Lincoln ranger 225 and ranger 8 no power or welding output
Results 1 to 13 of 13
    Here are the code #s off the machines K2857-1 11597 and K1419-4 11151. Have done most of the troubleshooting checks and I am not getting the 37 to 46 VDC at the brush holders on either machine any ideas on where I need to go from here maybe new boards? Thanks in advance!
    May 2008
    Orange, TX
    Re: Lincoln ranger 225 and ranger 8 no power or welding output
    Are you getting battery voltage at the slip rings?
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save 2nd Base!
    getting it to the board but not at slip rings
    May 2008
    Orange, TX
    FYI, the Code# 11151 is a Ranger 10,000 not a Ranger 8.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save 2nd Base!
    Okay thanks part of the decal is missing off of that unit!
    May 2008
    Orange, TX
    Locate flashing diode D9 and resistors R4 & R5 on the control board and check them for being open. Diode D9 would be suspect first and then the two resistors.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save 2nd Base!
    May 2008
    Orange, TX
    Quote Originally Posted by MarkKzumwalt View Post
    It's important as the control board in the Ranger 8 is different from that common to the 225 and 10,000.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save 2nd Base!
    May 2008
    Orange, TX
    The board may be fully encapsulated in which case it's non-repairable.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save 2nd Base!
    Yes the boards are fully encapsulated. Thanks for the info! Do you know of where to get these boards from and our part #?
    Mar 2014
    I think Duane may be dealing with Harvey today so I'll chime in. The 2 code numbers show to use the same control board, p/n 9SL12198-1. Any authorized Lincoln distributor should be able to get it. I looked on ebay but didn't see anything. 357 bucks
    Thanks for the p/n yes they both look the same.
    Thanks for the help and info! Got a new circuit board and installed on the 225 and it fixed the problems!
    Mar 2014
    Glad to hear. Thanks for reporting back with results.
