First TIG welds in Aluminum, feedback please
Results 1 to 5 of 5
    Mar 2016
    Phoenix, AZ
    Today was my first day welding aluminum. I have very little TIG experience - mostly MIG with some stick and some Oxy/Acetylene brazing.
    I tried on some C channel, about 3/32" thick, 1" x 1/2", and the results were horrible - like, break the internet horrible, so I cut some scrap 1/8" aluminum into 5" x 5" squares and tried some practice beads. Here is my result.
    I was using 3/32" 2% Lanthanated Tungsten, 3/32 ER4043 filler, and about 110 amps. I was using a #7 cup, with about 15cfh on the argon (100% argon).
    I left space between each pass, so the first passes are the odd rows, and my 2nd attempt is the even rows. Between the two passes I quenched and wire brushed.
    I figure I have at least a hundred more of these before I can do anything with decent consistency, so I'd appreciate any specific feedback. That last pass, I was running low on filler rod and tried to use too short of piece and things got ugly.
    Thanks
    Lee
    Re: First TIG welds in Aluminum, feedback please
    Those look good for a first day alright.
    I think you're ready for some joints, which is where welding begins, i.e., joining pieces.
    Peace to you all,
    Christian Livingstone
    www.youtube.com/newjerusalemtimes
    Everlast 210EXT AC/DC (2015)
    CAT250D 200 amp DC TIG/Stick/Plasma
    You were clearly overheating the plate on your second pass. Allow the base metal to cool a bit every 3rd or 4th bead. Just a minute ormtwo of cooling. Grind your tungsten or change to a fresh one imediately after you dip it into the aluminum. Dont forget to fill the craters at the end of the weld bead.
    Hobart Handler 190
    Syncrowave 250
    Purox Metalmaster
    You are off to a good start. Taper off your arc at the end while circling the torch some to reduce the crater in the end.
    PDX Pacific NW
    Looks really good for 4043. Try starting with 150 amps. Then back of as need after u get going. Somtimes 1/8" aluminum takes over 240 amps depending on the joint setup and mass of the part.
