Your thoughts on this Idealarc 250 - Page 4
Page 4 of 4 FirstFirst ... 234
Results 76 to 92 of 92
  1. #76
    Southern Illinois
    Re: Your thoughts on this Idealarc 250
    On the front and back of the rotor assembly there are lined bands that set the tension on the rotor movement. Check out the parts diagram and you will see what I'm talking about.
    Steve
    1990 Miller Dialarc 250
    1993 Miller Maxstar 140 STR
    2015 Lincoln MP210
    1966 Lincoln SA200 Redface
  2. #77
    Feb 2017
    I'm looking on page 8 and 9 of the manual, but don't see them called out. But I may not be looking for the right thing. But that's ok, I'm learning as I go here.
    My son had to work late last night, so it's still in the truck. Hopefully he can get over today sometime. After getting it inside and opened up, I'll take some pics of the insides. The amp control turned smoothly with one hand, but did seem stiff. I don't have anything to compare it to, so not sure if stiff is ok. I imagine that the bushings have not been lubricated in a long time. Although it does appear to be in better overall shape than many I've seen. Hopefully the insides will be just as nice.
    Home tinkerer and old tool junkie
    Lincoln SP 135 Plus
    Ĺincoln Idealarc 250/250
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Harris O/A Port-A-Torch
    Coal forge & anvil
  3. #78
    Jul 2012
    Kingsville,Texas
    Great machine/purchase, when you install power cord be careful with on/off switch. Broke switch on my machine, only removed side cover and was working on removing wires from switch. This creates a awkward position while wrenching and it broke. Its best to remove top cover , side cover and even switch from front panel.
    Was able to repair switch with epoxy glue and JB weld.
  4. #79
    Feb 2017
    Thanks for the heads up on the switch.
    I got the machine inside and covers off. It was wired with 6/4, I'm changing it back to 6/3 for my 50 amp plug. On the 6/3 wire I understand that red and black go to each side of the switch and white goes to the grounding terminal on the lower left side of the transformer. The previous owner had white going to the ground terminal and green going to the green wire off this thing on the top of the front panel. Not sure what it is, but the other 2 wire coming off it are grounds too. So it seem like some kind of common ground or suppressor? What do you think. He had the green wire wire on right in whoto) rigged to the green input, but it still has a ring terminal on it. The length and routing makes me think it should go to the grounding terminal on the side of the transformer. With the 6/3 wire and white going to the grounding terminal, I think it would be electrically correct. The wiring diagram doesn't seem to show it. Thanks.
    Lincoln SP 135 Plus
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Coal forge & anvil
  5. #80
    Southern Illinois
    The green to the ground lug on transformer connect the others to the switch and H1 and H2 should be connected to the switch for 230V operation. H3 should be isolated.
    That's the way we hook ours up
    Steve
    2015 Lincoln MP210
  6. #81
    Feb 2017
    Thanks Steve. That's what I have: H1 and H2 to the switch. H3 is unused, the end taped up. I'll run that green wire down to the terminal lug.
    Thanks for the quick reply!
    Lincoln SP 135 Plus
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Coal forge & anvil
  7. #82
    Southern Illinois
    No problem. You see the tension adjustment bolts and band? Don't mess with those
    Steve
    2015 Lincoln MP210
  8. #83
    Jan 2008
    Richmond, Virginia
    That other tin can is an HF bypass cap, in case you want to use a high frequency box with the welder.
    Attachment 1716881
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
  9. #84
    Feb 2017
    I saw those bands, but heeded your advice.
    It's all rewired, cleaned, lubed, reassembled and tested - works like a champ. Thanks to all of you who offered advice and guidance. It was a long trip to get it and I paid a decent price, but it's one heck of a welder and I'm sure it will out last me. It think it looks right at home under my welding table.
    Mission Accomplished!
    Lincoln SP 135 Plus
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Coal forge & anvil
  10. #85
    Southern Illinois
    Looks great in its forever home ! Enjoy it
    Steve
    2015 Lincoln MP210
  11. #86
    Mar 2005
    Under a Rock
    Looks great.
    yeah,what Olden said... thats a hi freq. bypass installed. (Lincoln T-12246)
    Miller 211/Spoolmate 100
    1961 Lincoln Idealarc 250
    Hypertherm PM 45
    Lincoln SP125 plus
    HTP 221
    Chicom spot welder
  12. #87
    Feb 2017
    Thanks guys. I don't expect to add TIG to this, but good to know.
    Are there any kind of rubber covers that can be but on the cable mounting studs? Being a safety engineer by trade, these exposed terminal studs worry me a little. Standing in front of the welder with damp trousers could be unpleasant. It seems lke rubber covers like those that cover batter terminals on car batteries might be a good idea.
    Lincoln SP 135 Plus
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Coal forge & anvil
  13. #88
    Southern Illinois
    https://www.ebay.com/itm/362046088657
    Look around for best price
    Steve
    2015 Lincoln MP210
  14. #89
    Mar 2005
    Under a Rock
    Meh...
    Don't be such a worry wart
    But actually a quick look through my junk drawer I found two of these...
    I think they are caps for a home heating oil burner nozzle.
    Hypertherm PM 45
    Lincoln SP125 plus
    HTP 221
    Chicom spot welder
  15. #90
    Feb 2017
    Its the safety engineer in me...
    Those little plastic caps seem like a simple solution, so long as they stay in place. I did a quick Google search, and there seems to be plenty to choose from. I'll check the auto parts stores.
    Lincoln SP 135 Plus
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Coal forge & anvil
  16. #91
    Southern Illinois
    You really don't have to overthink everything but if it makes you happy, knock yourself out!
    Steve
    2015 Lincoln MP210
  17. #92
    Feb 2017
    I just went and dug around my electrical junk box and found a couple distributor wire rubber boots. They fit snuggly onto the terminals - problem solved.
    Lincoln SP 135 Plus
    AHP AlphaTIG 200
    Viper Cut 30 Plasma
    Coal forge & anvil
