it was the hottest day in the past fifteen years or something. I believe the ceiling was 118 degrees. They keep the doors open to cool down the rooms because the fans do not always work. So after a few hours I took a nap. No reason to climb on high voltage switch gear in a sweat.
    Sincerely,
    William McCormick
    Mar 2009
    Iowa
    Re: Interesting....
    That welding pillow looks like a good way to burn the back of your head or neck. I balance on the headband adjustment knob to give a little space for sparks.
    My name's not Jim....
    Jul 2017
    Re: Interesting....
    A pillow and working in the heat aren't usually a good combo in my experience...
