Old 10-13-2005, 10:03 AM
steve butera steve butera is offline
ideal arc input amps
I am looking at a lincoln idealarc tig 300 and the tag on the back says the input amps required is 117. Am I reading the right tag ? could this be correct?
thanks
steve
BTS Welding
Old 10-13-2005, 01:15 PM
got aluminum got aluminum is offline
Sounds a tad high but I might be wrong. There should be multiple voltages on the tag that will have different currents with each voltage.
Yes I can tack it for you. I know that won't hold but that is what you asked me to do.
Millermatic 350P XR Aluma-Pro push/pull
Millermatic 185/spool gun
Miller Dialarc 250 HF Water cooled
Thermal Dynamics Plasma
Old 10-13-2005, 05:14 PM
klandor klandor is offline
Ideal arc Imput amps.
Steve ,that 117 imput could be right. I know lincolns precision tig 275 requires around 94 imput amps for maximum output.
Old 10-16-2005, 03:40 PM
smithboy smithboy is offline
input amps for AC for the dialarc 250 is about 90ish. Dc is in the 70s range.
Smithboy...
if it ain't broke, you ain't tryin'.
