Weld Pak 175HD knob removal....
Results 1 to 6 of 6
    Mar 2009
    Anyone know how to get this knob off? The wire speed was an allen set. This one on the voltage adjustment is just a flat slot. I can see the end of the shaft but nothing to push to release.
    I'm certain my favorite BFH will get it off but was hoping someone has been here done this before.
    Attachment 1711531
    MS
    Re: Weld Pak 175HD knob removal....
    Your image did not show up on Tapatalk Pipeliner.
    The only constant in life is that there are never enough chains
    The only constant in life is there is never enough chains
    Mar 2009
    Mar 2009
    Ended up not having to remove it. But I'd still like to know how it comes off. You know, in case I get bored one day and just want to take it off for fun.
    MS
    Have you tried shining a light down in the hole that is showing on the picture, the one 180 degrees from the pointer? I wonder if there is a spring clip or something.
    Mar 2009
    Yeah I could see the end of the shaft but nothing else I could see.
