victor dc2400 pattern torch
Results 1 to 4 of 4
    earth
    nice shape. works as it should. $250.00. pick up only. upstate ny 12833Name:  SAM_2333.jpg
    l-tec 250hf plus Lincoln pro 135 zeny cut 50 plasma
    Mar 2015
    Re: victor dc2400 pattern torch
    sure wish i was closer to where you are. been looking for one of these.
    Nov 2017
    Clovis CA
    They work good
    I had one back the late 70's I would use wood pattern Note: I need to use a rubber band and paper clip to hold the knurled pin to the pattern
    Harbor freight170
    Victor Torch
    HF 4X6 band saw
    South Bend 9 Lathe
    HF Mill
    B&D Mag Drill
    Amazon books that may help
    Machinist Handbook
    Machinist Guide
    Single To Three Phase Simplified
    groups.yahoo.com/neo/groups/southbendlathe9/info
    Jun 2010
    northern cal.
    I used one in the late 1990's to split large sprockets halfway thru (from the bore) before welding on 2 piece, bolt together hubs. The drive wheel ran along a straight piece of heavy flat bar, overhead. Yeah, the setup was partly made by the shop. A great tool if you actually have a use for it.
