Enough is enough - Page 2
Page 2 of 2 FirstFirst 12
Results 26 to 27 of 27
    Oct 2016
    Re: Enough is enough
    Quote Originally Posted by Sedanman View Post
    Change the rotor. I have seen rotors fail where the spark will ground to the distributor shaft.
    Sedanman, thank you
    I read your post and went down and pulled off the cap, took the rotor and checked it with a meter, it had continuity from the button to the shaft. Put the old rotor on and checked the mag, 4 plugs sparking. So then I timed the mag, checked the engine timing, put it all back together, and two revolutions with the starter and it was running. And not to bad either, she has a small skip but I think it should work out.
    I am out of time tonight, but this week I will set the timing, check the OCV, set the high idle and low idle, and use the machine
    Thank you gents.
    Oct 2016
    An update, the machine is running and starts great, I set the timing and high idle. It really welds nice, but if you fire up a rod it does well for a little bit and then bogs down, almost like it's running out of gas, and then comes back, but you can hear it hunting. Maybe the governor settings? I noticed the sensitivity is set near the end of the arm
    But it welds great, really amazing
