Miller Bobcat 225NT issues
Results 1 to 8 of 8
    Jan 2017
    Houston Texas
    Hello,
    I have a Miller Bobcat 225NT that I have owned for about 5 years, the last 2 or so I had it lent to a friend to do some repairs at his church (welding down grates and what not to prevent theft from metal mites) and I just got it back 3 weeks ago to go down to my moms house in Rockport to run auxiliary power after the hurricane.
    When I got it back, the vacuum fuel pump had been replaced with an electric pump, there was no auxiliary or welding voltage and it would die at low idle/takes for ever to stop running when moved to the off position.
    The electric pump was wired in off the main switch and it only pumps in the start, high idle and high/low idle. Wire is just wrapped around a terminal.
    For the lack of voltage I didn't have much time to take many diagnostic readings before leaving to go down from Houston to Rockport, so I started cleaning all of the electrical connections and slip rings. Fuse 1 is good. I did not confirm fuse 2 was good or not.
    I was able to get auxiliary voltage back (120 and 240) and had 55 volts of OCV at the welding lugs (did not strike an arc to test and I don't remember what the selector switch was on, but it was filthy in there) and it ran over 24 hours providing auxiliary power down there while patching roofs, clearing downed trees and cleaning up.
    Things are settling down and I would like to sort out the idle/stop issue and fuel pump.
    Serial number KH357108
    Stock number 903517
    Kohler engine
    Machine has 24XX hours on it
    The idle issue is the low idle, it will slowly come down in engine speed and then die (no loads being applied). The solenoid appears to be moving while it is running.
    These pictures are taken with the air cleaner assembly removed.
Size:  112.7 KBName:  IMG_2180[1].jpg
    The stop issue is when the start switch is moved to off, it takes at least 30 seconds to go from high idle to off. It does go through the cycle of speeding up right before shutting off. This is much longer then I ever remember.
    Would both of these functions be controlled by PC1?
    For the fuel pump this is where I should tie into it correct?
    Thanks and this forum has been a great resource.
    Peter
    Mar 2009
    Re: Miller Bobcat 225NT issues
    Why even fool with the electric pump? Yank all that junk off and figure out why the vacuum operated pump (supposedly) stopped working in the first place.
    And no "friend" of mine would ever use this welder again and sure as heck wouldn't have backyard engineered it to begin with.
    Feb 2005
    Louisiana
    This!
    Jan 2017
    Houston Texas
    I am not upset about the change, he meant well. What would happen with the vacuum pump is it would dry out from lack of use and you either had to crank forever or dribble some gas down into the line from the carburetor end to prime it. The vacuum pump is gone so I would have to purchase that, its probably cheap, but the I believe the easier task is a proper electrical connection at this point, unless of course this is the source of the machine not shutting down properly.
    Thanks,
    Peter
    Apr 2017
    Electric fuel pumps have different pressures and volumes ,the engine on your Bobcat works on very low fuel pressure.
    The Bobcat had a electric fuel pump option however the pump used has rated for the engine used. Not just any electric fuel pump will work without flooding or a host of other problems.
    Really the pulse pump is your best option , yes if it sets it takes a little longer to push fuel but over all its your best option.
    Electric fuel pumps on welders need to be set up as to not pump fuel when the ignition is on but engine off, I have seen engine drive fires because of this.
    Some are set up to pump fuel during starting and then switch to a engine normally open oil pressure switch to remain energized when engine running.
    Regardless of what PC-1 is doing your engine drive should shut off the minute you turn the ign switch (S-2) to the off position.
    It should never continue to run after S-1 is switched to the off position.
    You need to check for anything that is back feeding power or any wiring changes that may have been made however I tend to think you may have a problem with S-2 sticking maybe???
    Bemidji MN
    Quote Originally Posted by Dana gear View Post
    Mine cranks for quite a while after sitting for a few weeks. Was wondering if that was normal or a sign the pump was going.
    Airco 300 - Syncro 350
    Jan 2017
    Houston Texas
    Dana Gear,
    The electric pump on it states 4 PSI from memory, I'll check it.
    I agree on the wiring you only want it on when the engine is running.
    I went a head and ordered a pulse pump it was sub $10.
    Have you ever heard of a check valve being placed before a pulse pump to keep it primed?
    Thanks for the input.
    Peter
    On the S-2 sticking, I'll pull it off and see if it continues to feed power when it is rotated through the different positions.
    Apr 2017
    4 psi would be the maximum pressure for that carburetor to see in operation.
    Yes I have seen check valves however its not that fuel is reverse flowing generally after sitting for a week or so the fuel evaps in the carb another area fuel is lost is when the engine dive bounces around a lot like on a trailer on a bad road ,fuel can actually slosh out into the intake manifold a little.
    Honda had a problem with this on engines used on service trucks, mostly air compressors and recommended that you turn off the fuel and let the engine die as fuel was sloshing into the cylinder and washing off the oil on the cylinder wall and in turn passing the rings and into the crankcase, overtime the engine oil would be diluted by fuel.
    Most all pulse pumps require a little cranking action after setting for a time and no this is not a indicator of a bad pump, they did it when they were new.
