Nuts turn WHITE when welded? - Page 2
Results 26 to 38 of 38
    Mar 2017
    Forest Grove OR
    Re: Nuts turn WHITE when welded?
    I used stainless nuts. no coating, decent strength, don't rust, easy to find, nice and shiney when you are done brushing them. They aren't cheap, but neither is my time taking coating off.
    city of Four Flags
    CEP, how did an amateur welder like you get to inspect that kind of job site
    Mar 2014
    Can't say I ever recall my nuts turning white when I welded but I do recall a few times in iffy situations where the little buggers tried to crawl back up inside me to keep themselves out of harms way.
    Sep 2016
    Near Traverse City, Mi.
    I am really disappointed that this thread did not go sideways, or downhill. Maybe the door was left too far open.
    Miller Dynasty 280 DX, Lincoln 210 MP
    Port Orchard, WA.
    Inspect?
    Don’t pay any attention to me
    I’m just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Jul 2017
    Florida
    Yep, a perfectly good thread gone down the tube.
    At least the OP now knows 1 reason why his nuts turned white.
    HTP 221 water cooled
    new york city
    i'm amazed it took this long you guys are slipping.
    i.u.o.e. # 15
    queens, ny and sunny fla
  8. #33
    Apr 2012
    socal
    I have never sweated the electroplated zinc (whatever) Now, the hot dipped stuff is another story, on pipe I'll get out the torch & heat/melt & brush it off or use a sanding disk to remove, it seems to load up grinding stones the way aluminium does.
    -c-
    "Hey, if it ain't broken, break it"
  9. #34
    my nuts have been blue
    but never white...
    Miller 211/Spoolmate 100
    Lincoln SP125 plus
    Chicom spot welder
  10. #35
    Aug 2016
    what I use:
    Charl
    AHP 200X 2016, EVERLAST 211Si 2016
  11. #36
    Nov 2008
    Texas Near Dallas
    .... mcmaster is an easy place to get uncoated nuts......
    Yep... and they even have other shapes that make welding easier
    https://www.mcmaster.com/#weld-nuts/
    For regular nuts just look for the ones that say "steel" instead of "zinc-plated"
    For example 1/2-13 grade 5 would be one I commonly use. https://www.mcmaster.com/#95505a605
    From a google search I found the grade 8 tempering temperature to be 800F. Your just welded nut that's red-hot will definitely exceed this. So the fastener will be softer (and have lower yield strength) than it did originally. So there's no point in buying expensive fasteners that you're just going to ruin anyway.
    Dynasty200DX w/coolmate1
    MM Vintage
    ESAB miniarc161lts
    Lincoln AC225
    Victor O/A, Smith AW1A
    Cutmaster 81
    IR 2475N7.5FP
    Rage3
    Jancy USA101
    9" SB
    AEAD-200LE
  12. #37
    Quote Originally Posted by xmmancharl View Post
    what I use:
    Charl
    What model is that?
    Im wondering if those filters attach the same way as mine...
    Lincoln SP125 plus
    Chicom spot welder
  13. #38
    Jul 2017
    Florida
    Your local DG Hardware should carry uncoated steel nuts, unless you nut then by the box load.
    At least ours does anyways.
