Old 04-06-2012, 11:37 AM
Thunderrig15 Thunderrig15 is offline
New 90 Amp Flux wire welder
I am new to the forum and this is my first post...
Just wanted to share my experience with the new welder I bought:
A few days ago I bought the new "black" 90 amp welder for $75... Immediately I noticed differences in this welder from the older "blue" 90 A models. The spool holder is better made, the wire feed mechanism has been enhanced and has a 2 sided feed wheel for either .030" wire or .035" wire. It feeds pretty steady and smooth.
The box says it's a hot tip welder, but it is only hot when the trigger is pulled.
I also noticed the manual says it's AC, but on the welder itself, it states it is a DCEN.
I used Lincoln .035" wire in it, and I was very pleased with how it worked. I would recommend this welder to anyone that wanted to weld as a hobby and just for fun. For the price I couldn't pass it up.
Journeyman Electrician
(2) 135AC/ 105DC Amp Arc Welders
(1) 165A Inverter Arc/TIG Welder with Digital Readout
(1) WP17V Torch for Scratch/Start TIG welding
(1) AR300 Cylinder
Old 04-06-2012, 11:40 AM
Gamble Gamble is online now
Re: New 90 Amp Flux wire welder
Welcome to your new addiction. Post pics of your welds!
Hobart Handler 140 Mig
Longevity 200ex
Htp 221
Old 04-06-2012, 12:30 PM
California California is online now
Welcome!
I wonder if they have sold different welders under that same product number. The first black ones were definitely AC, and I just saw a floor sample that didn't say AC or DCEN on the machine itself. You said the specs painted on the welder include DCEN? If it really is, you got one of the first ones where they finally got it right.
What do you see inside? Do the welding cables come right off the transformer (indicates AC), or is there a rectifier component between the transformer and the cables?
Old 04-06-2012, 01:27 PM
Originally Posted by California View Post
Welcome!
The specs are listed inside the top lid of the welder... I will open it up tonight and give you the details on what I see and maybe post some pics of it. It def works better and a bit smoother than the blue one I owned... or may be I'm improving my skills from when I first started.. ha
(1) AR300 Cylinder
Old 04-06-2012, 03:55 PM
Here are some pics of the unit...the 3rd pic is the specs listed in the owners manual.
The other pics are of the unit itself.
(1) AR300 Cylinder
Old 04-06-2012, 03:58 PM
Thanks! I will try to post some weld pics in the next few days... I know I'll get crucified tho! ha
(1) AR300 Cylinder
Old 04-06-2012, 05:19 PM
Galaxieman's Avatar
Galaxieman Galaxieman is offline
The black cube on the pc board is a 'contactor relay'. That is what makes it 'cold tip', despite what it says on the specifications. The relay is activated with the torch trigger pull ... sending power to the primary of the main welding transformer.
HF 151 Dual Mig Welder (with mods)
Lincoln 225-S AC Welder
Buffalo MM-1 Milling Machine
Craftsman/Atlas 6 inch Metal Lathe
Buffalo RF-115 4 x 6 inch Band-Saw
Old 04-06-2012, 05:28 PM
SDPAULIE SDPAULIE is offline
It is an AC output. I know of someone that had one of those and complained to HF and they replaced it with a better model mig because of false representation =)
Old 04-06-2012, 05:40 PM
Bluewelders Bluewelders is offline
It looks like a cold tip AC welder .
The 170s come with a knurled drive wheel for the .030 wire size.
Does it have a knurled wirefeed wheel ?
Hobart T225
HF 151/2 Cap mod
HF 131/2 Cap mod
Miller Cricket XL
Century Portable Mig
O/A
Old 04-06-2012, 05:41 PM
Then that is big time false representation...as you can see what is on my unit and in the hardcopy manual. Thanks, good to know. I didn't get it at HF tho, but I'm happy with how it performs.
(1) AR300 Cylinder
Old 04-07-2012, 10:49 AM
You lost your recipt duh! doesn't hurt to call tech support
Old 05-29-2012, 05:52 PM
dugndeep's Avatar
dugndeep dugndeep is offline
Yow the new black ones come with a knurled roller,both sides are knurled,one side is for 30 and the other side is for 35.
Maxus Pro-125 Mig
Chicago Electric 90 amp DC flux-core
Lincoln Electric AC 225 tombstone
O/A torch
M/O mini-torch
10 acres of flatland
15 acres of holler
[IMG] code is Off
HTML code is On
