welding rod
Results 1 to 19 of 19
Thread: welding rod
    northwest Indiana
    welding rod
    What amp setting would you use to weld 1/16 inch steel with 1/16 inch rod (6013)? I am use to using 1/8 rod and I keep welding way to hot.
    Winnipeg, Manitoba
    Don't know if they make a 1/16" rod. What you can get is a 3/32" rods. They have an amperage range of 45-80 amps. Pick a midway amp of about 60 and see how it goes.
    Just what is it that you are welding / making? 1/16 if pretty thin.
    Here in the Great White North
    Mosquitoes can't fly at 40 below
    northwest Indiana
    rod
    You are correct on the 3/32 rod Snidley. Thanks for the range.
    Oklahoma
    Wal mart has 1/16" AND 5/64" electrodes!
    Lean mean TIG weldin' machine
    Squarewave 175
    Winnipeg, Manitoba
    Walmart & Home Depot and those kind of places - I will not buy my rods from.
    Quite often for what they are charging for 1 pound of rods - I can go to my local welding shop and buy 5 pounds. I like to support my local guy as well you always get to browse among all the new toys.
    Walnutport PA
    My thoughts exactly
    Of course I usually pick up a new toy too. I want some of the BIG toys though. Too bad I don't have a BIG wallet
    MillerMatic 175
    Thermal Dynamics Drag-Gun Plasma
    Airco Bumblebee AC/DC SMAW
    Victor Super-Range II oxy/act
    Hilton, NY
    There's always the guy on ePay selling those Canadian Tire Lincolns that can't be shipped in the original box.
    "Uses electrode sizes from 1/16 to 3/32. I have used mine quite a bit and I can say that the best size is 1/16 and they work even better when the rods are pre heated."
    I really gotta read up on preheating them rods!
    http://cgi.ebay.com/ws/eBayISAPI.dll...ory=45031&rd=1
    Internet vending at it's best.
    fla jim Guest
    Years ago I used to use 1/16" 6013 for sheet metal with my old Craftsman buzz box. If I remember I used about 45 amps.
    Tractor Supply has 1/16" 6013
    Central Florida
    I have some Lincoln 1/6 6013 rod. The container says 25 - 50 amps. I have run it around 30 amps.
    Bill C
    "The more I learn about welding the more I find there is to learn..."
    northwest Indiana
    Thanks for the info guys
    Oklahoma
    hahah, yeah i wasn't recommending buying them from wal-mart. Hell, they charge you ten bucks for some no name cresent wrench where you could get a name brand one anywhere else for 5! On top of that, I'm sure we all know the phrase "wal-mart fall apart."
    Squarewave 175
    West Central Florida
    As long as we're talking about small rods....I've got
    a question: *as they all roll their eyes and say to themselves:
    "what else is new"*.....I tried some of those small rods, like
    3/32" & 1/16", and I noticed that when I got to the end of
    a weld, pulled out & raised the hood....the electrode
    was glowing ! I normally run 1/8", and that has never happened
    on those rods.....but, (being a "learner"), I like to try different
    rods. Is this normal ?...(the glowing part, that is)......
    Seems to me, if the flux on the rod gets THAT hot....
    the rod is scrap.
    I'll be the LAST one to let you down !
    Oklahoma
    Weird, was it the whole electrode? I run 3/32 7018 H4R at the shop sometimes, the tip will normally glow, but i've never seen the whole electrode do that. Hahahaha, that did make me think of this kid that was trying to show off to me, when he went to strike the arc, the whole electrode went up! It was kind of funny, rasied me hood and was greeted by him dumbfoundedly looking at this bright red stick in his electrode holder...still don't know what he did...
    Squarewave 175
    Yep !. . .the whole rod ! . . .(or I should say "what's left of it
    after a few inches of bead")....glowing like a ribbon
    in a toaster-oven.
    ohio
    your alittle to hot for that size rod ......now if you ran the whole rod from start to finish and it is just ever so slightly turning red then your tuned in right...give or take a few amps
    Thanks, Boilerman !...I think I was stoking the rod a little high.
    (was cranking er' at about 90.
    Feb 2004
    NE New York, Plattsburgh
    What are all those funny numbers?
    This is my first post on this site . I've recently bought an'83 Chev. 1/2 ton 4x4, and I've been installing a beat up Fisher plow for the last two months. I finally had to unbury my Montgomery Ward AC/DC welder, and then my welds were BLAH . I used to know what the numbers reffered to, ie; 6011, 8014 etc... What's the DC do? It didn't buzz as much. My upside down welds required 3or4 passes to fill in the gaps (in the bead).I really should read a welding book, with lots'a pittures!
    Andrew Golt
    fla jim Guest
    Andrew;
    Here's a couple of links for welding rod choice.
    http://www.mylincolnelectric.com/Cat...asp?browse=104|2030|
    http://hobartwelders.com/weldit/fill...ck_charts.html
    DC welds a lot smoother. You can use either DC reverse (DCEP)polarity Electrode is positive, or Straight (DCEN) where the electrode is negative. DCEP or reverse is the most common it gives the best penetration, and weld bead.
    If you want a good basic book, get Richard Finch's Welders handbood. This is a real basic overview of welding processes (Welding101).
    As we always recommend. Look into taking some classes at your local tech school, or JC.
    Wall mountain videos is another good source of information
    http://www.weldingvideos.com.
    I have their mig video, it's very well done.
    Feb 2004
    use dc.50 amps,smaller rod,7018 or 6011
