Your thoughts on this Idealarc 250 - Page 2
Results 26 to 50 of 92
    Southern Illinois
    Re: Your thoughts on this Idealarc 250
    There are lots out there. Keep looking. Don't rule out a Miller Dialarc 250 if one pops up. They are the same quality machine and depending on the area of the country they can be cheaper than the Lincoln
    Steve
    1990 Miller Dialarc 250
    1993 Miller Maxstar 140 STR
    2015 Lincoln MP210
    1966 Lincoln SA200 Redface
    Bemidji MN
    I have both transformer and inverter machines, I doubt you will see any brand inverter last 60 years plus.....both have there place for work..
    +1
    Love the old stuff, but my inverters are nice too
    Another vote for Dialarcs as well - weld very nice and sometimes are as little as $200.
    Airco 300 - Syncro 350
    Feb 2017
    I've spotted another Idealarc 250, but its about 4 hours away. Its the nicest looking one I've seen for sale within striking distance. The guy is asking $425. What do think - good deal or not?
    Home tinkerer and old tool junkie
    Lincoln SP 135 Plus
    Ĺincoln Idealarc 250/250
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Harris O/A Port-A-Torch
    Coal forge & anvil
    Southern Illinois
    Take the wife on a road trip and go get it
    Steve
    2015 Lincoln MP210
  5. #30
    Southern Illinois
    If the serial is AC323--- it's a 1974 model. That's what it looks like to me
    Steve
    2015 Lincoln MP210
  6. #31
    Southern Illinois
    And the C after the code number means it has power factor capacitors installed
    Steve
    2015 Lincoln MP210
  7. #32
    Bemidji MN
    Quote Originally Posted by ndnchf View Post
    That one is very nice. It may help you to know that the new version of it is $2,500
  8. #33
    Feb 2017
    Thanks guys. I've was trying to read the serial number too. I couldn't quite tell if it starts with a 2 or a 3. What does the power factor capacitor do for it?
    Lincoln SP 135 Plus
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Coal forge & anvil
  9. #34
    Southern Illinois
    The power factor capacitors basically reduce amperage draw while welding but at idle it pulls more amps. For home use it really won't make much difference just don't let it idle for long stretches of time
    Do a search here and in you tube there is a great video that shows amperage draw with and without capacitors at various amperage settings.
    Steve
    2015 Lincoln MP210
  10. #35
    Bemidji MN
    It will reduce the size of breaker and wiring you need for the unit.
    Name:  idealarc 250 power.png
  11. #36
    Feb 2017
    I just did some reading on the PFCs, got it now. But it made me realize I may be biting off more than I can chew, electrically speaking. I'm in an older home with original wiring. I have a 230v 50amp circuit in my garage and that servers fine for my Alpha TIG and Plasma. But it looks like it may be inadequate for an Idealarc. Its not feasible to update the circuit without addition major upgrades that I'm not ready to do. So is the Idealarc too much? I really like them, but for my home use, I don't really NEED that much.....I just like 'em. Maybe I should look for an AC/DC tombstone or something similar?
    Lincoln SP 135 Plus
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Coal forge & anvil
  12. #37
    Feb 2005
    Louisiana
    I am just guessing and going out on a limb here but, I am thinking the amp draw required (thus breaker size required) is for full/max amp output by the machine. If you will not be using the max amp output of the machine, you may be good to go with what you have in your garage as to wire size and breaker size. Like I say, I am just guessing and not totally sure.
  13. #38
    Bemidji MN
    When welding under 200 amps, the 50 amp breaker will be fine with the power factor corrected machine.
  14. #39
    Jan 2008
    Richmond, Virginia
    Nice looking. I'd try for $375. - $400. considering the smallish leads.
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
  15. #40
    Mar 2009
    You can burn 1/8" rod all day everyday on a 50 amp circuit.
  16. #41
    Feb 2017
    That's good to ear. I'm retired from the navy, but not building a battleship! I see no need for anything larger than 1/8" rod.
    Lincoln SP 135 Plus
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Coal forge & anvil
  17. #42
    Southern Illinois
    I've always run my Idealarcs and Dialarc machines on 50 amp circuits
    Steve
    2015 Lincoln MP210
  18. #43
    Feb 2005
    Louisiana
    Thank you for your service! If you dont mind, pm me your info of your service, MOS, etc. I would like to hear about it. Thanks!
  19. #44
    Feb 2017
    Thanks guys, good to know the 50 amp circuit will handle all my needs. Just wish it wasn't so far away. I'll think on it.
    Lincoln SP 135 Plus
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Coal forge & anvil
  20. #45
    Jan 2008
    Richmond, Virginia
    ... I'm retired from the navy, but not building a battleship! ...
    My son worked for the Navy for a couple years. Men's department - USMC. There's a retired Navy guy I know up in F'burg. I'll PM you. Maybe you know him.
    SP-175 +
    Miller spot welder
  21. #46
    Feb 2017
    I called and left a voice mail with the seller of that nice Idealarc, but no call back yet. May have missed out on this one too.
    I don't know much (read that as anything) about Dialarcs, but have read good things about them. I would consider one if a good deal popped up. I've seen a couple on CL, but more than I would like to spend. There is something about the style of the old Idealarcs that appeals to me. I have a garage and shop full of vintage equipment. An old Idealarc would be a good fit.
    Lincoln SP 135 Plus
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Coal forge & anvil
  22. #47
    Feb 2017
    To my surprise, the seller called me back and it's still available. The serial numbers ia AC-328742. He says it works great and I can test it out. Looks like a road trip Saturday morning!
    Lincoln SP 135 Plus
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Coal forge & anvil
  23. #48
    Southern Illinois
    Great. You won't regret it
    Make sure the polarity switch works and you can feel distinct stops in the 3 positions. Make sure the on/off switch snaps good and doesn't feel gummy. Crank the amp control crank up and down and check to see it moves relatively freely and the little indicator moves as well. Also check for up/down movement on amp crank. If it's sloppy that means the shaft bushings are worn out. They are about $4 each to replace. Bottom line if it fires up and welds, buy it. These other items are potential bargaining points but not big deals
    Steve
    2015 Lincoln MP210
  24. #49
    Feb 2017
    Quote Originally Posted by Sparkie View Post
    I was just about to ask what else I should look for, but you beat me to it. The next challenge will be getting it safely loaded in my truck and secured. I'll bring plenty of tie down straps.
    Assuming all goes well and I get it home. I figure it would be prudent to remove the cover and blow out the dust, then lube the bushings and gears. Anything else while I'm inside?
    Thanks again guys
    Steve
    Lincoln SP 135 Plus
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Coal forge & anvil
  25. #50
    Southern Illinois
    That's correct. Take the top and the small side panel off, the front and back panels can stay. Vacuum and/or blow the dust, dirt and debris out that's collected over the years. The gears that change amperage will have old dried grease in them that needs to be cleaned off and reapply a light coat of white lithium spray grease. On the polarity switch you will see some little rollers that are spring loaded that provides the detents, put some lithium grease on those also. The on/off switch can be cleaned with some Contact cleaner to flush the dirt out. Check the general condition of connections and look it all over. Go on Lincoln's website and download the Operator's and the separate parts manual to have for reference
    Steve
    2015 Lincoln MP210
