Help, craters at end of weld
Results 1 to 6 of 6
    I just picked up a Lincoln 88 amp flux cored MIG welder two weeks ago and have been practicing in my spare time. I'm trying to weld steel square tubing but am having trouble with sort of craters where I stop the weld at. Any suggestions on how to prevent of remedy this? Also any comments on my welds overall are appreciated as I am a novice trying to teach myself. Also there is no surface prep at all so these wont be perfect welds by any stretch.
    Mar 2005
    Under a Rock
    Re: Help, craters at end of weld
    I have little experience flux core , but solid wire.. after you get done running the bead... stop.. then instantly light up again and drop a dollop/spot weld...
    seems to do the trick.
    I do the same for tig... /-= shrinkage
    Miller 211/Spoolmate 100
    1961 Lincoln Idealarc 250
    Hypertherm PM 45
    Lincoln SP125 plus
    HTP 221
    Chicom spot welder
    May 2010
    Port Orchard, WA.
    I’m just a hobby welder my self. What I do when getting ready to stop. Is close up the stick out length, and back up just a touch to fill in the crater.
    Don’t pay any attention to me
    I’m just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Nov 2012
    when you get to the end make a circle and double back maybe 1/4 inch then go to the end of the joint again or just make a circle or 2. you have to try and see what works best for each joint. the bead shape is not bad but your voltage might be a little high or you wire is too slow, you have to fine tune those also. it just takes practice.
    what size and brand of wire is it?
    what kind of machine are you using?
    May 2011
    Andover, Ohio
    Welcome to the forum.
    Lincoln A/C 225
    Everlast P/A 200
    Jul 2017
    Backing off the gun, longer stickout while welding, cools a mig do to higher resistence in the hot wire. I believe innershield is the same as mig in this respect. Also you should have a drag angle not a push like mig. Increasing the angle will also cool the weld as you finish the weld.
