Going to look at a lincoln need tips
Results 1 to 25 of 48
    Jun 2014
    Im going to look at a lincoln welder and I beleive its an sa200 but the owner doesnt know. They sent pics of the side and it has a f163 engine. Appears to be in clean shape. They dont know anything about it and asking $4500
    Whats should I look for to determine value as far as model and type? I dont know anything about sa200 vs sa250 or red face black face etc. Also dont know which year models are good.
    Should I just try to fire it up? Should I take ether and jumper cables? If it looks good and clean but wont start I might takr a gamble on it. Any tips alpreciated. Name:  image.jpeg
Size:  55.2 KBName:  image.jpeg
Size:  60.0 KBName:  image.jpeg
    1968 Lincoln SA200
    Maxstar 161
    Dynasty 280
    Trailblazer 325efi excel
    Maxstar 210
    Hypertherm 45xp
    Invision 352
    Oct 2013
    cntrl FL
    Re: Going to look at a lincoln need tips
    If it's mostly original, It's an SA 200 Redface (Round Generator Barrel) with upgraded electronic Idler and the alternator conversion.
    If it's not running and welding, it might not be worth any $4500.00
    SA 200's 1970, 1969,1965, 1963, 1955/44,
    SA 250 1981 D152 DC only
    2004 Ranger 10,000
    Lincoln Pro mig 135
    Hobart GPB 1957 258 Pipeliner, 1958 261 Mainliner
    Miller Load Bank
    Everlast ST 200
    Hobart Airforce 250
    May 2010
    Port Orchard, WA.
    What is your location? If you’re in the Mid West, SA-200s sell very high! Here on the west coast not so much. I paid $250.00 for a 1948 Short Hood, and $200.00 for a 1966 Red Face.
    Don’t pay any attention to me
    I’m just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Jun 2014
    Went and checked it out. Looked clean, turned over nice but wouldnt start so I negotiated down and bought it. Now to drag it home and see if we can get it to start
    1968 Lincoln SA200
    Maxstar 161
    Dynasty 280
    Maxstar 210
    Hypertherm 45xp
    Invision 352
    Jan 2016
    well with any piece of engine driven equipment, hopefully you bought it cheap enough so if it needs major repairs its still worth it in the end...starting it may be the first of many repairs as you dont know if it even welds...good luck with it..
    Oct 2013
    cntrl FL
    I noticed that the control panel has a murphy coolant and oil pressure gauge. If the buttons aren't reset, it won't let it start, unless there's something else going on. When it's turning over, what kind of oil pressure are you getting?
    2004 Ranger 10,000
    Lincoln Pro mig 135
    Miller Load Bank
    Everlast ST 200
    Hobart Airforce 250
    Jun 2014
    By the looks of it and the modifications it had and the way it turned over I assume it will run with not much work. Everything looked really clean and disnt notice any leaks. Oil pressure gauge jumped up to the middle when it was turning over. Nice older couple said it was their sons. They had a receipt where he had paid $6,000 somewhere last year.
    I didnt know what a murphy gauge was. I will see what I need to do to reset it. I appreciate the tips. Ill post up how it goes and see if anyone else can tell me what I dont know about the machine. Thanks a ton for the tips already thrown out. It would have taken me forever to learn that.
    1968 Lincoln SA200
    Maxstar 161
    Dynasty 280
    Maxstar 210
    Hypertherm 45xp
    Invision 352
    Oct 2013
    cntrl FL
    Check to see if the spark plugs are getting fire, If they are, then it's probably a fuel problem.
    2004 Ranger 10,000
    Lincoln Pro mig 135
    Miller Load Bank
    Everlast ST 200
    Hobart Airforce 250
    Quote Originally Posted by scramblerj View Post
    If the oil pressure went to the middle of the range, it's not the murphy gauge... depending on how its wired to short the mag. I would disconnect the stop wire on the mag and see if it will start. have a jumper wire to ground it to stop the engine if it does run.
    Oh, BTW that's a nice looking machine.
    Nov 2012
    ROCKVILLE ,,VA
    check gas bowl shut off? what the story on the son? not with us ? jail? etc? maybe contact him?
    Jun 2014
    Found out the son passed away. Gas tank was almost empty so I stopped and put some gas in it trying to fire it off but no luck Just picked it up. Going to look it over better when I get back to the shop. I can see gas filling up the bowl and going on to the filter so it seems like it's getting gas
    1968 Lincoln SA200
    Maxstar 161
    Dynasty 280
    Maxstar 210
    Hypertherm 45xp
    Invision 352
    Jun 2014
    I was wrong the fuel petcoc was not open. Opened it up and it fired right up
    1968 Lincoln SA200
    Maxstar 161
    Dynasty 280
    Maxstar 210
    Hypertherm 45xp
    Invision 352
    Feb 2016
    Myrtle Beach
    Awesome! Have you welded with it yet?
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    Nov 2016
    New Hampshire
    Wow, you have to love an easy fix! Did it weld once you had it running?
    Dec 2015
    Good find great looking welder! Looks like the gentleman who owned it before you took care of it. Looks like it was set up for a rig
    Oct 2013
    cntrl FL
    Great! glad to hear you got it running.
    2004 Ranger 10,000
    Lincoln Pro mig 135
    Miller Load Bank
    Everlast ST 200
    Hobart Airforce 250
    Jun 2014
    Quote Originally Posted by winniweld View Post
    Quote Originally Posted by Capt B View Post
    Absolutely. It came with some leads and a nice pipeliner electrode holder. Im really glad it fired up and welds good with no issues. Really thought I might have to have it tuned up to get it working but its great. It puked a small amount of coolant out the overflow tube. Not sure if the cap is froze up or if it was overfilled or what. I ran it for about 30min and it dis not get abover 190. Mainly hovered at 170-180.
    I should probably check the oil.
    Story was that he paid $6,000 for it in 2017, Im assuming from a place that did all this work to it to get it pipeline ready perhaps.
    Anything else I should check on it?
    1968 Lincoln SA200
    Maxstar 161
    Dynasty 280
    Maxstar 210
    Hypertherm 45xp
    Invision 352
    Jun 2014
    Heres a video I took of my buddy welding with it. First time he had stick welded since jr high
    https://www.instagram.com/p/Bdn_CVGFjM3/?hl=en
    1968 Lincoln SA200
    Maxstar 161
    Dynasty 280
    Maxstar 210
    Hypertherm 45xp
    Invision 352
    Oct 2013
    cntrl FL
    WOW! sounds great. Smooth and steady.
    2004 Ranger 10,000
    Lincoln Pro mig 135
    Miller Load Bank
    Everlast ST 200
    Hobart Airforce 250
    Mar 2009
    If you can look in the neck and see coolant it's a little too full. I like to fill them so if I rock it from side to side I can just barely see it slosh.
    Jun 2014
    How do I tell what year model this is?
    Chart I found looks like 1968. Wow I figured 80's
    1968 Lincoln SA200
    Maxstar 161
    Dynasty 280
    Maxstar 210
    Hypertherm 45xp
    Invision 352
    I say we all tip one in honor of the last owner... For what ever reason he didn't get any return on his investment.
    May 2010
    Port Orchard, WA.
    I can’t quite read the serial number on the face plate.
    Here is a serial number to date chart.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Dec 2016
    raleigh nc
    It is a shame some are never given the chance to fufill most of there lifes goals , i feel the last owner left this world early . My glass is raised in his/her honor .
    Jun 2014
    Yes found out he passed away. Looks like he had it setup to run pipeline. Glad I can keep the machine in use
    1968 Lincoln SA200
    Maxstar 161
    Dynasty 280
    Maxstar 210
    Hypertherm 45xp
    Invision 352
