POWER I-MIG 230I & spray transfer
Results 1 to 9 of 9
    Jul 2016
    Roatan island
    Anyone know if the Power I-MIG 230 can do spray transfer?
    I keep reading it's a function of voltage output above 25 and the specs say it can deliver 25.5 but that's a slim margin.
    Opinions on this machine are welcome.
    Feb 2015
    Re: POWER I-MIG 230I & spray transfer
    Nope, very few welders under 250 amps can spray arc (it's not a function of the amps though, it is just only that machines above 250 amps generally also are designed to output higher voltage to spray). I believe the only Everlast welder that does spray arc comfortably is the 275. Maybe the 251Si can too, just can't remember off the top of my head.
    Otherwise for a sub 250 amp machine to reliably spray arc, you're looking at a welder from a different brand.
    Jul 2016
    Roatan island
    Thanks for the confirmation. It's as I suspected.
    According to the Miller calculator yes. BUT only up to 1/4" material. Over that you run out of voltage.
    https://www.millerwelds.com/resource...ing-calculator
    Fabricator 252i
    FP120
    Cutmaster 42
    Jul 2016
    Roatan island
    tkevan:
    Just went to that Miller site and they want a 2% Oxygen mix ! ?
    Is that a misprint? I thought we were shielding the puddle from Oxygen by using only inert gasses like CO2 and Argon.
    Nov 2008
    You can use a 90/10 mix on mild steel. I personally use C 18 (82/18) on my welders and spray with it, but I don't have the 230i. The 275 units will do it fine.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Smith Oxy Fuel setup
    Everlast PowerPlasma 80
    Everlast Power iMIG 160
    Everlast Power iMIG 205
    Everlast Power iMIG 140E
    Everlast PowerARC 300
    Everlast PowerARC 140ST
    Everlast PowerTIG 255EXT
    Quote Originally Posted by RoatanBill View Post
    tkevan:
    That's a misprint. Should be 98%Argon/2% CO2. That gas with 1/4 steel puts you in the 24-25V range. Anything thicker puts you over your 25.5V.
    Fabricator 252i
    FP120
    Cutmaster 42
    Nov 2008
    Actually, the wire diameter is going to determine when something is going to spray.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    True. The calculator gives you a ballpark voltage/IPM for .035 and .045. The 230 should hit those.
    Fabricator 252i
    FP120
    Cutmaster 42
