Enough is enough
Results 1 to 25 of 27
    Oct 2016
    Enough is enough
    So I have a 58 SA-200 and it was sitting for years before it landed here. Well I have been putting off some work on it, and now I could have used it yesterday and it didn't start. So time to get it working right
    First of all, it has a Wico magneto, with a pretty bad cap, so I will order a cap, rotor, and points today. Then take it off and retime everything. Has anyone spent much time with one of these? Anyone have a few pointers on Wico?
    Next, the carb is old, steel, and not the best. I am toying with just buying a new one and putting this one on the shelf for later. Do the new ones have the mesh screen on the inlet?
    Then the fuel line is a mess, so I will install a steel line, does anyone make a pre-made one? If not I was just going to bend some tubing and try for the best path.
    Ounce I get it running reliably it sure will be nice and handy.
    Mar 2009
    Re: Enough is enough
    Can't help on the Wico.
    I assume "steel" carburetor means it's a Marvel Schebler. Probably a TSX-514 or 239. Either way a Hygrade 1302 rebuild kit is cheap. McDonald Carb and Ignition can get you any thing you need to make it gooderinnew. I'm kinda partial to the Marvel's. Clean and properly kitted, their easy to work on and tune.
    Mesh screens can be had everywhere for cheap. Just look for a "fuel strainer elbow fitting". Or if you order some stuff from McDonald Carb, he'll have one.
    http://www.mcdonaldcarb.com/category_s/356.htm
    No one I know of makes a premade fuel line. But I have seen them made out of everything from copper tube to rubber line.
    Oct 2016
    Quote Originally Posted by Pipeliner View Post
    Yes it is a Marvel schebler carb, so I have have the choice of rebuilding or replacing. I will chase down a rebuild kit and see what my options are. Thanks for the link. I just need to verify the carb model
    Mar 2009
    If you get a Hygrade 1302 it will rebuild 99% of Marvels and you'll have half a box of parts left over. You'll need to get throttle shaft bushings from McDonald if they're sloppy.
    Oct 2013
    cntrl FL
    Is that '58 an early Long Hood with the R-57 idler or a Late model Short Hood that has a Bellows idler? I'm Just curious.
    SA 200's 1970, 1969,1965, 1963, 1955/44,
    SA 250 1981 D152 DC only
    2004 Ranger 10,000
    Lincoln Pro mig 135
    Hobart GPB 1957 258 Pipeliner, 1958 261 Mainliner
    Miller Load Bank
    Everlast ST 200
    Hobart Airforce 250
    Oct 2016
    Quote Originally Posted by BYW200 View Post
    Long hood with the R-57 idler. Still 6 volt pos ground. Only thing they changed is it has a spin on oil filter.
    May 2008
    Orange, TX
    1/4" steel brake line works too but you'll need a double flare flaring tool if you have to cut a standard length line to get it to fit.
    My go to is rubber fuel line with appropriate barbed fittings at the sediment bowl and carb fuel inlet with inline fuel filter for extra protection.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save 2nd Base!
    Nov 2013
    Livingston, New Jersey, United States
    Glad you said that Duane that is what I used and hoped it was right.
    John
    Sent from my XT1254 using Tapatalk
    Oct 2016
    Parts are inbound. Being at the end of the road they should be here by the end of the week. I will strip the carb and get a soak going so its ready for a rebuild. Just finished printing off the magneto timing from the manuals post in previous threads (thank you Duane) so by the time parts hit the mailbox I should be ready.
    Then after its running I will get the gin pole truck done, lift the SAE-300 off the trailer and pull the head off to see how bad things are,
    Oct 2016
    I have been bending the steel brake line for my older tractors to make the ones that are unavailable, it has a mix of cooper and rubber line on it right now, which leaks.
    The clean bent steel lines appeal to my OCD, but they say the have pills for that, oh well
    Oct 2016
    well the parts arrived today, so Saturday morning i will give her a good work over.
    Jun 2016
    Not there
    Poat a video. These kids that never welded with one will never be able to understand.......nothing is even similar.
    Oct 2016
    Wel I got the mag done, and the carb done, and everything back together. It fires up and ran but needs some adjustments. I need to check the timing and then recheck the OCV and away we go
    Jun 2016
    Not there
    Fantastic.......I'm scanning the market for anorher one the last few days. Some old guys want a 'vette or a Harley....I already did that.
    I wanna die listening to an SA idling down after I drop the stinger on the ground and spill my last beer. Is that too much to ask for ?
    Mar 2016
    North Georgia
    I want to fuel inject a sa200...
    Maybe one day ill get another one to play with
    Oct 2016
    Quote Originally Posted by Michael ray View Post
    I have been pondering this, one would think you could make a pick-up from the mag drive gear, then run a GM injector in a throttle body inplace of the carb. Now all you need is a simple ECM. Like on the old gm 4 bangers
    Let me know how it works��
    Mar 2016
    North Georgia
    Quote Originally Posted by Hoff907 View Post
    Any timed signal can be converted into an input for the control module..
    Been gathering up the parts to inject a Harley and still plan on it pretty soon.
    Best thing ive found for the computer is a brand called megasquirt. All the parameters are fully adjustable, can use a series of coil packs or a single coil pack for a modern 4 cylinder and high or low impendance injectors..
    Ive done a couple types of motors with that computer and it is awesome for engine control
    Oct 2016
    Well I will be going back out for the 4th attempt to time the magneto. The Wico rotor can be installed anywhere on the shaft, there is no index to it. Now I can see where the rotor drive gear is beveled so maybe it is suppose to be set to the rotor somehow. Anyway, I can not get it to do more than pop off, and sometimes less
    It sure is getting frustrating
    Mar 2016
    North Georgia
    Back when i was a kid...had to be less than 12... i had a honda 3 wheeler that i couldnt find timing marks for. I watched the intake and exhaust valve in relation to the piston and tried to start it.. moved the cam advance and retard a couple teeth and coukdnt get it going...sat there for a couple hours and just started moving the cam a tooth at a time and repeatedly tried to start it..finially after 25-30 attempts i got it running..had to move it a couple more teeth for it to run good..and when it ran good, i discovered the proper way to time it, it was pretty clear.. learned alot about how stuff works by doing it
    Oct 2016
    Well I set the only timing mark I see on the rotor, a small line directly under the rotor point/tab between the two bevel gears. Seems close. Got a decent spark on #4 on the bench, rechecked the whole timing of the governor and the rest, and then reinstalled the mag. Then I went thru the carb again just to be sure.
    It will fire and start, but not run.i have turned the mag top as far towards the block as I can
    Oct 2016
    update
    I called BW and spoke with Randy, then called Standard Magneto. after talking with them I ended up with the following
    1) I am timing the Rotor to the gear correctly
    2) I need to check the advance, with is fairly easy
    3) since the Plug wires are suspect and may be the wrong type for a Magneto I will replace the Plugs, wires, and magneto coil
    I am timing the unit correctly, just missing a few items and there could be some issues, so lets see when the next batch of parts show up
    Oct 2016
    Well the parts came this week, and I put them in the mag, it was set to the correct advance.
    After assemble when I went to bench test it, no spark. Back apart, and the two wires off the coil I mixed up. I had spark over nearly 5/32 of an inch and blue. Took the wife shopping, went back this morning and no spark on the bench. I am pulling my hair out with this. So I took it back apart, checked the points gap, and it's 15 thousand, the only thing I can guess is I have a spark plug on it set to .030 for my last check. Back to the bench
    FYI. Primary coil checks in at 1.5 ohms, secondary coil at 5.46 K ohms, points set to .015, plugs and wires from high speed and new, cap, rotor, coil, points, condenser new from BW.
    With the coil ground removed I have no continuity from the unit to the case, with the mag rotating and the cap off you can see sparks at the points, the tabs from the cap are touching the coil button and I would guess the rotor but I can not see that one. With a meter I have continuity from cap to the plug electrode. I have cleaned the points twice and will do a third one next.
    This thing is starting to get frustrating
    Oct 2016
    Cleaned and went thru it again, no spark from the 4 plugs clamped to the table.
    Checked and cleaned the points, re-gaped the plugs to .020, zilch
    And a tig rod to the coil button will jump almost 3/8 inch. But nothing out of the rotor and cap.
    Nov 2015
    Beacon and Pawling, New York
    Change the rotor. I have seen rotors fail where the spark will ground to the distributor shaft.
    Eventual master of the obvious, practitioner of "stream of consciousness fabrication". P.S. I edit almost every post because because I'm posting from my phone and my fingers sometimes move faster than my brain.
    Jul 2017
    I have had brand new condensors that were bad. Not uncommon in this chinese parts world
