#776
Re: Let's see the welding rigs
Sixstring,
Your cousins truck is clean looking Chevy, nice rig>
#777
Hey Sticky - haven't been on WW too much - too busy! I see my weight guess on Toz's truck was low. More tools in there than I thought! Hope you got what you were looking for since I wasn't able to "help" you....
Applied Fabrications, LLC Ye Olde Ford F-550 TB 302 / XMT 304 / Dialarc HF-P SAM 400 / SA-200 x 2 etc. |
#778
'07 Fowler 200D '65 RedFace '04 Miller TB 302, 22hp Miller 12RC Miller HF 251-1 Lincoln SP135 HyperTherm PM 380 and a few others....... I want a new TIG machine, but which one? |
#779
Here is the start of my new to me welding truck!
Had not been running in 15 years http://youtu.be/zqua2QMrzvg BEFORE I got it ![]() What I have done so far ![]() YAY OR NAY on the stacks?
#780
Yay on the stacks fo-sho!
#781
2nd on the stacks - looks good.
#782
I think they look good too. I have a buddy, he thinks I should have them wider apart so you can see more of the stack out to the side....I am unsure, I think I like them like this, not to blatant like some of the newer diesel trucks.
#783
Well first things first. I think the restoration of the truck should come before wether it gets stacks. I also suspect that the restoration may take a good bit more time than you think (it frequently does). BUT my first impression was NO but perhaps if the the rest of the job is well done you will be able to pull it all together. Ps I've done this kind of resto AND I hope you finish it (many folks don't) it's a good looker.
Miller thunderbolt 250 Decastar 135E Recovering tool-o-holic ESAB OA I have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools. |
#784
Restoration.......lol it will be made mechanically sound,then driven so it can make money, it will be restored at a later time.
#785
Those cabs fit reasonably well over a much later frame, so if you get a 1973-87 C-30 chassis you can (almost) set the cab right on it.
You'd need to u-joint the steering column (we wanted the stock wheel so we did) or come up with a different column. I don't have any pics of the one I did many years ago on a C-10 chassis but it ain't hard. Better drivetrain with better brakes (there's a REASON old time brake shops were often not too far from the bottom of steep grades!) will make it much nicer to drive. You could also transplant the whole subframe from a C-30 and throw a 14-bolt dually axle (they are different from SRW trucks) under the rear. Plenty of cheap donors out there and since you weld it would be a breeze. A '73-79 brake pedal mount is VERY close and will clear the stock dash with some trimming, and that can get you conventional power or Hydro-Boost brakes. Welding rigs are heavy and old-school trucks are pretty but they don't stop very well. |
#786
No on the stacks. Stacks jumped the shark big time.
Vantage 500's LN-25's, VI-400's, cobramatics, Powcon inverters, XMT's, 250 Ton pacific 12' press brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. Lincoln idealarc tig 330A with bernard cooler Sync350LX. Miller migs, marvel saws |
#787
It was meticulously maintained as its a fire truck so it only needs a few basic things. Needs wiring help, tie rods ends and a seat, and a door pin, thats about it, everything else works and great!
#788
No Stacks, especially if they aren't hooked up and just for show.
"Si Vis Pacem Para Bellum" (2)Lincoln 225AC/DC portables, Miller Syncrowave 300, miller sidekick,Lincoln Idealarc 250,Miller 251 Mig, Miller 30A spool gun, Hende lathe, Horizontal bandsaw, pora band ,14FT enclosed trailer.SA200's |
#789
They would be fully functional if installed, just for looks I agree would be more than retarded
#790
I don't know why everyone is saying "no". I think they look awesome how the are. Don't make them farther apart.
Sent from my Kindle Fire using Tapatalk 2 |
#791
That baby is "Side Pipes" era..
![]() ...zap!
![]() I am not completely insane.. Some parts are missing ![]() I have figured out that keeping everyone happy is nearly impossible but pissing people off is easy and fun. |
#792
I second the side pipes.
Miller Pro 300 68 SA 200 64 SAF 300 305 G Lincoln gasser Miller 210 |
#793
Sidepipes are cool but not in Saskatchewan, too much snow. I think the stacks are the titties (.Y.)
I hate being bi-polar it's awsome My Heroes Have Always Been Cowboys |
#794
Zoomies all the way.....
#795
That front licence plate is in awesome shape!
And the plywood plate holder on the back is priceless!
#796
No worries, I will have a shiny new plate for it when I licence it, but then again maybe I will keep it just for you ahahaha. I take it you're from the city and never seen a village of 350 people's firetruck from 1970. |
#797
i up graded tho this
#799
Nice rig. I like the way the decals raise with the body line on the doors.
IW Local 580 NY, NY |
#800
Is that an SAM-400 in the middle?
| Tags |
| mobilewelding, portable welder, rig bed, trailer, welding truck |
| Thread Tools | |
| Display Modes | |
