Tig welder for gunsmithing? Thermal arc 161stl?
Results 1 to 25 of 29
    I have a small gunsmithing business and am looking for a decent tig welder. Anyone have any experience with the Thermal Arc 161stl or 201TS. Only difference I see between the the 2 are the amps and HF start on the 201TS. I have very limited tig experience other than a few classes at the local comm. college a few years back. but i look forward to learning. Should I be looking for a welder with pulse settings for thinner material (maxstar 150)? Any input would be helpful.
    Oct 2010
    The Netherlands
    Re: Tig welder for gunsmithing? Thermal arc 161stl?
    HF start=tig welder, the others are just dc power sources branded as tig welders.
    Pulse is not that important , but other settings are... up/down slope, pre/post flow digital amp reader (for repetability)
    www.becmotors.nl
    yup, I quit welding.. joined welder anonymous
    Feb 2010
    Northern MN
    That HF start is a huge thing, trying to be precise and use a scratch start is a pain. What is your budget for this machine?
    You could look at HTP, Esab, Lincoln or Miller for other machines.
    If you will only be doing steel a DC only machine will work, if you plan on doing any aluminum you will need a AC/DC machine in which case HF is mandatory.
    Pulse isnt really needed if you learn to use the foot pedal and watch the puddle, you can basically do the same thing.
    Looking to spend around $1200 to $1300. It's not going to be used everyday, only on occasion when the need arises. I have been considering the miller maxstar 150 sth and the diversion 165. The diversion is more in my price range and AC/DC but looks like a pretty basic machine. That could be a good thing while learning but don't want to outgrow it to quickly. The thermal arc 201TS looks fairly similar to the maxstar but does not have any pulse settings. The 201 does have downslope control.
    Oct 2010
    western kentucky
    you might look around for a used lincoln squarewave 175..
    Jul 2011
    You can get a used TA185 for around $1500. Dynasty 200's seem to be dropping a bit in price used as people await the 280.
    TA Arcmaster 300
    CM3
    XMT 304
    S22P12 suitcase feeder
    X-Treme 12VS
    Optima pulser
    TA161S
    Maxstar 150STL
    Hypertherm PM45
    OP setup
    Stihl 020AVP, 039, 066 Magnum
    Nov 2010
    NH
    TA's are decent machines..
    I know the maxstar 150 is a bit more than your budget but it's a great machine for small stuff.
    I got one back in August, & love it. I'd recommend getting a pedal no matter what machine you end up with though.
    HiFreq is a must for small stuff, IMO.
    Jun 2011
    I found a Lincoln Precision 185 close by for $1000 with all kinds of extras for my gunsmith work, on Craigslist.. I can weld pretty much anything I need to with it from 26 guage sheet metal upwards and it will handle 1/4 aluminum as well altho I don't do much that thick.
    May 2009
    coldest, flattest part of the midwest
    I have a 161stl and love it. It is ten times the machine a maxstar will ever dream to be. I am a miller fan so I am just stating that the machine is great. As far as tig it is similar but for stick welding it is awesome. You don't need high freq for anything but aluminum really. It is nice but I have never had an issue not having it. It is lift start, not scratch start. All you do is touch the tungsten, touch buttom or pedal and lift to desired arc length. There is no sticking or extra motions. The pedal from my 185 plugs right in and on 2t mode makes it just like my 185. For gunsmithing I would suggest buying a pedal since the slope method can be difficult on small parts to control. You can get used to it and do great things though. With the torch it comes with you can set it to 4t and push buttom to start and then roll the little dial to back off amps as you go then hold button again to slope down. I usually leave it on 2t and then when it gets a little hot I just let go of button, it starts ramping down then hit button again and it goes back to set amps. No matter what tig you get I would recommend getting one that you can at least control the amps on with slope or pedal other wise you might vaporize some small parts.
    Millermatic 252
    Lincoln 175 plus
    TA 185tsw
    TA 161stl
    hypertherm pmax 45
    Victor torch
    Henrob torch
    An S10 for each day of the week
    SoCal-LA
    Quote Originally Posted by carolinacustom View Post
    I believe neither of these tigs go below 10 amps output. That makes it a bit tough for small edges or such, and can leave crater cracks in high strength steels. Engaging a pulse can dampen the arc a great deal but these don't have that either. I do think they are remote capable though.
    I do medical instrument fabrication and repair on occasion, a lot of it 17-4, and I rely on my Dynasty200DX.
    I know this is a lot of machine, and takes a great deal of knowledge to operate, but I can go to 1 amp output and engage the pulser to dampen that even. The pulser takes out arc wandering on arc startup too. As far as slope control, you won't need that with a foot control, which I can't even imagine gunsmith welding without foot control.
    The new Miller 280DX tigs are coming out this spring. That will put some "Blue Lightning" 200dx Dynastys on the used market. If you can find one with at least a year of warranty left, you will have a winner.
    Miller Dynasty700DX, Dynasty350DX 2ea., Dynasty200DX, ThermalArc 400 GTSW, LincolnSW200 2ea., MillerMatic350P, MillerMatic200 with spoolgun, MKCobraMig260, Lincoln SP-170T,PlasmaCam/Hypertherm 1250
    Any one have any input on this one? HTP Invertig 131 http://www.usaweld.com/ProductDetail...Code=70131DCHF
    The specs look pretty close to the maxstar with the exception of the duty cycle and 130 vs 150 amps. It also comes with a pedal. I am really looking for something small as space is pretty limited and it will only be used for the occasional job. I don't want to break the bank on a welder that will be idle most of the time but don't want to buy a piece of junk either.
    SoCal-LA
    I think this will work for you. Foot pedal with HF start is there, goes as low as 5 amps is very good. Seems to come with all the right stuff to get you going.
    I don't care for the 1 year warranty, but HTP seems honest. Maybe they offer an extended warranty, otherwise flog it the first year.
    Looks like the air cooled torch will accept standard parts, so getting them at your local weld supplier should be easy.
    Thumbs up from me.
    Dec 2008
    I just bought a HTP 221 and love it so far. It has a 3 year warranty (I think the duration is different based on the machine). I have been playing around with it the last couple nights and learning a lot. I plan on posting a review in a couple days. I need to get more scrap so I can show the beads in the hands of a newbie. It goes down to 4 amps and has a lot of adjustments. I know its a bit more than you want to spend. For the money you are looking at, best would be to hold out for a used Lincoln PT series.
    Hobart Handler 210 with Spoolgun
    Hypertherm PM30 Plasma
    HTP 221 Tig Welder
    HF Bandsaw
    HF Auto Dark Helmet
    Maryland
    Of the limited number of machines I have looked at, the low power setting on pulse is always limited to the lowest output the machine can normally put out. So if you are welding on a machine with 20 Amps as the floor, and you set it up for 25 Amps with pulse background at 20%, rather than getting 5 Amps during the low periods, you are actually getting 20 Amps.
    Bottom line, pulse is no crutch for that.
    If gunsmithing doesn't require aluminum welding, Maxstars are about 1/2 the price (actually less) than the equivalent Dynasty (ebay used pricing).
    Con Fuse!
    Miller Dynasty 350
    Millermatic 350P
    -Spoolmatic 30A
    Miller Multimatic 200
    Hypertherm PowerMax 1000G3
    Miller Maxstar 200DX
    Oct 2010
    western kentucky
    guy selling a squarewave 175 on here in the for sale section..
    http://weldingweb.com/showthread.php...981#post738981
    I found a Maxstar 150 STL locally but no HF start. I would rather have an STH but I can get the STL for a good price and it's local. I have used an STL before and the lift-arc works great. What situations, if any would high frequency be a must?
    Jul 2011
    Utah
    Don't even consider a machine that doesn't have high freq, seriously, it's worth it to just find an STH. Small portable machines really only exist without it HF because some job sites prohibit it's use due to radio/electrical interference, that's basically the only reason you'd ever choose scratchstart over it (or if you're welding heavy stuff and running at a set amperage with no pedal/thumbwheel remote). Up/downslope are completely useless if you using a foot pedal. For your application pulse will be extremely desirable, it definitely helps on thinner material and also can help the weld appearance. I have a maxstar 150 STH and it is one of the best welding DC TIG / stick welders I have ever used. You should be able to pick up a used one for under $1000 easy.
    Jul 2011
    Utah
    Quote Originally Posted by S obsessed View Post
    What a ridiculous statement, it looks to me like its less of a machine. It doesn't even have high freq?
    Jan 2012
    http://www.ebay.com/itm/LINCOLN-INVE...item3a704f07b3
    You can pick up a WP17 air cooled torch for another $100.
    Joe
    Miller Syncrowave 200
    Mac/Miller MW130 MIG
    Kalamazoo bandsaw
    Cincinnati Arrow 500 VMC
    Colchester Dominion 15 x 36 lathe with 2 axis DRO
    Jan 2010
    connecticut
    maxstar 200 is the way to go for what you will be doing they are a sweet little welder.I have used them on jobs where we were welding ss down to .025 and they were smooth and consistent.the 200 will give you all you will need and still have some left for the application you are looking at.i love these welders and would highly recommend them.
    After the arc has died the weld remains
    Jan 2005
    The The Thermal-arc (Sanrex) TS160 is the model that was a full feature machine, It use to sell for more then a fully outfitted Thermal-arc 185. That was for the machine only. Pulse/repeat/ 1 amp low-end/high freq. That was a great DC tig unit. If you could find one used, then it would be the one I would get. Never was as good on power as a maxstar, but it was one sweet tig machine just the same. I do like the new 161s better on stick, and how it is excellent on 120 volt Stick welding. 110 amps on a 20 amp circuit without blowing breakers.
    There are a few guys that come into my friends welding store, and want these old Lincolns on DC. Not sure if it's this model or the older ones. I know they all have modern top of the line inverters too. I knew a gunsmith that just loved the old Lincoln machines too. He was comparing it to my Thermal-arc 300 TSW ac/dc but I got the feeling he liked his machine better.
    http://www.ebay.com/itm/LINCOLN-IDEA...item3f12b9fe8b
    Esab 2200i-TA34
    Esab 160i caddymig
    Hypertherm 45XP
    Thermal Arc LM-200 Lincoln feeders
    Thermal Arc Pee-Wee 85s
    Thermal Dynamics 38XL-SL-40
    If I agreed with you, we'd both be wrong!
    Jan 2008
    curious what a gunsmith does with a welder..i have heard of a torch and silver solder on some gun work..
    Quote Originally Posted by weldbead View Post
    Thanks for all your advice. I ended up buying a Miller Maxstar 150 STH today.
    I want to use it to attach Rem. 700 bolt handles and other small jobs as needed. I pay a guy to tig them now and want to learn to do it myself. Might take awhile before I'm there but I'll learn. He uses a Maxstar STH and does a real nice job. I just hate paying someone else to do it.
    SoCal-LA
    You are going to love it.
    Congrats!
    May 2010
    NW Indiana
    You made a good choice, Maxstar is a helluva little machine.
