Tank Turning Rolls - Profax Tr5000
Results 1 to 12 of 12
    Aug 2016
    Houston,Tx
    I have 2 sets of tank turning rolls. I no longer use them. They are Profax TF5000. Rated for 5000 lbs per set. 4"-60" diameter. $2500 per set. One set pictured. Second set is identical. I'm in Houston. I will ship.
    Nov 2017
    Clovis CA
    Re: Tank Turning Rolls - Profax Tr5000
    Why would you buy a set of roller
    Any time I ever need a set I just made them for job.
    Harbor freight170
    Victor Torch
    HF 4X6 band saw
    South Bend 9 Lathe
    HF Mill
    B&D Mag Drill
    Amazon books that may help
    Machinist Handbook
    Machinist Guide
    Single To Three Phase Simplified
    groups.yahoo.com/neo/groups/southbendlathe9/info
    Feb 2014
    n.w. of chicago
    Cause I'm sure there nicer than anything you could make with your harbor freight mig welder, some people make money with their tools, also look at what they are before making a stupid comment a little more than a couple shopping cart wheels screwed into a piece of plywood, no I don't know the original poster
    Nov 2017
    Clovis CA
    It is very simple to build a set rollers NOT from Plywood using a drill for power to rollers note gear down the speed with worm gear box
    As for welder I have owned in pass very good welder the large I have owned was a Miller 750 with wire feed and gun
    Today I have very small with limit space and not interested taking on large work any more
    Quote Originally Posted by pat h View Post
    Harbor freight170
    Victor Torch
    HF 4X6 band saw
    South Bend 9 Lathe
    HF Mill
    B&D Mag Drill
    Machinist Handbook
    Machinist Guide
    Mar 2005
    Under a Rock
    Regardless,
    I think the point here is:
    If you don't have any interest in the item for sale.... Then Move along.
    Miller 211/Spoolmate 100
    1961 Lincoln Idealarc 250
    Hypertherm PM 45
    Lincoln SP125 plus
    HTP 221
    Chicom spot welder
    Nov 2017
    Clovis CA
    I was thinking the ask questions group
    Not hide under a rock like a fool does
    Why this better than a shop fab roller that is far cheaper
    FYI The Miller 750 was mistake the most ever use was are 300 amp welding beams
    Regardless,
    Harbor freight170
    Victor Torch
    HF 4X6 band saw
    South Bend 9 Lathe
    HF Mill
    B&D Mag Drill
    Machinist Handbook
    Machinist Guide
    Jun 2016
    Not there
    With a machine torch and HT85 or so you could make up one Hell of a plasma pipe bevel thingy.
    Nov 2017
    Clovis CA
    Thank you
    Sent from my SAMSUNG-SM-J320A using Tapatalk
    Harbor freight170
    Victor Torch
    HF 4X6 band saw
    South Bend 9 Lathe
    HF Mill
    B&D Mag Drill
    Machinist Handbook
    Machinist Guide
    Aug 2016
    Houston,Tx
    If I need a tool or a machine, and I have the option to buy it or make it myself, These are the things I think about. Will mine work well enough to do the job I need it to do? Is the money saved building your own worth the time invested? In the long run, will I save any money? Can I afford to buy one? I used to try to build everything. Now, I only build if I have to.
    Aug 2016
    Houston,Tx
    Also, sometimes we don’t have the tools to build what we need.
    Aug 2016
    Houston,Tx
    In case anyone needs a reminder, the point of this post is that I have 2 sets of tank turning rolls for sale .
    Aug 2016
    Houston,Tx
    I still have them for sale.
