Is Delrin/acetal the best choice for this?
Results 1 to 14 of 14
    Mar 2006
    I'm looking to build a roll bender for 7/8" to 1" aluminum and stainless tube. Similar to the one included.
    I will probably make the dies out of plywood initially to test it out. To replace them, I was looking at using a piece of 3" round bar acetal. Will this work or will it be too slippery? Anything else that would work better? I'm thinking that with the pressure from the top roller, it will bite in enough to prevent slipping.
    Campbell Hausfeld Fluxcore 80
    Thermal Arc 185
    Millermatic 250
    JD Squared model 32 bender
    Mar 2007
    Lookout, West Virginia
    Re: Is Delrin/acetal the best choice for this?
    It will probably slip more on the SS than the AL, but as long as you aren't bending it too much with each pass, it might work. You can always just shove the tube through while the other hand turns the crank.
    Jan 2008
    Richmond, Virginia
    Aluminum dies for the geared rollers would have more grip.
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
    Jan 2011
    Hutchinson Kansas
    Gears would also work better than sprockets
    Mar 2006
    Both the aluminum (anodized) and stainless will be polished and have to avoid scratching it.
    Thermal Arc 185
    Millermatic 250
    Mar 2006
    Quote Originally Posted by propanehotrod View Post
    I think so too. I'm looking to try to find some. I think the reason for the sprockets is because the dies are slippery to give it double to bite.
    Thermal Arc 185
    Millermatic 250
    If not cost prohibitive, then you might consider dissecting a HF planetary ring roller. I suspect slipping will be more prevalent the tighter your radius. My small hf roller has no knurling left and only slips if I roll real tight.
    ct.
    Delrin is fairly slippery stuff.
    Maybe not so good where traction is necessary.
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
    Vintage-
    -South Bend 9in. lathe
    -South Bend 7in. shaper
    -Craftsman power hacksaw
    -FibreMetal 710
    -B&D mag drill
    Cheapo-
    - Chinese mill/drill
    Jan 2011
    W. Wisc
    What about a urethane or rubber coating on a steel wheel? You would get good grip and no-marring surface that way. Depends how serious you are about this. There are places that can coat rollers like this, but it will cost. I suspect Delrin or any plastic is going to be too slick.
    -Dave
    XMT304, 22A Feeder, HF251D Hi Freq box
    Would a small diameter wide rubber band in each roller help?
    Mar 2006
    Not a bad idea. I was thinking about gluing a piece of rubber on a plywood die initially to test it out.
    Thermal Arc 185
    Millermatic 250
    Mar 2006
    Definitely something I will look into when I get the design figured out. Thanks
    Thermal Arc 185
    Millermatic 250
    Cut a piece of truck inner tube and glue it to the rollers with something like 3M super weatherstrip adhesive. The tube will be thick enough to protect the surface and provide grip at the same time.
    Sent from my hammer and chisel using Tapatalk
    How does the roller in the photo perform?
