Mig Weld Stainless Steel??
Results 1 to 10 of 10
    Apr 2008
    Charlotte NC
    Ok Guys,
    I'm sure I will suffer for this question. Is there a mig set up to weld stainless steel. I've been fabricating many years but have never seen or had the need to mig stainless. I'm currently bidding a few jobs using 14ga. to 11ga. SS sheet and 1/2"dia. to 1"dia SS round stock. The jobs will require yards and yards of SS welds. Mostly 4" runs and less. Currently I tig most of the SS I do, occasionally stick weld the thicker stuff in field.
    Miller TrailBlazer 251
    Miller HF-250-1
    Miller MaxStar 150 STL
    HyperTherm PowerMax 380 plasma
    Lincoln PowerMig 180
    Millermatic 252
    Miller Diversion 180
    Apr 2011
    minnesota
    Re: Mig Weld Stainless Steel??
    I have run stainless through my mm175. It even has a chart for it. I bought it from a shop that bought it for one job. Clean up on sanitary stainless sucks but it works
    Millermatic 252
    millermatic 175
    miller 300 Thunderbolt
    lincoln ranger 250
    smith torches
    lots of bfh's
    Feb 2008
    North of Philly
    Don't expect SS mig welds to look anything like tig. The welds will most likely be smooth rather than the stack of dimes look and be gray in color.
    Tbone had a recent thread with questions on SS mig, and it's been covered here several times in other threads as well.
    www.weldingweb.com/showthread.php?t=72981
    Ronald Reagan
    Sep 2006
    NJ, USA
    The guage-thickness stuff, sure. Usually use short-circuit transfer mode with tri-mix (helium-argon-CO2). My small Lincolns can do it OK. The puddle seems more sluggish than GMAW on plain steel.
    The thicker pieces? That's really the realm of spray-mode transfer IMHO. For that, you need a 'big' machine that can do spray-transfer. Which usually means the 250-class machine or better/bigger.
    Pay attention to getting the 'correct' filler alloy for the parent material alloy. Different stainless alloys use different filler alloys. Some of the alloys (parent and thus the filler) are rather 'special'.
    Plain-old 304 alloy parent is welded with 308 filler.
    If the parent alloy is something else, check for the recommended filler alloy and then double-check the filler pricing/availablity and any 'special' procedures needed.
    Apr 2008
    Charlotte NC
    I'm running a MM 252. I have 75/25 gas and 98/2 gas. The parent metal is to be 1/4", 309 stainless steel plate and 1/4", 330 stainless steel. I could tig or stick with ease but hope I set up a mig procedure to save labor.
    Miller HF-250-1
    Millermatic 252
    Mar 2007
    Deltaville, VA
    For that material you can go one of two ways.
    Short circuit with tri-mix (90%Helium/7.5%Argon/2.5%CO2) (Ed Craig swears by a 98%Argon/2%CO2 mix but I haven't used this). I know the tri-mix yields a good and corrosion resistant weld.
    If you can keep the material "in-position" I'd recommend a spray transfer with an Argon rich mix (95-98%Argon, balance CO2). This will yield a better, faster weld. Only problem is the puddle will be very fluid and difficult to hold out of postion.
    Personally, I'd use pulsed spray with a 98%Argon/2%CO2 mix. All the advantages of spray, but the pulse allows for out of position welding.
    Syncro 250 DX
    Dynasty 200 DX
    MM 251 w/30A SG
    HH187
    Dialarc 250 AC/DC
    Hypertherm PM 1250
    Smith, Harris, Victor O/A
    Smith and Thermco Gas Mixers
    Aug 2011
    Cape Cod, MA
    I second Sundown's gas recommendations. 309L for filler metal. 1/4" plate is a mite heavy for short-arc- if you can't use spray, stick might be your best option.
    John
    A few welders
    A lot of hammers
    A whole lot of C-clamps
    Maryland
    Is 309 still the prefered filler for 330 to 309 welding?
    Con Fuse!
    Miller Dynasty 350
    Millermatic 350P
    -Spoolmatic 30A
    Miller Multimatic 200
    Hypertherm PowerMax 1000G3
    Miller Maxstar 200DX
    Sep 2006
    NJ, USA
    McKay's suggested chart on stainless does indeed list 309 (or 312 first) for welding 330 and 309 together. A bit surprising to me, given that 330 has ~2x the nickel as 309 (34-37% for 330 versus 12-15% for 309, chromium levels are closer at 17-20% for 330 and 22-24% for 309).
    330 to 330 is supposed to use 330 though.
    I'd double-check with the customer on end-product usage and if they require full-up 330 for the usage of the product (high-heat item?). If so, I don't see any 330 wire with a quick check of the 'usual' suspects, but 330 SMAW sticks are listed/referenced (whether you can actually get them is another question though, eh?)
    Dec 2009
    Greenville TX
    Quote Originally Posted by SundownIII View Post
    can any of you give me a few thoughts or pointers before I go for this test. I really need the money bad and im so frikn nervous V V V
    this is all the information they give :
    Weld Test - The duplex test is the hire in test. 1" steel plate with a backing strip 2G, 3G and 4G positions. MIG Lincoln pulse arc machine (with the stainless wire).
    sundown is awsum, where has he been man don't leave us nubs alone
    thermal arc 252i - millermatic 350P - alphatig 200 gen4 - Hypertherm 1250 G3
