305D auto idle
Results 1 to 4 of 4
Thread: 305D auto idle
    Jun 2017
    South eastern Sask
    305D auto idle
    My 305D auto idle seems to have crapped out on me and won't idle down after welding for a bit. If you pop the side cover off the machine you can manually idle it down by pushing the throttle. The solenoid that controls the idle will then rev it back up to weld again when you need to. Anyone have any ideas were to look to get it fixed? Thanks all.
    Lincoln Mig Pak 140
    Lincoln Ranger 305D
    Victor Torches
    Visalia, CA
    Re: 305D auto idle
    new solenoid?
    old lincolns were powered (working) to get you to low idle, and wanted to high idle without electrocity. so any fault in the electrical system or solenoid would kick you to high idle so you could work still.
    check voltage coming into the solenoid and chase the issue from there
    bosses stuff:
    trailblazer 325
    maxstar 200
    my stuff:
    sa 200
    fronius transpocket 180
    100 amp Lincoln w/f
    97 f350 DIT
    Kevin
    Mar 2017
    DutchessCo. NY
    Re: 305D auto idle
    I have a 305g at work that would constantly hunt-idle up then come back down and repeat this constantly making the machine useless to weld with. I took all the skins off and with the engine off found that the plunger in the solenoid housing was binding. I blew it out and sprayed WD40 in it. operated it manually with the engine off and binding -sticking all freed up. Now it works like new. Maybe that's it-maybe not. It worked for me this time.
    Jun 2017
    South eastern Sask
    Re: 305D auto idle
    Quote Originally Posted by Weldboy View Post
    Thanks for the help guys! Turned out mine must of been dirty too. A cleaning and shot of penetrating oil and its working for now
    Lincoln Mig Pak 140
    Lincoln Ranger 305D
    Victor Torches
