Tig aluminum with helium blend? Better looking welds?
Results 1 to 20 of 20
    Mar 2006
    Hey, if I change from a 100% argon gas. To a mix with helium, will the weld beads look different?
    Does anyone have before and after pictures of welds with straight argon compared to blends with helium. Any links etc?
    Port Orchard, WA.
    Re: Tig aluminum with helium blend? Better looking welds?
    First picture is with 100% argon. The second picture is 100% helium. I’ve never used a blend of argon, and helium.
    Don’t pay any attention to me
    I’m just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    100%
    Hmm...
    seems easier than building a Y mix setup...
    for once in a while /small job..
    Miller 211/Spoolmate 100
    Lincoln SP125 plus
    Chicom spot welder
    Dec 2003
    Fairfield,CT
    Careful. Inverters don't like to start with 100% argon. At least for my dynasty.
    www.tjsperformance.com
    Dynasty 300 DX
    HTP 240
    Miller Bobcat 225G
    LN-25
    Bpt. Mill/DRO
    4' x 8' CNC Plasma Table
    Instagram: tjsperformance
    Port Orchard, WA.
    100%
    Hmm...
    With 100% helium, it takes about half the AMPS, as with 100% argon.
    I’ve never had that problem with my Dynasty 300.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    I likely wouldn't use it on thinner metal. The value is more heat. Dynasty 280 DX struggles with 5/8" thick material on argon. It takes a while to puddle, allowing things to get nasty, and drips flow to the back side. With 5 CFH of helium added it puddles very quickly, welds cleanly, and I can weld the other side with only a quick scrub with a stainless brush. I had trouble with the end of a weld melting the corner away adjacent to the weld. When it is a clean 90 degree edge to be ground smooth it can be hard to preserve the crisp edge without helium.
    It enhances a 280 amp welder to 350 amps equivalent.
    Willie
    100%
    Hmm...
    Helium is expensive. Too much of it is wasteful. My Y set up was a Y fitting equipped with valves, an extra hose, and regulator. My helium tank is a trade in. I had a tank of tri mix for stainless steel MIG. It didn't work near as well as TIG so it gathered dust. If you do any thick aluminum, such as castings, you'll love it.
    Willie
    Dec 2003
    Fairfield,CT
    Could not get it to start for the life of me until I mixed in some argon. I do not have "blue lightning" my Dyn 300 is 2006
    Dynasty 300 DX
    HTP 240
    Miller Bobcat 225G
    LN-25
    Bpt. Mill/DRO
    PDX Pacific NW
    100%
    Hmm...
    for really thick stuff ya but I think I'd wanna use ac and mix it. Last time I checked the price of helium it was like 150$ to fill it. Now I pay 70 for argon. It sure would last a while since it's only for aluminum
    Good reason to use a "Y" fitting and blend.
    Can you up your start amps?
    Dec 2003
    Fairfield,CT
    Yes I played with that as well. I just gave up and mixed it for that particular job I had. Sorry not to highjack.
    Dynasty 300 DX
    HTP 240
    Miller Bobcat 225G
    LN-25
    Bpt. Mill/DRO
    Jan 2011
    Hutchinson Kansas
    I have used a 50/50 helium argon mix for thicker stuff. I liked it so much I started using it anytime I have a lot of AL to do. It is hotter. It also wets out better and seems to weld cleaner with a shinier bead.
    Mar 2006
    Propanehotrod, thats the answer i was looking for.
    Willie
    Are you using "5 CFH" of helium through a helium specific regulator, or 5 CFH of helium through an argon/CO2 regulator? If the latter, you're using more like 15-20 CFH.
    First person on WeldingWeb to have a scrolling signature!
    HTP Invertig221 D.V. Water-cooled
    Millermatic 211 Inverter MIG w/ Spoolmate 150
    Eastwood 40A Plasma cutter
    Mar 2014
    Gas Flow Calculation
    Flowmeters are calibrated for a specific gas (e.g. nitrogen for the RTA). To calculate the flow rate of another gas, multiply the reading by the ratio of the conversion factor or the desired gas to the conversion factor for the calibration gas. For example on the RTA (calibrated for nitrogen), if the indication is 200 ml/min and the gas is Argon, the actual flow rate is 200 * 1.443=288 ml/min. GAS FACTOR
    Nitrogen 1.00
    Oxygen .996
    Argon 1.443
    Air 1.00
    Helium 1.454
    Water Vapor 0.817
    https://engineering.dartmouth.edu/mi...libration.html
    The helium regulator has two scales, one for helium, the other for argon. You are correct, helium passes through a regulator much easier than argon, little atoms.
    Willie
    Quote Originally Posted by HT2-4956 View Post
    Nitrogen 1.00
    Oxygen .996
    Argon 1.443
    Air 1.00
    Helium 1.454
    Water Vapor 0.817
    Yup, seen this before. Doesn't work for welding flowmeters
    Quote Originally Posted by rahtreelimbs
    Found this thru a Google search. Does this mean that since Argon and Helium are very close in numbers a flowmeter for Argon would work for Helium?
    I would venture to say that is incorrect, in general. That might be specific for that Dartmouth RTA thing, but look at this Miller flowmeter. Not that 10CFM of argon (well the ball location that is), is about ~23 CFM of Helium. Now I see why people, including Jody, say you just barely have to crack it open and float the ball above it's seat; it's a heck of a lot of flow, probably due to density differences.
    SE Saskatchewan, Canada
    I'm anxious to give my bottle of 75 Argon 25 Helium a try on aluminum.
    Been to busy to do any testing.
    Wondering if the added energy will require going to a water cooled torch??
    On my Lincoln SW200 the stock #17 torch can reach its limits just on Argon. I do have a #26 torch that I can switch to if doing lots of welding maxed out but wondering if going to Argon/Helium mix will go beyond what it can handle.
    Lincoln Ranger 305G
    Miller Big 40 (SOLD)
    Hypertherm 30XP
    Lincoln Square Wave TIG200
    Koike IK-12
    Evolution EVO380
    Mar 2017
    Forest Grove OR
    The added energy is in the arc, it's a more efficient thermal conductor, not a better electrical conductor. Same amps, just runs hotter in the weld pool.
    Feb 2015
    50/50 argon helium works great on aluminum. Very nice looking shiny welds on inverter or transformer. HE50 is the mix and cheaper for me than straight argon. Run about 30cfh give or take depending on what my setup is. Very fast welding, great for production, works on thinner material. Even if it was more expensive I would still use it, once you get the hang of it you won't go back. Be ready to move fast!
    Now it seems all I own are ESAB products, a lonely Hypertherm 85 and couple of Miller XMT's.
