Old 12-28-2007, 07:29 PM
chris madden's Avatar
chris madden chris madden is offline
? on O/A torch regulator
I have a radnor torch kit and in the manual it all go's by cubic feet per hour and on the reg it go's by kpa and psi is kpa the same as cubic feet per hour?
Millermatic 135
Syncrowave 200 with coolmate 3
Hypertherm powermax 30
were I am when I am home
Old 12-28-2007, 08:18 PM
Donald Branscom's Avatar
Donald Branscom Donald Branscom is offline
Re: ? on O/A torch regulator
Nice shop ! Very nice.
About your question.
PSI,KPI (metric) and cubic feet are all used, but different.
The regulator usually shows two scales.
as far as the torch setting for actyelene Obvioously NEVER exceed 20lbs pressure.
Thats why the actylene shows a red zone on the guage.
The torch settings for the size of tip or cutting torch should be listed in your owners manual but if not, any welding store has a small pocket guide that you can get as a reference.
Also when adjusting the flame on the cutting torch, fine tune the shape of the pointed flame with the cutting lever depressed.
Never get any petroleum product near your oxy rig.
Not being condescending, just covering the bases.
Old 12-28-2007, 08:36 PM
Sandy Sandy is online now
Kilopascal(s), kpa, is a pressure scale also. Some of the Aussies here can probably give you a good run down of kpa and settings.
Old 12-28-2007, 08:42 PM
William McCormick Jr's Avatar
William McCormick Jr William McCormick Jr is offline
According to Wikipedia 1 kpa equals 0.14504 psi.
It has nothing to do with cubic volume in itself. But if you know your pressure and your orifice and what you are putting through the orifice, you can conclude the cubic feet an hour in conjunction with the pressure.
Sincerely,
William McCormick
Old 12-28-2007, 10:38 PM
so I sould go off of psi ?
Millermatic 135
Old 12-28-2007, 10:46 PM
Most of the tip charts I've seen are referenced in psi. PSI is the US standard (still) . All of the talk you hear will be in psi.
Old 12-28-2007, 11:07 PM
ok thanks
Millermatic 135
Old 12-29-2007, 12:44 AM
ok thanks
I was taught this by my father.
You start at seven psi of acetylene at the regulator. You start at 40 psi at the regulator for oxygen. For cutting this works well. And you can also use a welding torch tip as well at these pressures.
I was taught to light a torch by my shop teacher actually. He said you turn up or down the acetylene till the flame just does not leave the torch.
Add oxygen until you get neat needle blue flames. But no harsh sounding or vibrating blue needle flames.
Shut off the acetylene first when you are done.
Sincerely,
William McCormick
Old 01-01-2008, 11:43 PM
clark-kentski's Avatar
clark-kentski clark-kentski is offline
Cris that 10 mfa is a pretty good size rosebud.What size acetylene tank do you have? there is a saftey rule that says do not use more than 1 seventh of your tanks capacity per hour! if no one else post first ill look up the settings for that tip for ya in the morning,be safe
Victor SuperRanger O/A
Solar mig
Lincoln Powermig 140
Southbend 9in lathe
350# kohlswa anvil
Miller Maxstar 150 stl etc....
Old 01-02-2008, 08:54 AM
Good morning, from the Victor manual type mfa heating nozzles tip size 10 acetylene12-15 psig oxygen 30-40 psig acetylene cubic feet per hour is 30min. 100max. as you can see it would be easy to break the 1/7 rule. personally i use a #6 tip,be safe
Solar mig
Southbend 9in lathe
350# kohlswa anvil
