Remaking a '46 short hood
Results 1 to 25 of 36
    Aug 2016
    Tulsa, OK
    I know there are a lot of members out there that have upgraded early model short hoods by using compound exciters, exciter armatures and coils from later model short hoods. However, I did not have a later model short hood machine from which to rob these parts. The purpose of this post is to describe my journey with this old short hood. I will also post pictures as I tell the tale. I purchased this machine about five years ago from a farmer near Coyle, Oklahoma. My first mistake was having no knowledge of short hoods in general and this '46 model in particular. These are the beginning photos. The welder was known as 2G-2. The narrative will continue with subsequent posts along with progress photos.
    Aug 2016
    Tulsa, OK
    Re: Remaking a '46 short hood
    As I started the disassembly process I noticed there was no hole in the backing plate for a starter. It was not until I attempted to separate the engine from the generator that I learned what a Lord bushing and pin coupling was and how difficult it is to separate after 71 years. All you old Pros have to be laughing by now. When I finally manage to uncouple the coupling there was more horror to be seen, a flywheel without a ring gear! To be continued...Name:  Hand crank no starter or hole for one.jpg
Size:  114.5 KBName:  Lord Bushing & Pin Flywheel to Generator Armature Coupling.jpg
    Nov 2015
    Northford, Connecticut
    Hehehe🤣! Better join the gym and get those muscles in shape to turn that there hand crank that I hope came with your machine. I do look forward to your machines progress! Good luck
    1968-'70 Lincoln SA 200 code 6633
    Millermatic 200 serial#JE834063
    Port Orchard, WA.
    In the 1970s, I used a hand crank SA-200 for several weeks. I was amazed how easy it started. I used my foot to push on the hand crank. I think the SA-200s with a starter, turn to fast. Mine take longer to start, than that hand crank did.
    Don’t pay any attention to me
    I’m just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Oct 2013
    cntrl FL
    WoW! That Short Hood looks all original. That's the first time I've seen an oiler cup going too the Armature bearing, and the brush cover is notched out for it to. It's well worth the effort to get it back to like new condition.
    SA 200's 1970, 1969,1965, 1963, 1955/44,
    SA 250 1981 D152 DC only
    2004 Ranger 10,000
    Lincoln Pro mig 135
    Hobart GPB 1957 258 Pipeliner, 1958 261 Mainliner
    Miller Load Bank
    Everlast ST 200
    Hobart Airforce 250
    Yep, if they were in good tune... 4 turns with the mag off and full choke, set'er up on compression, mag on and give it a tug... off we go. Easy peasy.
    I have a flywheel with starter ring and backing plate with starter hole if you need one for that machine. W.B.
    Aug 2016
    Tulsa, OK
    My next step was to exercise a little urban renewal. I had to clean out and tear down the old neighborhood. Too be continued, next is how I converted to electric start for $316.
    Aug 2016
    Tulsa, OK
    I converted to electric start using the following recipe and $314:
    1 starter ring gear from a newer model short hood: $25
    1 backing plate from a newer model short hood: $25
    1 new hi-torque tractor starter: $75
    1 new starter button switch: $7.50
    1 new Denso 35 amp mini alternator: $75
    1 new fan belt: $16
    1 new Mega Crank 30 amp ATV battery: $89.95
    2 new batter cables: $8.95
    1 friend with a lathe: free
    Making it all work: priceless
    Name:  turned flywheel & pressed ring gear.JPG
    Turn flywheel edge down and press fit ring gear on flywheel according to Lincoln specification.
    Lay 5 bolt backing plate from newer short hood on top of 4 bolt backing plate and bolt them together. Drill new 4 bolt mounting holes in newer plate using older plate as a template. (I forgot to take a picture of this).
    Name:  Tractor high torque starter.jpg
    Mount hi-torque tractor starter.
    I had to fabricate a bracket for the Denso alternator but it worked ok. I had to high mount the alternator to create clearance between the fan belt and lower radiator hose. Also, there was no room for the battery up front so I mounted it where you see it.
    I will post some before and after photos of the total rebuild process soon...
    Aug 2016
    Tulsa, OK
    Name:  New Pistons, New Valves and Seats Ground.jpg
Size:  67.8 KBName:  Engine With Head Removed.jpg
Size:  134.5 KBName:  Candy Nectarine and Clear Coat over Sparkle Silver Generator Housing Coupled to Engine on Frame.jpg
Size:  97.0 KBName:  Dissassembly Begins.jpg
    More later...
    Feb 2005
    Louisiana
    Great before and after pics. Also nice looking dog!
    A few of my toys !
    Manjaro
    LinuxMint
    Miller Roughneck 2E
    Lincoln WeldPak 100
    HTP MTS 160
    Victor O/A
    Aug 2016
    Tulsa, OK
    more engine before and after...Name:  New Springs, New Valve Guides and Pins.jpg
Size:  101.5 KB new valve train (valves, springs, guides, keepers and ground seats Name:  DSCN0666.jpg
Size:  81.2 KBName:  DSCN0669.jpg
Size:  124.7 KBName:  Block Bored .040 With New Camshaft & Main Bearings.jpg
Size:  88.6 KB new main and camshaft bearings...more later
    ROCKVILLE ,,VA
    looks great !!
    Aug 2016
    Tulsa, OK
    My last four last picture posts...and a special thanks to Duane for helping me with the idler board wiring and carburetor linkage!Name:  Parts prep work.jpg
Size:  73.1 KBName:  Parts prep work 2.jpg
Size:  87.7 KBName:  Parts primer 3.jpg
Size:  138.6 KBName:  Parts primer 2.jpg
Size:  131.2 KBName:  Parts primer 1.jpg
    Aug 2016
    Tulsa, OK
    #2Name:  Frame painted.jpg
    Oct 2013
    cntrl FL
    Looking Good !
    Sent from my XT1254 using Tapatalk
    2004 Ranger 10,000
    Lincoln Pro mig 135
    Miller Load Bank
    Everlast ST 200
    Hobart Airforce 250
    Aug 2016
    Tulsa, OK
    #3Name:  Primered front panel.jpg
Size:  53.3 KBName:  Main generator housing base coat.jpg
Size:  64.6 KBName:  main generator housing prep.jpg
Size:  104.9 KBName:  Generator Housing Paint Prep (matching Barrel #158704).jpg
    Aug 2016
    Tulsa, OK
    #4Name:  Before roof goes on.jpg
Size:  101.0 KB Thanks for looking and next time I post something I will try to be more organized
    Very, very nicely done. Love your attention to detail and adapted uses for the engine stand.
    4 out of the 5 voices in my head say "Go for it".
    Mar 2009
    Just curious SKP - what are you using for an air cleaner?
    Aug 2016
    Tulsa, OK
    I have not yet decided. I know where I can get an original but the guy wants $130 which seem a little rich to me. I have 3 or 4 of the later model oil filled Lincoln air filters laying around my shop, I may adapt one of them. I have also fabbed one before with a couple of round plates and a dry air filter. And lastly, I may buy a K&N.
    Aug 2016
    Tulsa, OK
    Thanks Duane, Those frames are hard to paint properly unless you can rotate them. And I have a nice paint booth with piped in breathing air and I can run 20,000 CFM through it with the big Devilbiss exhaust fan. I have a VFD on the motor so it is easy to adjust.
    My "paint booth" air flow is based on the wind velocity at any given time. Love bugs and other "assistants" have been known to occasionally get stuck in the paint too.
    Mar 2009
    Quote Originally Posted by SKP View Post
    By original, do you mean the one on the left or right?
  25. #25
    Feb 2005
    Louisiana
    I agree with Duane. I have seen his "paint booth"!
    A few of my toys !
    Manjaro
    LinuxMint
    Miller Roughneck 2E
    Lincoln WeldPak 100
    HTP MTS 160
    Victor O/A
