Your thoughts on this Idealarc 250 - Page 3
Results 51 to 75 of 92
  1. #51
    Bemidji MN
    Re: Your thoughts on this Idealarc 250
    Quote Originally Posted by ndnchf View Post
    I was just about to ask what else I should look for, but you beat me to it. The next challenge will be getting it safely loaded in my truck and secured. I'll bring plenty of tie down straps.
    Assuming all goes well and I get it home. I figure it would be prudent to remove the cover and blow out the dust, then lube the bushings and gears. Anything else while I'm inside?
    Thanks again guys
    Steve
    For heavy stuff like this I bring my engine hoist with me.
    Likely 350+ lbs.
    Airco 300 - Syncro 350
  2. #52
    Feb 2017
    Quote Originally Posted by Sparkie View Post
    That's correct. Take the top and the small side panel off, the front and back panels can stay. Vacuum and/or blow the dust, dirt and debris out that's collected over the years. The gears that change amperage will have old dried grease in them that needs to be cleaned off and reapply a light coat of white lithium spray grease. On the polarity switch you will see some little rollers that are spring loaded that provides the detents, put some lithium grease on those also. The on/off switch can be cleaned with some Contact cleaner to flush the dirt out. Check the general condition of connections and look it all over. Go on Lincoln's website and download the Operator's and the separate parts manual to have for reference
    Excellent, that's just what I needed to know. I'll go see if I can find the online manual. Thanks!
    Home tinkerer and old tool junkie
    Lincoln SP 135 Plus
    Ĺincoln Idealarc 250/250
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Harris O/A Port-A-Torch
    Coal forge & anvil
  3. #53
    Feb 2017
    Likely 350+ lbs.
    Unfortunately I sold my engine hoist after rebuilding the engine in my 1924 Ford model T. I just didn't have the room to store it. My 2 car garage is jam packed. But the seller said he has some friends that can help load it. For unloading I have a 1000lb capacity pneumatic lift table that I can butt up to the tailgate. I can then get it to ground level. But an engine lift would be easier.
    BTW, what are the outside dimensions of the Idealarc? I need to do some rearranging to make room for it. Thanks.
    Lincoln SP 135 Plus
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Coal forge & anvil
  4. #54
    Mar 2009
    Here you go, see page 11.
    http://www.lincolnelectric.com/asset...oln3/im206.pdf
    Figure 21" w x 21" d x 34" to top of eye and 360 lbs +/- 5 without leads.
  5. #55
    Feb 2017
    Quote Originally Posted by Pipeliner View Post
    Thank you sir!
    I thought I've read somewhere about lubing the fan bearings. The manual says the fan motor has sealed ball bearings. it would be kind of hard to lube them if they are sealed. Did earlier models have open or just shielded bearings?
    Lincoln SP 135 Plus
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Coal forge & anvil
  6. #56
    Mar 2009
    Here are some part #'s Sparkie posted a while back on the fan / bearings.
    http://weldingweb.com/showthread.php...71#post7304671
    Most likely shielded though. Don't over think this machine too much. Turn it on. If the fan runs and it burns rods it will probably continue to do so for decades to come.
    In other words: if it ain't broke, don't fix it till it is.
  7. #57
    Feb 2017
    Sage advice!
    Wrote down the bearing and motor numbers for future reference - thanks.
    Lincoln SP 135 Plus
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Coal forge & anvil
  8. #58
    Southern Illinois
    The dimensions will be in the Operator's manual
    Steve
    1990 Miller Dialarc 250
    1993 Miller Maxstar 140 STR
    2015 Lincoln MP210
    1966 Lincoln SA200 Redface
  9. #59
    Feb 2017
    Got it - thanks.
    Lincoln SP 135 Plus
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Coal forge & anvil
  10. #60
    Feb 2017
    Can someone tell me the diameter of the hole in the lifting eye on the Idealarc? It's not on the drawing in the manual. Thanks
    Lincoln SP 135 Plus
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Coal forge & anvil
  11. #61
    Southern Illinois
    Not sure but it will handle a chain hook easy but a Miller Dialarc requires a shackle
    Steve
    2015 Lincoln MP210
  12. #62
    Feb 2017
    I've got a piece of heavy 2" pipe that I may use with 4 men to lift it onto a dolly. Just wondering if it will fit. Thanks
    Lincoln SP 135 Plus
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Coal forge & anvil
  13. #63
    Southern Illinois
    Not sure about that. Just don't let it hurt you. 350 lbs of iron
    Steve
    2015 Lincoln MP210
  14. #64
    Jun 2014
    I have an 80's model. The hole in the lifting eye is well over an inch/inch in half. I used a come along/clevis hook and beam to load in truck. Removed from truck with engine hoist. No problem. Mine didn't have the wheel kit. Made a metal dolly to put on- easy rolling.
  15. #65
    Jun 2014
    4 MEN lifting. One on each corner. Piece of cake.
  16. #66
    Jan 2008
    Richmond, Virginia
    Appx 1.75" w x 2.75" H on my old Idealarc. Sort of pear shaped, larger at top. My old Miller Dialarc is round, about 1 3/8" in diameter.
    You can see the lift eye clearly in some pics here: http://weldingweb.com/showthread.php...c-score!/page2
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
  17. #67
    Feb 2017
    I went on the assumption that my 2" pipe was too large. So I took some chain and shackles and looped then over the pipe, and made a captive clamp to keep it centered on the pipe. This will be for lifting it onto the pallet I made.
    The pallet is made kind of like a sedan chair. A 1-1/4" board secured with heavy screws to two 2"x6" boards. We'll use the pipe to set the welder on the pallet. Then strap it down securely. Then 4 men can lift the pallet up into the back of my truck. I'll use the lifting eye to secure it in the bed with straps to the four corners.
    That should get it loaded and home safely.
    Lincoln SP 135 Plus
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Coal forge & anvil
  18. #68
    Feb 2017
    Just got home with the Idealarc. It was 4+ hour drive each way, but we'll worth it. I was able to test it out using all three polarity settings and at various amp setting. This thing welds so smoothly - I love it. Hopefully I can get my son over tomorrow to help get it unloaded.
    Lincoln SP 135 Plus
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Coal forge & anvil
  19. #69
    Southern Illinois
    Your set now. Good job on acquiring a classic
    Steve
    2015 Lincoln MP210
  20. #70
    Jan 2008
    Richmond, Virginia
    You got a good one. Enjoy it.
    SP-175 +
    Miller spot welder
  21. #71
    Feb 2017
    Anxiously waiting for my son to come over this evening and help me unload it. We had four men to load it in. But for unloading, there are two of us and a 1000lb capacity pneumatic lift table.
    While waiting, I got 8 feet of new 6/3 SOOW power cable and a new 50 amp, 3 prong plug. Took some running around though. Lowes for the plug, Home Depot for the cable. Got the plug installed on the cable. After its in the garage, i'll remove the cover to blow it out, lube the moving parts and install the new power cable.
    Lincoln SP 135 Plus
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Coal forge & anvil
  22. #72
    Southern Illinois
    Good plan. It's worth the effort to set it up right
    Steve
    2015 Lincoln MP210
  23. #73
    Mar 2009
    Just remember, there is such thing as too much of a good thing. You want the amp wheel to be snug when you turn it; otherwise it will creep while you're welding. If you have to two hand it, probably too tight. If you can give it a round with one hand leave it alone. Grease and oil just attract dust / dirt / grinding dust, etc.
  24. #74
    Southern Illinois
    Very true. Some guys make the mistake of backing off the brake bands to make it easier to turn. Then when you strike an arc the amp wheel will turn on its own.
    Steve
    2015 Lincoln MP210
  25. #75
    Feb 2017
    Brake bands? I don't know what they are, so will leave theme alone.
    Lincoln SP 135 Plus
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Coal forge & anvil
