Flange Alignment--Two Hole ?
Results 1 to 17 of 17
    Jan 2008
    Wamba, TX
    I was at a friend's shop the other day and he was showing me two sections of pipe, about2 feet in diameter. They were welded at 90 degrees with a flange on the downward section. I was asking how do you verify that the top pipe and the bottom of the flange are parallel? He started to explain and got as far as "standard two hole...", and got interrupted. I never remembered to ask what that meant....So..what was he going to say??
    Thanks
    TxDoc's Photos
    Lincoln SP175 Plus
    Lincoln Power Mig 256
    Lincoln 250 LX Spool Gun
    Lincoln Precision Tig 225
    Hypertherm 600
    KMG 2x72 Belt Grinder
    Baldor 812RE Grinder
    Jan 2006
    Re: Flange Alignment--Two Hole ?
    Well, when we do flanges at work, we assemble the piping system with two bolts and gaskets in the flanges, then tack everything together, then remove it (access is usually too difficult to weld in place), complete the welds, then reinstall with all of the bolts. The beautiful thing about flanges is that they usually have some slop in the fit so you account for all of the misalignment in your system in the welds on the flanges.
    Or else, you assemble with two bolts and gaskets, weld in place, replace gaskets as they have been burned in the welding process, then tighten with all bolts.
    Of course... when you're doing pre-fab none of this works.
    Feb 2011
    Alberta, Canada
    I'm not sure of your description but when welding a flange to a pipe it can be either 1 or 2 hole.
    2 hole would have the top 2 holes level with each other. Usually bolts or flange pins are put in even #holes and a level laid on the pins.
    Leo
    Sep 2008
    SF bay area, CA
    You install a level across two holes in the pipe flange.
    Feb 2009
    Central Illinois
    Leveling across two holes is only part of the procedure. You also need to make the flange faces square with the pipe in all directions. Adjustable pipe stands, a level and a square make this easier. They also make fancy chain fixtures to hold flanges but no one uses them.
    Dan
    Feb 2007
    West By Golly Shelby NY
    Quote Originally Posted by Dualie View Post
    Ding Ding Ding!!!
    That is how it was explained to me by the guy wanting pipe welded the first time.
    David
    Real world weldin.
    TWO HOLE is the standard procedure because most valves, strainers, and devices attached to flanges are manufactured TWO hole. HOWEVER some import stuff can be one hole.There are flange line up pins that help, but usually a couple of oversize bolts that fit TIGHT in holes that are for fit up only and too large for installation purposes.
    http://pipefitter.com/existing_php/Matheyflups.php
    Sep 2006
    Marlborough, The Peoples Republik of MA
    Two hole set up
    Jan 2008
    Wamba, TX
    Okay, that makes sense, now! I got it and appreciate the words and pics. This large piece of work was made and used only one time. Then it was discarded, and I was told, probably going to be used to make a cooker. Lotta work and time and effort to be used just once.
    Thanks again for the explanation.
    TxDoc's Photos
    Lincoln SP175 Plus
    Hypertherm 600
    Nov 2011
    orbiting
    Prints usually stipulate bolt holes to straddle centerline, aka the "two hole".
    It's a standard practice in the industry, stuff happens sometimes and somebody doesn't get the memo though.
    I have several nozzles on the top of a tank. they are all located radial from the centerline of the tank. Does two-holing apply per centerline, or is the 'vertical' centerline on the drawing of the tank assumed to be the two-holing line? I had a fabricator use the radial lines and claim it was the industry standard, but that sounds weird.
    Thanks, Jay
    been told that when two holing you get a more accurate reading on level if you place pins further apart.I have been a pipe fitter for 30 years and have never heard this until the other day.What do you think?
    Sep 2005
    Cave Creek AZ
    More accurate sure because you have a bigger average sample of horizontal to measure., but you can only two hole the flat face of a flange that way, not its mating flange, or the neck side of the flange because the pipe gets in the way. We used to use the next size up bolts, 3/4" in place of 5/8" bolts for two hole bolts. Just hammer them through a junk flange once, then back out, then the fit snug in the holes for a 5/8" bolt. Then just set a torpedo level across the top and you are two holed!
    When I was in a new job that used a lot of flanged fittings, the guy that I was working with asked "Do you know how to two hole?", I replied, "Yes I do, but my wife doesn't like it, so I don't try it very often." He was floored.
    Feb 2009
    Melbourne, Australia
    Thanks Walker.
    Reading your post, i got to the end and spat my coffee.
    Now i have to clean the monitor.
    Oct 2011
    alabama
    I've been a pipe fitter and welder for 20 yrs.from the oil fields to paper mills. 2 hole is the standard practice on all flanges, If you have to EVER 1 hole or as some call it hole and half then someone has screwed up big time. 2 hole flanges is so no matter who or what makes up prefab pipeing then it will fit any flange of same size and weight class anywhere everytime. just my humble experience.
    Magicial Magician Of Molten Metal
    2006 Chevy Dually Welding Truck
    1975 SA-200 Lincoln Red Seal
    Miller AEAD 200-LE
    Lincoln 225 AC/DC tombstone
    Victor Contractors Flaming Tomahawk
    Profax Tig Rig
    More pipe fitting tools to mention
    Metabo's
    Quote Originally Posted by dancesintherain View Post
    Yes it is absolutely true. If you put the pins at the very top, you can get a false reading. I learned this lesson the hard way. I had a vessel come back to the shop because two flanges were out of two-hole. When we checked the pins at the top they were good, but in the middle and they're out by 3/16. I think it was an 8" flange or something like that.
    Aug 2012
    Colchester, UK
    Quote Originally Posted by TozziWelding View Post
    Two hole set up
    thats a cool looking jig, is that from the curvo mark stable??
