SA-200 no aux power
Results 1 to 4 of 4
    Sep 2007
    SA-200 no aux power
    Code 8638
    Everything else runs properly just no 110v at the outlet.
    Any ideas?
    Tim
    Miller
    MM 250,251,251,252
    DeltaWeld 450 w/ WC-1
    CP-300 w/ 22A
    Re: SA-200 no aux power
    I trust you've checked the receptacle to make sure the internal contacts aren't damaged.
    As for the machine end, there is a connection in the harness that joins the black wire from the right exciter brush and brown wire to the 2 0'clock main shunt coil. This connection also joins the black wire comming from the generator harness running to one of the idler board "B" terminals. I would locate that connection and see if the black wire to the board corroded off.
    I'd also check the QD terminals at the boards' "B" terminals to make sure they're making contact. You should also check to make sure there is continuity (less than 1ohm) between the two "B" terminals.
    Save Second Base!
    Sep 2007
    It was a loose spade terminal from the receptacle to b terminal.
    Thanks for all you do Duane.
    Tim
    Miller
    MM 250,251,251,252
    CP-300 w/ 22A
    Glad to hear you found the cause and got it operating again.
    Save Second Base!
