Your thoughts on this Idealarc 250
Page 1 of 4 123 ... LastLast
Results 1 to 25 of 92
    Feb 2017
    This Idealarc 250 is for sale locally. Says it welds beautifully and comes with 100' of + and 75" negative cable. Model is 250-250, code is 9041-C, serial is AC-609568. He's asking $300. It doesn't sound like a screaming good deal, but not bad. What do you think? Not sure if I'm reading the serial number service bulletin correctly or not, but it may be 1985 or 1985?
    Home tinkerer and old tool junkie
    Lincoln SP 135 Plus
    Ĺincoln Idealarc 250/250
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Harris O/A Port-A-Torch
    Coal forge & anvil
    Apr 2008
    NW ON Canada
    Hard to beat that machine for that price. The lead/cables alone are worth more than what he's asking for the package.
    The age of these machines is almost kinda irrelevant. They seem to last forever.
    Jason
    Lincoln Idealarc 250
    Thermal Dynamics Cutmaster 52
    Miller Bobcat 250
    Thermal Arc Hefty feeder
    Torchmate CNC table
    Ironworkers Local 720
    Bemidji MN
    Re: Your thoughts on this Idealarc 250
    +1 decent deal in my book
    Airco 300 - Syncro 350
    CT
    If it was near me, it would be sold already. ;-)
    Hobart Handler 190
    Syncrowave 250
    Purox Metalmaster
    Mar 2009
    Yes it's an 85'. Yes it's a good deal given the amount of leads that come with it. Yes it would also be sold if it were near me. Yes it should be in the back of your truck already.
    Feb 2017
    Thanks for the feedback guys. I just called and left a message with the seller. Will try to go look at it tonight.
    Lincoln SP 135 Plus
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Coal forge & anvil
    Jan 2008
    Richmond, Virginia
    Screaming good deal if the leads are in good shape and it works. If I didn't have one already, I would have been up there a couple days ago.
    I got mine out by Charlottesville: Name:  idealarc 250 ours 3.jpg
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
    Mar 2005
    Under a Rock
    Buy it !
    Miller 211/Spoolmate 100
    1961 Lincoln Idealarc 250
    Hypertherm PM 45
    Lincoln SP125 plus
    HTP 221
    Chicom spot welder
    Jan 2014
    Hallieford, VA
    Oldendum was kind enough to pass that listing on to me a couple of days ago. I have one but would have bought this one also to resell if I had the time to retrieve it. (Thanks Dick). Great buy!
    Jerry
    30+ yrs Army Infantry & Field Artillery, 24 yrs ago
    Miller 350LX Tig Runner
    TA 210, spool gun
    Lincoln 250/250 IdealArc
    ESAB PCM 500i Plasma
    Kazoo 30" vert BS
    Kazoo 9x16 horiz BS
    Clausing 12x24 lathe
    20T Air Press
    Feb 2017
    I've emailed, called and texted the seller - no response. It may be gone. I've got a MIG and TIG, so its not the end of the world. But i'm always looking to add to my home shop equipment.
    Lincoln SP 135 Plus
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Coal forge & anvil
    Southern Illinois
    Yes it's a 1985 and has power factor capacitors factory installed.
    It's a good deal, go get it!
    My partner and I buy them and have them powder coated and we clean and lubricate them. Ready for another 40 years of service!
    Here's one we have done recently
    Steve
    1990 Miller Dialarc 250
    1993 Miller Maxstar 140 STR
    2015 Lincoln MP210
    1966 Lincoln SA200 Redface
    Feb 2017
    Wow - that's beautiful! I've still not heard anything back, but still hoping.
    Lincoln SP 135 Plus
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Coal forge & anvil
    Southern Illinois
    Hang in there.
    Steve
    2015 Lincoln MP210
    Jan 2014
    Hallieford, VA
    Mine with original paint and just a blow out. $400 a few years ago from VA Dept of Trans.
    Jerry
    TA 210, spool gun
    Kazoo 30" vert BS
    Kazoo 9x16 horiz BS
    20T Air Press
    Southern Illinois
    That's a great looking machine Jerry.
    I sold my Idealarc250 and got a Miller Dialarc 250 and had a custom aluminum tread plate hood made for it.
    Steve
    2015 Lincoln MP210
    Nov 2015
    Beacon and Pawling, New York
    Quote Originally Posted by storeman View Post
    Jerry
    Wow! I got mine for $100 but it looks like hell.
    Eventual master of the obvious, practitioner of "stream of consciousness fabrication". P.S. I edit almost every post because because I'm posting from my phone and my fingers sometimes move faster than my brain.
    Jan 2014
    Hallieford, VA
    Pretty machine Steve Obviously VDOT made typical govt use of mine..
    Jerry
    TA 210, spool gun
    Kazoo 30" vert BS
    Kazoo 9x16 horiz BS
    20T Air Press
    Southern Illinois
    My first was a 1975 model I got for $130 at a flea market. It had a rough life but the still usually weld good. Anything short of a direct lightning strike doesn't effect them!
    Steve
    2015 Lincoln MP210
    Nov 2012
    $300 is cheap for that machine
    Dec 2015
    Western New York State, USA
    they stick weld nice. some will same best stick welders around. maybe motor generator welder a little better
    machine is just big and heavy. once you use a inverter at 15 to 50 lbs that you carry whole machine to where working you dont need long welding cables. 15 lb inverter welder i got came with shoulder strap. literally could climb a ladder with it on my shoulder. or easily carry one handed and put it on my car seat to take somewhere else
    50 or 100 feet of 10ga extension cord is cheaper and a lot lighter to carry. you up 50 foot on structural steel you can have welding machine on the steel beam. no having to climb down to adjust amps
    Southern Illinois
    Your 100% percent correct. They are heavy so no comparison to inverter machines. My Miller Maxstar 140STR weighs in at +/-10lbs. It runs 1/8" 7018 great. The difference I have noticed running inverter machines, the Maxstar, 210MP or my buddy's Miller 215 is they don't have the guts to long arc, you have to hold a tight arc which you should anyway.
    Steve
    2015 Lincoln MP210
    Nov 2015
    WNY TomB, but your inverter doesn't have a 100 percent duty cycle at 125 amps. This is the reason this is still the machine of choice to teach stick welding with. These things will burn 1/8 7018 non-stop. Also, ever seen anyone arc gouge with an inverter? Your little toaster might be right for you, but it's not for everyone. I have a little inverter and a big old transformer machine, both have their place.
    Mar 2015
    If you get the welder the first thing you need is to cut the castors off that cart. Those little dinky castors aren't up to moving that heavy of welder around. Even if the floor is smooth, one pebble that stops a leading wheel and its going over.
    Feb 2017
    Unfortunately it appears to be sold. I've tried contacting the the seller multiple times, no response whatsoever. I'll keep my eyes open.
    Lincoln SP 135 Plus
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Coal forge & anvil
    Jan 2016
    Quote Originally Posted by WNY_TomB View Post
    I have both transformer and inverter machines, I doubt you will see any brand inverter last 60 years plus.....both have there place for work..
