Esab MIG 4HD with spool gun
Results 1 to 17 of 17
Hybrid View
    Sep 2017
    I have a chance to get 2 452CVCC welders with the MIG 4HD wire feeders for a steel of a deal. Would it be possible to put a spool gun on the MIG 4HD wire feeder? Or does it take a completely different part to run a spool gun?
    Thanks in advance.
    (yes, I have 3 phase power available)
    Jan 2005
    Re: Esab MIG 4HD with spool gun
    The 4hd is setup for optional push/pull gun.. It will take a MIg 28 control for ST-23 spool-gun.. if that's what you have?
    Esab 2200i-TA34
    Klutch 220si
    Klutch 140si
    Thermal Arc Pee-Wee 85s
    Thermal Dynamics 38XL-SL-40
    Victor 82 (A-60)
    Hypertherm 45XP
    Jul 2016
    Midwest
    Quote Originally Posted by amosfella View Post
    Thanks in advance.
    If you don't already have a spoolgun, You can buy for instance, Tweco Eliminator with a control box. It would fit most all power supplies. It's about $1200 worth but if you want a top quality spool gun for that machine, that's where you would be new. If you don't have a spool gun already i have one of the Eliminator units for sale cheap ( demo unit). Or many other guns would be adaptable. The internet is full of them.
    Sep 2017
    I don't currently have a spoolgun or a control box. before I started looking at the Esab, I was looking how to attach a control box to a Miller regency 250. I haven't been able to find the right parts up till this point. I've been looking for a control box that allows spot/stitch timing, gas pre and post flow, etc. And I've been trying to figure out how to do that as inexpensively as possible, as right now I only have 2 medium sized projects that I'd require it for.
    Even now, I don't really want to mess with wiring. But in the end, if I have to, I guess...
    Jul 2016
    Midwest
    You probably wont find anything with spot and stitch but the Tweco box has pre and post flow I believe
    Sep 2017
    I'm thinking I'll go look tomorrow. Anything specific to look for on them?
    Sep 2017
    So, i had a look today. One welder was a 452 cvcc, and the other was a svi 450i cvcc. Both with mig 4hd feeders. Both looked to weld very nice. Are they worth $600 cad for the pair?
    Jul 2016
    Midwest
    Both were solid in their day. i remember selling a lot of SVI 450i units because of their size. Only real issue ever was a fan or two would go out. They had 2 fans in the back. 452's were common production machines where i lived and many are are still on the job. Not sure if ESAB or L-tec back then actually made those machines but they were good. 4HD was solid too. I owned a few of them in my travels. As far as value, I'd say 600 cad should be a deal. The feeders are worth that but it all depends on how they look under the hood. 3ph is always worth about 1/2 of 1ph for some reason.
    Sep 2017
    Only thing i could see wrong was the 450 didn't have a working bolt/amp meter screen. Is that part hard to come by? The one wire feeders has a bit of a beat up cover. Both are esab branded. Would the wire feeder and spool gun you offered work on both? Welding electronics aren't my strong suit, and it rather not take a zap to find out...
    Jul 2016
    Midwest
    The 450 had digital readout. I doubt you will find the meter unless you call around to repair stations and ask for a used one. I know a few you could call in the states I would run this stuff through all of the motions before buying. Damage is a bad sign. Spoolgun with control box works on any CV power supply.
    Sep 2017
    ok. I saw them being welded with. As I said, did a nice job an 3/8". Maybe one could get a compatable volt/amp readout on digikey. Only the cover on the one feeder was damaged. The internals looked just fine, and seemed to work just fine. To me, a cover isn't a big deal. I saw in the one power supply manual that tig was also an option on these machines. Are the pieces to make that a reality with a high frequency start, etc., available??
    Jul 2016
    Midwest
    Just guessing that for tig, Both would be scratch start. Not sure ESAB had an HF box for start or other..May not turn down low enough to do thin material. The SVI would be my choice for tig. Nice thing about welders is they either work or they don't.
    Jan 2005
    The 350 MPI would be my pick for a tig machine. The Esab high voltage box worked excellent with it.. No high freq.. but jumps a arc mile.. It's a full feature dc tig setup..(other then pulse) I would think the SVI 450i would be lift-arc?
    Esab 2200i-TA34
    Klutch 220si
    Klutch 140si
    Victor 82 (A-60)
    Hypertherm 45XP
    A full featured WC115 miller control box does have most of what you want. it drives the spoolmatic 15A or 30A.
    It can control a welder that uses 115 volt, 24 volt contactors. also can be wired for simple contact closure,
    Sep 2017
    Bought the esabs. Look good so far... Got to get plugs for the welder and generator.
    Jul 2016
    Midwest
    If you ever need any feeder parts I can hook you up with a repair guy who has a lot of ESAB parts from L-Tec on up.
    Sep 2017
    I was wondering if anyone knew where I could get a pulse controller for the svi 450i?? Or if someone had a good one for sale?
