How to clean polarity selector switch?
Results 1 to 23 of 23
    Can somebody give me some advice on how to clean and lubricate the polarity selector switch on my syncro 250?
    It moves really hard, I guess it isn't a good idea to use the grease I use on heavy equipment?
    Ill post a picture if I can get it to work
    Thanks!
    Im a 16 year old teaching myself to weld.
    Miller Syncrowave 250
    Esab Migmaster 250
    Miller Two Fifty Twin
    Re: How to clean polarity selector switch?
    Here's what I did on mine...I first tried WD-40, and that didn't do much. I ended up using non-chlorinated brake cleaner and a brush, until it was clean and dry. Then I used white lithium grease to re-lubricate it. Make sure you pile in some paper towels or rags to catch the solvent and the gunk that will fall from the switch, and let it thoroughly dry before re-lubricating. Some folks suggest using dielectric grease, which probably can't hurt, but I would use what you have on hand. Spray on white lithium grease worked great for me. Some folks suggest taking the welder to a car wash and hitting the insides with the spray wand. That's a bridge too far for me. I am afraid I'll brake something.
    Millermatic 252
    Syncrowave 250
    Purox Metalmaster
    Here's the advice that was given to me:
    Originally Posted by 7A749
    Yes. Open the machine up and blow it out with compressed air. You can lay some rags under the switch and hit it with carb cleaner and a small brush if it's got caked up grease on it. Be careful not to get carb cleaner on other components inside the machine. It can discolor and melt some plastics. The insulators will be ok for what little you're hitting them with it.
    I generally use white lithium in a spray can with a straw on the nozzle. You will see where the switch is a series of copper lobes with lined indentations in them, separated by plastic insulators between them. Inspect the switch for any damage, then spray some grease into the assembly. Use care moving the switch until it smooths out. If you reef on it before it's greased up, you could break the components.
    Move the switch thru all three positions and make sure you have grease on all the lobes of it. The early machines have a metal control handle, later models, a plastic one. You should have metal switches on your machines.
    Millermatic 252
    Syncrowave 250
    Purox Metalmaster
    Thanks for the quick reply, I’ll try that. What type of brush did you use, a wire brush? Carb cleaner sounds like a good idea to get the gunk off there.
    Esab Migmaster 250
    Here’s the picture of the switch:
    Plenty of grinding dust on there
    Esab Migmaster 250
    I uses a small bronze bristled brush, the kind hey sell for cleaning guns. Be careful not to breath the carb cleaner. I like the brake cleaner a bit better. Don't breath that either. And whatever solvent you use, watch where it goes. Don't let it get on the electronics at all.
    Millermatic 252
    Syncrowave 250
    Purox Metalmaster
    CRC brand "Electro-Motive cleaner" is a really good product for this type of cleaning, It's fairly friendly to most plastic components. Used to buy it in 5 gallon buckets working on LeTourneu and Wabco heavy equipment electrical components. A lot of the newer non chlorinated brake cleaners are pretty hard on plastic. I used some today to take 3 layers of paint off a semi trailer ID tag, washed it right off.
    t
    The electro motive cleaner is excellent, I've seen videos of people immersing a running electric motor into it, personally I would not use carb cleaner, also after cleaning a little dielectric grease on the contacts will help lubricate and preserve them to prevent a recurrence. You can also use tuner cleaner and lubricant, and try to get lubricant into the bushings and shaft.
    NRA LIFE MEMBER
    GOD BLESS AMERICA!
    RONALD REAGAN
    Mar 2009
    Whatever you decide to do.........just remember to unplug it 1st.
    It wasn't too friendly to the plastics in my HFT angle grinder. I sprayed some into the motor once when it was acting up, and the plastic disintegrated. But it didn't melt -- it just cracked all to pieces.
    I know CRC makes something called "QD Electronic Cleaner" spray which is much safer on plastics...personally, I'd use kerosene or MS on the Sync switch and then dielectric grease.
    So I got the contacts cleaned pretty well and greased it with Lucas red n tacky but it doesn't move much better than before. Any suggestions?
    Also why would I want to use dielectric grease for this application? From my understanding it is nonconductive which doesn't seem favourable for an electric contact switch. What am I missing here
    Esab Migmaster 250
    You put dielectric grease on car/boat battery terminals, too. It keeps air out, which keeps moisture and oxygen out, which keeps corrosion out.
    I honestly have never seen an issue with Electro-Motive, I do like the QD cleaner too, use it for electronic plugs and recepticals on heavy equipment and trucks.
    The stuff I used that caused problems was called CRC "Lectra-Motive"
    No offense but I am guessing you didn't clean it well enough. On mine I had to repeat the cleaning process several times. Also don't just focus on the contacts but also on the pivot points.
    Millermatic 252
    Syncrowave 250
    Purox Metalmaster
    also use something like Ballistol or Break-Free CLP on the pivot points to clean and lube them. Grease won't work there.
    Millermatic 252
    Syncrowave 250
    Purox Metalmaster
    The dielectric grease will help prevent arcing and oxidation, I use it on most open switches and contacts, coat my battery teriminals and inside the clamps with it, it works wonders to prevent corrosion.
    NRA LIFE MEMBER
    GOD BLESS AMERICA!
    RONALD REAGAN
    ...and if you put it onto the terminals of batteries before you load them into a flashlight, you won't have to beat the flashlight every time you want to turn it on.
    That makes sense, thanks caveman and kelvin.
    What do you mean by pivot points?
    I re cleaned everything where the copper makes contact and got some dielectric grease to put in but it still doesn’t move any better. It does switch into AC pretty easy but that is because the ac only has 3.or 4 contacts whereas the dc has 7 or so.
    Also, what breaker do you have your s-wave on? I am only running it from a 30amp and it just pops really fast.
    Thanks for all the help!
    Esab Migmaster 250
    The polarity switch is a rod with a bunch of blades sticking off of it, and a handle on one end. That rod has to have some kind of bearings or pivot points that allow you to twist it with the handle. Make sure you clean and lubricate those as well.
    I am running a 100 amp breaker with 6 gauge romex to my garage. Its a beefy, dedicated welder circuit. I never trip my breaker.
    Millermatic 252
    Syncrowave 250
    Purox Metalmaster
    Yes I did clean those.
    I hadn’t realized that you “only” need #6 wire for 100 amps.
    Esab Migmaster 250
    you should download a copy of the owners manual. https://www.millerwelds.com/support/manuals-and-parts
    Millermatic 252
    Syncrowave 250
    Purox Metalmaster
