Magnetic valve for square wave tig 275
Results 1 to 6 of 6
    Jan 2010
    norway
    Could Someone please help me with a magnetic valve for my square wave tig 275?
    I live in Norway and the Norwegian importer says its out of stock and is impossible to get..
    Cluj-Napoca, Romania
    Re: Magnetic valve for square wave tig 275
    Sorry to hear that. Does he recommend no other distributors?
    Mar 2015
    Milwaukee, WI
    That looks like a common gas "solenoid valve" with a 120VAC coil. Something like this would work:
    https://www.amazon.com/Electric-Sole.../dp/B00DQ1ACQ2
    (You could also get one with a lower voltage AC (12V or 24V) coil to work, but you'd have to add a small step-down transformer.)
    Dec 2014
    Wasilla, Alaska
    What Denis said, also, there must be a "magnetic switch" in a distribution warehouse, or large Lincoln dealer somewhere, or, a parts machine that has one. Perhaps one of our readers can help? Don't give up, Good luck!
    Dec 2015
    Yeah,
    You don't need the Lincoln part. Solenoids are cheap and easy to match up to the Lincoln one, as the Amazon listing above shows.
    I mean, I recently put a new gas solenoid in a TIG unit of mine just because I preferred it having more standard sized pipe threads to more easily fit it up with a quick-disconnect fitting.
    So, please do let us all see the one you get.
    Peace to you all,
    Christian Livingstone
    www.youtube.com/newjerusalemtimes
    Everlast 210EXT AC/DC (2015)
    CAT250D 200 amp DC TIG/Stick/Plasma
    Jan 2010
    norway
    I bought the one in the link above, and it works great.
    Thanks for the help guys
