Check my math
Results 1 to 25 of 26
Thread: Check my math
    Check my math
    Minnesota Dave, and anyone else;
    Is my math correct?
    We express roof pitches as 6:12, 3:12 12:12 For 12' measured horizontal, how much rise, or fall?
    We express grades as % A 10% grade falls away 10' in 100' of horizontal.
    Both of these are ratios. We can convert.
    Also inclines are expressed in degrees. We can measure an angle, in this case deviation from horizontal with a protractor, but how do we turn that number into percent, or ratio?
    A circle 200 feet in diameter has a circumference of 200x Pie, or 3.1416, or 628.32 feet. As a circle has 360 degrees, each degree is 628.32/360 or 1.7453333333333......
    Therefore, a 10% grade is 10x1.7453333333333333.......or a 17.4533333333... degree angle.
    A circle 24' in diameter has a circumference of 24x3.1416 or 75.3984' As this circle is also 360 degrees, we can divide. 75.3984/360= .20944. therefore a 6:12 pitch is 6/.20944=28.6478 degrees.
    I have a new phone. It tells me the angle as a deviation from level. I always need it expressed as ratio, or percent for it to make sense to me.
    I understand this won't work very accurately as my units of measure are circular, and these measurements need to be straight.
    What is the proper way to convert?
    Willie
    N 48° 38.680 W 080° 40.837
    Re: Check my math
    Willie,
    The math you are doing gives you the length of an arc. If you are looking for the rise of a 10% grade at a distance of two hundred feet it's 10% of 200. What are you trying to calculate? Maybe I'm reading it wrong, but it looks like you are trying to calculate the vertical rise from horizontal at the intersection of that vertical line and a 10 degree arc angle? I think to do that you will have to resort to the old school angle calc's with a sine/cosine table?
    Maybe I'm just confused.
    Re: Check my math
    Alternatively you could calc the long side of a 10% triangle with a base (horizontal run) of 200' and a rise of 20' :
    20x20 = 400. and 200 x 200 = 40000. and 400 + 40000 = 40400. Square root = 200.9975'
    Then do a ratio of long side to rise for a radius of 200' :
    200 / 200.99751 = .99503 and ... 20 x .99503 = 19.9007'
    So, if my guess at the math is correct the rise of a 10% rise arc angle for a 200' radius is 19.9007'
    Clear like frikkn mud ...
    Re: Check my math
    Willie
    This part is incorrect.
    A 10% grade is a 5.71 degree angle (also a 1.2 pitch roof is 5.71 degrees)
    100% grade would be 45 degrees
    When you took your 10x1.7453 from your example, it's still a 10 degree angle.
    Sep 2008
    Re: Check my math
    Willie
    You are trying to convert a ratio into an angle and can't do it the way you are attempting to with your use of a circle. What a roof ratio of say 3/12 or 6/12 is in trigonometric terms is the tangent of an angle- or rise over run. If you take a calculator and divide 3 by 12 and take that answer hit the inverse function key- and then the tangent key-you'll get 18.43 degrees. So if you had a slope of 10% that is telling you for a rise of 1 you go out out a ratio of ten. Or again 1 divided by 10 take the inverse tangent of that and get 5.73 degrees. So a 10% slope equals almost 6 degrees.
    So if you are holding your phone and it tells you the angle- take the calculator function and enter that angle in degrees and hit the Tangent key -it gives you a value- lets use 45 degrees the tangent is 1 so that is saying for every 1 value UP- you also moved out 1 value which is what a 45 degree angle is one inch or one mile up to one inch or one mile of run produces an angle equal to 45 degrees.
    If you are with me so far- let's assume that you tilt the phone and the new angle is 30 degrees- go to the calculator and put in 30 and hit tangent- it comes back as 0.58 if you decide you want to know how far UP that 30 degree angle would be, you pick a distance let's use 10 feet-since it makes the math simple- 10 x .58 =5.8 feet- so your rise is 5.8 feet over a run of 10. You can also do it the other way-you know that you are 5.8 feet high- and want to how far from that point on a wall you would have to go out to give you an angle of 30 degrees 5.8 feet divided by .58 equals ten which again is saying a ratio of 5.8/10
    Hope this makes sense if not will give it another shot.
    Re: Check my math
    Quote Originally Posted by John Bartley View Post
    Willie,
    Hills are expressed as percent grade. A 10% grade is 10' of rise per 100' of horizontal run. In my attempts to calculate grade in percent, i was imagining 10' as a portion of the circumference of a circle 100' in radius. A 100' radius circle would be 628.32feet in circumference. Each increment of one degree or 1/360 of its circumference is 1.74533333333'. a 17 degree tilt would be approximately 29.67 feet of rise per 100' of run, or 29.67% grade.
    My son suggests that a 45 degree angle would be 100%, or 12/12 as roofs are described. Divide the angle by 45. 17/45 is 37.777%. I believe he is mistaken.
    Re: Check my math
    Yeah, I got it all wrong. A 17 degree angle is near 30% grade.
    Bemidji MN
    Re: Check my math
    I like a pencil and pictures
    Also, look at the trig table below (tangent only)
    The fraction 4/12 is 0.3333... which is between 18 and 19 degrees.
    The fraction 10/100 is 0.1000 which is between 5 and 6 degrees.
    The angle always corresponds with the fraction (written as a decimal).
    Name:  trig table tangent.jpg
    Name:  trig table.jpg
    Airco 300 - Syncro 350
    Re: Check my math
    Hmmm .... I think he's correct. A 45 degree angle is an equal rise and run.
    Re: Check my math
    I know he's not mistaken about the 100%, and 12/12 being 45 degrees. I just think his dividing the angle by 45 will not yield the correct answer in %.
    Re: Check my math
    Re: Check my math
    Bemidji MN
    Re: Check my math
    A little algebra (moving stuff around).
    The right hand column I just used the calculator.
    On the left I took the 4 digit number from the table.
    Basically a calculator is a fancy electronic trig table
    Re: Check my math
    I too like pencil & pictures now that my 11 year old military spec cell phone died. I'm starting to gain early proficiency with the camera on my new, already obsolete I phone 8. Does this make me a millennial?
    Bemidji MN
    Re: Check my math
    Here is a grade-angle chart you can use for checking your trig practice
    Name:  grade angle chart.jpg
    Bemidji MN
    Re: Check my math
    Using pencil and paper and then taking a pic is faster than typing anyway
    ...more understandable too - for me anyway
    Was my 17 degree explanation workable for you?
    Basically there are always 3 possible spots to write numbers. The angle, the numerator and the denominator.
    As long as you have 2 of them, the 3rd can always be found pretty quickly.
    Re: Check my math
    Thanks guys. I guess i should have failed high school math. ...........Then again, what teacher was going to risk having me in their class a second year?
    Willie
    Sep 2008
    Re: Check my math
    Here's a link to both an online calculator and the formula to convert % of slope to degrees of angle
    https://www.calcunation.com/calculat...conversion.php
    Re: Check my math
    Willie
    Hey Willie,
    I should probably say the same thing as you said above, but ..... every time I have to go to the web or a book to re-learn something I think to myself ... "how often do I use this stuff?" Its a wonder that we can even remember the math terms, never mind how to use them. I enjoyed this thread. It was a math refresher - thanks!
    Re: Check my math
    Mrs. B is a first grade teacher. I posed my math question to her. She was no help. She showed me the sort of math, and the sort of students she deals with.
    Bemidji MN
    Re: Check my math
    My students love kid snippets videos
    Jul 2016
    Re: Check my math
    Is my math correct?
    Willie
    Trig is where you should be
    Here it is standing: atoms with consciousness; matter with curiosity. Stands at the sea, wonders at wondering: I, a universe of atoms an atom in the universe. - Richard Feynman
    Re: Check my math
    Willie
    I have taken a lot of math in my life but it is just like everything else. Use it or lose it. I have forgotten way more math then I would like to admit.
    I play with sticks
    Trailblazer 325 EFI w/Excel Power
    LN-25 Pro
    Power Mig 210 MP
    Sep 2005
    Cave Creek AZ
    Re: Check my math
    This might help
  25. #25
    Dec 2009
    Re: Check my math
    Willie,
    If your phone gives you the angle from level in degrees, try this. If the angle is 17 degrees, enter 17 into a calculator then press TAN. Tan is "opposite over adjacent", but forget about that. Sounds like 11th grade trig class (I didn't like it much but took it twice anyway). Tan is really Rise over Run. This I can get my head around. Ok, 17 Enter, TAN, =.3057..., x 100= 30.57. So, 17 degrees drops or rises about 30 1/2 ft along 100 ft. Three strokes on a calculator.
