How to "clean" or "prepare" metal
Page 1 of 3 123 LastLast
Results 1 to 25 of 63
    Dec 2006
    Troutdale, OR
    Since Im new I guess its fair for me to ask a simple question that keeps jumping out with different answers. Ive heard so many versions its sick, and figured there's gotta be a difinitive for the forum library.
    What is the proper way to prepare/clean steel, aluminum, and SS prior to welding?
    ThermalArc 185
    MillerMatic 180 w/ Autoset
    Victor Cutskill Oxy/Acetylene
    Thermal Dynamics Cutmaster 38
    and spite!
    Jan 2006
    In A Nice Comfy Chair
    Re: How to "clean" or "prepare" metal
    Clean rags..
    1 Stainless steel "toothbrush" for each type of metal..
    Acetone..
    Wipe..
    Brush..
    Wipe..
    Brush..
    Untill its clean
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
    utcia michigan
    what zap said but if its got mill scale on it grind or sand first then do what zap said
    Chuck
    ASME Pressure Vessel welder
    Jul 2006
    why would you clean it?? For nice projects or something, ive just clean it up aftrer im done then paint or do whatevere with it??
    Jan 2006
    Quote Originally Posted by lodogg89
    The real pros clean it before..
    During..
    After...
    You would'nt work for me very long if you did not clean clean clean your stuff prior to welding..
    Dirty metal = major contamination..
    Major contamination = major problems with me..
    ...zap!
    Do not attempt.
    Dec 2006
    Troutdale, OR
    That it?
    Grinding, rags, & acetone?
    Any particular type of brushes or just the usual wire 2-3" brushes?
    Theres gotta be a little trick or two to such a simple process...
    ThermalArc 185
    and spite!
    Dec 2006
    Southern New Hampshire
    That's it my friend now go out and conquer the world!!!
    _________________
    Chris
    He did say "stainless brushes", and yes there is a difference. No cross contamination, keep the aluminum brush only for that, and so on...have fun!
    If you don't have the time to do it right, then you definitely don't have the time to do it over.
    Feb 2007
    West By Golly Shelby NY
    I wouldn't grind aluminum with a steel wheel. The abrasive in wheels for steel is aluminum oxide, just what you don't want in your aluminum.
    Yeah, for the best weld on carbon steel, grind off the mill scale. The arc will be more inclined to go TO the base metal.
    For stainless, one of those flap wheels work best for me.
    It all depends on the project.
    A mig with C 25 or 6010 stick will weld over the most sin, but its just that, a sin.
    I have had guys tell me to weld right over the paint. I tell em I am not that good of a welder. The truth is I will end up with a crappy weld.
    Rust, grease, OLD welds all have to go before doing the job right.
    A carbon arc gouge or Arc Air works best for me removing old cracked, interrupted or just trashy welds and leaves a pretty good surface for a good weld. All I do is chip any slag that is left. Some times I trim with a grinder.
    David
    Mar 2006
    Arizona
    Aluminum cleaning/grinding/sanding/metal prep stuff on it's own.
    Stainless cleaning/grinding/sanding/metal prep stuff on it's own.
    And yet another set for mild steel. I would personally keep two additional sets for mild steel, 1) for the dirty work on dirty metal (rusty stuff, repairs, fences, etc) and 2) for the nice DOM tubing work like gates, soapbox racers, etc.
    Lincoln AC225 stick welder
    Lincoln HD100 WeldPak flux core wire feed welder
    Three of the cheapest grinders money can buy
    Dec 2006
    Troutdale, OR
    Great information guys. I just knew that there was more to it than rags and combustables! Anything else?
    BTW: Ive been absolutely amazed at the difference in my work with and without cleaning. Also helps with the learning curve since there seems to be a slightly different "feel". Maybe that's just me, but since I like to do a job the correct way it makes me feel better knowing that there's one more step to the ritual.
    ThermalArc 185
    and spite!
    Jul 2006
    do you guys clean everything you weld?? If i cleaned things i probably would enjoy welding as much, do you clean all types of metals for all types of welding? Im curious about this, tell me more, Where can i buy acetone? Does it come in big bottles?
    May 2006
    Yes, clean mild steel, alumized mild steel, stainless steel, aluminum. You get a much better arc and a much nicer weld bead.
    John
    - bleeding Miller blue!
    http://www.weldfabzone.com
    Dec 2006
    Troutdale, OR
    You can get Acetone at any hardware store (ie: Freddy's, Home Depot, Lowes, auto stores, and/or any paint shop). Usually comes in 1 litre and 1 gallon cans.
    ThermalArc 185
    and spite!
    utcia michigan
    yes i clean every thing before i weld ,braze or solder
    Chuck
    Jul 2006
    i will have to pick some up and try this, i will let you know how it goes.
    Dec 2006
    Troutdale, OR
    REMEMBER:
    dont store the rags in a "pile" as the schtuff is EXTREMELY flamable and is known to spontaneously combust! Let it "air out" away from your work area and open the rag up so it can off gas quickly.
    LASTLY:
    Dont try to weld your can of acetone to your project.
    ThermalArc 185
    and spite!
    Jan 2006
    Are we done with this yet?
    ...zap!
    Do not attempt.
    Jul 2006
    ofcourse were not done with this thread, i havent learend enough yet. Okay, i bought a gallon of acetone, and stainless wirebrush, i will test this out and see how it works, maybe post a before and after pic of my work, no making fun though, im new at this.
    Feb 2007
    Quote Originally Posted by zapster
    During..
    After...
    ...zap!
    Apparently you've never worked for a construction company. Things don't always clean up as nice as you want and you don't always have time. Xray quality welding is neccessary for everything. Dave
    Jan 2006
    Maybe not but I fix stuff that cant be repaired in the field..
    Dont be too quick to judge others capabilities too fast..my friend..for now..
    Even if it was -20 and with a wind in my face at 50 mph.. clean has to and will happen..
    No matter what you state..
    I'm a pro...are you?
    and there is many here that will agree with me..
    This is what seperates "us" from "them"
    ...zap!
    Do not attempt.
    Sep 2005
    middle tennessee
    ...zap!
    I am "them" most of the time at work because that's what they want You can only argue a point so much and in the end they are the boss. I do actually clean my stuff more than any of the other people though. But when I'm doing work for myself and others I do it right
    Dewayne
    Dixieland Welding
    MM350P
    Lincoln 100
    Some torches
    Other misc. tools
    Gillette, Wy
    I wonder... how about alcohol? Isopropyl is cheap... Just a thought
    Dec 2006
    Troutdale, OR
    What we need are hugs...who's gonna start?
    I can think of numerous excuses to do a quality job, but cant think of many to do a lousy job. Its true that there are many jobs out there that are of the mode of "get it stuck together", but I dont consider that welding.
    I dont know if alcohol would strip oils like acetone does. Anyone with other ideas as to how to clean metals for welding?
    ThermalArc 185
    and spite!
    Northern Cal., Shasta County
    Everything has it's goods and bads. Isopropyl is good I guess. I only keep a bit of that in the shop. It evaporates so fast it's not much goof for heavy removals. It's best for what it is intended for, topical skin treatment.
    I keep a gallon or so of denatured alcohol, usualy methyl, around. It won't harm most plastics so that's a plus, but one oddity is it doesn't blend well with deisel and/or kerosene. If it doesn't blend well I assume it won't clean much better.
    I generally use a lot of the laquer grade thinner/solvent. It is generally a mix of around three of your favorites so works well for a host of tasks. It will harm many plastics so some caution is required. It's evaporation rate is a little less than acetone and many alcohols.
    Another usefull cleaner is ordinary de-oderized mineral spirits (paint thinner also). It's cheap, evaporates slow and it will blend and solve most any oils and greases as well as pitch. Plus it isn't as harsh on the hands and has a much higher flash point than the other options. I use it often as a first assault on heavy oil and grime. Then follow up with laquer thinner as needed. This combination also works well for cleanup before and after painting too.
    If nothing else cuts it I dig out the acetone. It evaporates so fast you gotta be quick.
    So in my shop at any given time I will have quite a hoard of cleaners
