Welding square tubing together
Page 1 of 4 123 ... LastLast
Results 1 to 25 of 95
    Jan 2017
    Charlotte NC
    I️ was just wondering how one would weld together to square tubes that fit inside each other with about .03” clearance between them on each side. The large tube is 2” x .187 wall and the smaller tube is 1.58” x .12” wall. SMAW process and has to be as strong a weld as possible. This is not for a functional part but let’s say it will be used to reduce a trailer hitch receiver.
    Lincoln Pro MIG 180T
    Alpha Tig 200X (2016)
    Miller Maxstar 161S
    Re: Welding square tubing together
    Quote Originally Posted by davezelonis View Post
    I would weld it 6011/6010
    as far as non functional/trailer hitch .... one of these things is not like the other...
    Miller 211/Spoolmate 100
    Lincoln SP125 plus
    Chicom spot welder
    more experience will be here soon.... hang tight.
    Lincoln SP125 plus
    Chicom spot welder
    Jan 2017
    Charlotte NC
    Thanks, it is not going to be anything I️ just wanted to know what size fillet you would put in there. One run with 6010 1/8 rod? Three passes with 7018 3/32 rod. Etc...
    Miller Maxstar 161S
    Jan 2006
    In A Nice Comfy Chair
    Do front and back (If ya can get to the back) all the way around and do not stop on a corner.
    No biggie....
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
    As stated or just drill and use receiver pin.
    Jan 2017
    Charlotte NC
    Quote Originally Posted by zapster View Post
    No biggie....
    ...zap!
    Thanks Zap, that’s what I was looking for.
    Miller Maxstar 161S
    Not there
    I ALWAYS splice like that if I use tube in tube or a few stick of 3/16 or 1/4" flat bar ? I dunno. I'm old, but what can it hurt ?
    The MIG also gets pulled to the side( nearly always---especially if it will be on the road) and the Excalibur comes out. I dunno. My mentor did so/ so do I.
    Fill that gap !
    PDX Pacific NW
    What's wrong with stoping on a corner?
    PDX Pacific NW
    I'm wondering if the piece is supposed to slide in there and your worried about it warping and binding up
    Jan 2017
    Charlotte NC
    Not worried. I️t was just a hypothetical question on the best way to fuse these two tubes together for maximum strength just in case I️ decide to use this joint under load.
    Miller Maxstar 161S
    PDX Pacific NW
    Ok I figured you were welding the outside tube to somthing and needed the inside tube to be able to slide. I would just use my tig and use about 160 amps or more and 3/32 rod with 1/8 tungsten and weld it up. U don't need to worry about a tiny gap. It will give u more penetration that way anyway. Just grind the milscale first and that piece will weld very nice with tig
    Jan 2017
    Charlotte NC
    Thank you. So you would TIG it instead of STICK.?
    Miller Maxstar 161S
    PDX Pacific NW
    Ya becuase I don't stick weld. Penetration is similar tho with stick and tig I think at least from cep's etch tests I've seen. His mig is another story. Another way to get better pentration would be to bevel the outside tube some
    Jan 2017
    Charlotte NC
    Thanks Again, I️ think I️ have a better idea now on how to get a good sound weld in between those two tubes.
    Miller Maxstar 161S
    PDX Pacific NW
    Your welcome. Just don't forget to grind the scale with a black grinding stone on your grinder. Everywhere within 1/4" of the weld so it welds nice and clean if you wanna tig it
    Jan 2017
    Charlotte NC
    Yep, TIG=clean, bright, metal.
    Miller Maxstar 161S
    Northern Cal., Shasta County
    I generally throw in a couple of plug welds on something like that if there's enough distance. Re-inforcement that doesn't occupy space.
    Jan 2017
    Charlotte NC
    Quote Originally Posted by Sandy View Post
    Very good idea Sandy!
    Miller Maxstar 161S
    Gasoline Alley, SoCal
    My experience:
    TIG is the most reliable strength wise. It’s a slow process.
    Stick 6011 is a close second.
    Flux core wire uphill is also very good.
    I don’t know what your application is, but I could feel confident with any of these methods on that lap joint.
    Jun 2013
    Okay guys here goes... Never use a cell rod (6010, 6011) on a dynamically loaded structure. It will break sooner or later. A trailer hitch is dynamically loaded. With SMAW low hydrogen is the ONLY way to go.
    piece of soapstone
    tape measure
    chipping hammer (wire handle type)
    PDX Pacific NW
    Johnt's badasness will make that rod work. ^^
    Outside of Raleigh, NC
    My thoughts as well.
    Miller Trailblazer Pro 350D
    Miller Suitcase MIG
    Miller Spectrum 2050
    Lincoln 210MP
    Jul 2017
    Any contrary advice on using Oxy Acetylene Brazing (bronze, "weldo-brazing is may be the name) ?
  25. #25
    Western New York State, USA
    Quote Originally Posted by Blackslacks View Post
    normally i would use 3/32 7018 and have it welded in less than 2 minutes. there is nothing wrong with 6010/6011 as long as weld has enough, big enough to safely hold load preferably over 400% what is required. i have welded literally over 1000 tons and the over 100 tons welded with 6010 never broke as long as it was more than a small tack weld.
    safety factor of at least 400% more than required is fairly standard. if you got a weld say 0.5 square inches able to hold 30,000 or 15 tons than in general as long as load under 4 tons it will hold. when you get down to 1.5 tons on a weld able to hold 15 tons it will not break. at least i never had any break
    for example water and steam pipes welded with 6010 taking pressure fluctuations every day i dont see any pipe welds done with 6010 failing. everyday a lot of critical pipe welded with 6010 without any problems even decades later. most professional welders using 6010 everyday with no problems would laugh at you for saying 6010 welds will break.
