Sa200
Results 1 to 20 of 20
Thread: Sa200
    Mar 2013
    Sa200
    Hey all, I have a question for the pros. I have a mid 70's blackface and a 60's red face that burn 7018 well on a low dial setting but won't burn 6010 properly on low on the rheostat but set above 50 welds smooth and above 70 perfect. If I set the dial to 30 or lower it will weld 6010 rod for about 5 seconds then the arc starts cutting out. But if I drive the rod in it'll weld smooth. Anything that would cause the arc to break when its long arced a bit? OCV is set 91 on one machine and 93 on another.
    Dec 2016
    Re: Sa200
    Commutators need cleaned to make a better connection?
    Mar 2013
    Re: Sa200
    I cleaned them. I have 38 ohms off the blue and brown wires out of the barrel.
    Mar 2013
    Re: Sa200
    I changed the remote switch changed out the rheostat and still the same thing
    Mar 2014
    Re: Sa200
    Xxxxxxxxx
    Port Orchard, WA.
    Re: Sa200
    Is it possible your 6010 has dried out? Dip your 6010 in water, and let air dry for 24-hours.
    Don’t pay any attention to me
    I’m just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Visalia, CA
    Re: Sa200
    Quote Originally Posted by Allstar_pipeliner View Post
    i could be wrong, but, when you set your rheo that low, you are not only reducing current, but voltage too. from what i gather, 6010 needs some real ocv to be able to run properly, especially to long arc like you said. i have found with my machine that general pipe welding is easiestly done in the correct gear to run between 40 and 70 on the rheo.
    bosses stuff:
    trailblazer 325
    maxstar 200
    my stuff:
    sa 200
    fronius transpocket 180
    100 amp Lincoln w/f
    97 f350 DIT
    Kevin
    Mar 2013
    Re: Sa200
    Dipped the rods in water same thing new tins same thing tried the rods on another welder at 30 on the rheostat and welded like a dream. I put in new post new leads new stinger and ground new rheostat and burned a couple 3/16 and fell to see if anything was warm or hot and nothing. It's not even a smooth arc at 40 it's got to be 50 and higher.
    Mar 2013
    Re: Sa200
    It'll blow a hole through 3/8 plate with 3/16 on 4th and 80 but won't run a smooth bead with 3/32 on 4th and 25
    ROCKVILLE ,,VA
    Re: Sa200
    Did you install new brushes? Or old brushes not seated good,,, just woke my machine from long restore sleep it break arc after pulling rod off the pipe about 3/16" so pour water on brushes while running for few seconds ,then put her in hi gear and 100% fine let bark on 1/4" 7024 about (2)rods, re clean commutator with stone , went back to old setting ,can tease her now! Can pull arc off real slow about 1"1/4 she still wants weld! So make sure brushes are seated all way across
    Mar 2013
    Re: Sa200
    The brushes had good life yet and moved up and down smoothly but I did roll the rack recently to drop the ocv because it was a bit higher than I like. I welded for awhile after to seat them. Could it be that simple that the brushes need a bit more. I am ready to skip breakfast and run out and give it a try.
    Jun 2015
    Alaska born, Alaska bred
    Re: Sa200
    Every Lincoln welder I've ever run, the arc force was adjusted via the fine current. Low fine current has a smooth arc good for low-hy, and high fine current has an aggressive arc good for cellulose rod.
    Based on my experience, I would venture to say you aren't experiencing anything unusual.
    2000 Lincoln SA-250
    1974 Miller Dial-Arc 250
    Mar 2013
    Re: Sa200
    Ok I did a wet seating for the brushes and now I'm getting a spark off the commutator stone on one side of the brushes but not the other. Is it maybe still wet and arcing out? I've never seen sparks off a commutator stone.
    Re: Sa200
    The arcing could be a result of jacking with the rack. It can have that effect.
    Plus by dropping the OCV you also decreased the arc voltage which can cause the arc to snuff out. I'd be willing to bet your OCVs are dropping below 90 after burning rod for an hour or so to warm the generator a bit.
    I'd suggest putting the rack back to factory and use the Coarse Range and Fine Voltage "Shield-Arc" controls as designed.
    Save 2nd Base!
    Mar 2013
    Re: Sa200
    It was 94-94.5 cold and dropped to around 92 when I ran it for an hour. What do you usually set yours to Duane?
    Re: Sa200
    98-100V cold is not unusual.
    OCV and Other Specs.pdfOCV and Other Specs.pdf
    Note the "Long Test" procedure description.
    Save 2nd Base!
    Mar 2013
    Re: Sa200
    Thanks for the info. I was thinking of trading out the brushes with the dual wire brushes. Anything good or bad about them.
    Re: Sa200
    Smoke-n-mirrors IMO.
    Save 2nd Base!
    Mar 2013
    Re: Sa200
    Ok I was swapped an engine on another welder and it was doing the same thing. I checked the engine rpm and it was low so I brought it upto 1550 and it smartened right up and welds like a dream OCV is 94.5 and 131aux volts. I figured I'd play with the idle on my red face and turned upto 1570 and it welds smooth too but I have my OCV set to 95 but my aux is 137. If I dropped my idle down to 1520 my aux drops to 131-132 but rod starts cutting out again on low rheostat settings. Is there any way to keep rpms up but drop aux volts?
    Mar 2013
    Re: Sa200
    Nevermind I switched out a different exciter and it's at 129 now
