extending mig lead
Results 1 to 7 of 7
    Feb 2012
    Chattanooga TN
    extending mig lead
    Has anyone ever extended the gun lead on a mig welder? Would be easy to do on mine. Just wondering if I will run into any issues.
    Sep 2005
    yuma az
    Re: extending mig lead
    might be good to add your machine and how far you wanna go may be easier to buy a gun with a longer whip again all dependent in what you got and what you wanna do
    350P 30A spool gun cut master 51 syncro 250 other stuff
    " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
    Feb 2012
    Chattanooga TN
    The lead now is 5' I would like 8'-10'. Its an older Clarke so parts are a no go. Everything runs separate, power lead, trigger wire, liner, and gas line (valve in the handle). It would be really simple to extend and pretty cheap as well. Just didn't know if I would run into any weird voltage issues or anything by doubling the length or so.
    Jan 2012
    NE Ohio
    You would be better off finding a longer whip that will fit your machine. Normally see sizes of 10, 12 and 15 foot.
    Feb 2010
    Northern MN
    you should be able to find a gun that will fit, They all pretty much use a few different connectors between all the brands, or at least close to a standard connector. You should be able to find something that fits. I would post up a few pictures of the machine end connector for the gun whip and see if anyone knows what it is
    Feb 2012
    Chattanooga TN
    Quote Originally Posted by ironmangq View Post
    No connector everything is hard wired.
    Feb 2011
    North Georgia Mountains
    If you are talking about extending the power cord, you just need to look at the max current the welder draws and get a wire(power cord) of the correct size. Should not be a problem.
