Lincoln ac/dc 300
I found a used lincoln ac/dc ideal arc for $500. I think it has ability for HF tig welding. Is it worth buying? Can it be run on a 50amp 220v? I am trying to get a tig setup on a budget. Any suggestions? Thanks for any input.
Re: Lincoln ac/dc 300
Make sure it's a single phase machine. It depends on how much output you want. I have run my Shopmaster on a 50a outlet and it was fine. I was running a wire feeder with .035" hard wire. It was not close to max output and it was fine.
"Stick-man is wise" - Farmall "Stick-man is right. Much as it pains me to admit it, the thieving knucklehead." tbone550 "StickyFingers-man" Commander 500D, LN25 Shopmaster 300, Super S-32P Hypertherm Pmax 600 Smith & Oxweld O/P |
You call, but try to find out if it was built with the Power Factor Correction capacitors. If not putting them in will be expensive. Even then, a 100 amp service is ideal for a single phase 300 amp transformer tig. If you get the serial#, your LWS could probably find out if it has PFC.
"Nothing welded, nothing gained." Miller Dynasty700DX, 3 ea. Dynasty350DX, Dynasty200DX, ThermalArc 400 GTSW, MillerMatic350P, MillerMatic200 with spoolgun, MKCobraMig260, Lincoln SP-170T,PlasmaCam/Hypertherm 1250, Hypertherm800 GaryJohnson2016 |
Did they make those in 3 phase 220 volts? If so, that would make for a nice shop tig.
| Thread Tools | |
| Display Modes | |
