Old 05-17-2012, 12:31 AM
Mick120's Avatar
Mick120 Mick120 is offline
Large nut insert tool
Anyone here come across a cheap alternative for large nut insert fitting?
I'm fitting some M10 inserts but, my tool, only goes to M8....cost of a new one is bloody silly.
I've got a 5/16" hand rivet tool and, considered making something to modify the thing for nut inserts but, would hate to screw the thing.
Any constructive input appreciated.
CIG 320SP pulse mig
Mitech ACDC315P
Samson 510 CNC plasma table
Hypertherm 85
Etc, etc,etc.
"You don't stop laughing when you get old....You get old when you stop laughing".
www.snapncut.com
Old 05-17-2012, 01:29 PM
acourtjester's Avatar
acourtjester acourtjester is offline
Re: Large nut insert tool
HI Mick
here is a nutsert tool I build for instlling nutserts. If you want more info give me your email and I can send you a pdf file on how I built it with pictures.
have fun
Tom
Old 05-17-2012, 02:03 PM
Coupebuilder Coupebuilder is offline
Jesters setup is pretty nice, however if you need a down and dirty quick setup can be made with two steel 30 degree wedges with a slot milled in them for the bolt. Use a heavy duty clamp to pull them together. As the steel wedges are drawn together they get wider and pull the riv-nut into shape. Think a machinist parallel if that helps. There are also commercial versions of these as well, but not too hard to make one.
"Anybody can talk $h!t behind a monitor, I let the quality of my work speak for itself"
Lincoln Square Wave 255 and 355 Tig
Lincoln 255 Power-Mig w/ spool gun
Koike 5 x 10 CNC plasma
Hyd-Mech DM-10 bandsaw
Ineco QB-76 NC tube bender
Old 05-17-2012, 02:05 PM
Here is a slightly different version of what I described. Also Jester should post those for all to see if he has them, I'm sure others would like to save a few ucks on the tool and that looks like a great setup.
Old 05-17-2012, 06:15 PM
Mick120's Avatar
Great ideas both of em.
I know it's not exactly rocket science to pull an insert but, the price the mongrels want for a tool is outrageous.
I do have an Italian FAR tool that I bought at auction for bugger all but, it only goes to 8mm.
Thanks again guys.
CIG 320SP pulse mig
Mitech ACDC315P
Hypertherm 85
Etc, etc,etc.
www.snapncut.com
Old 05-17-2012, 06:53 PM
irish fixit irish fixit is offline
While it's not 100% fool proof I've run my fair share with nothing more than a standard hex nut or two that's oversize for the thread and a bolt the size that fits the insert.
Just slide the oversize nut over the bolt, thread the insert onto the bolt (preferably with some lube), put in the hole, use a wrench to hold the oversize nut and another wrench to turn the bolt.
Actually a good quality piece of threaded rod works even better than a bolt.
With care it works pretty well. I have had a few get a little cocked when run up and grab onto the bolt but not often.
I do like both of the ideas above as well.
Millermatic 252
XMT 304
Dynasty 200DX
Hypertherm PowerMax 1250
Miller The Legend AEAD200LE
Suitcase 12RC
Suitcase 8VS
Optima Pulser
XR feeder and XR Edge gun
and more at
http://members.dslextreme.com/users/waynecook/index.htm
Old 05-17-2012, 08:28 PM
Mick120's Avatar
Before I saw Tom & Coupe's ideas, when I ordered the inserts (minimum order 100....) I also ordered a cheap alternative to the expensive tool, actually a lot like Toms. (pic attached)
D!ckheads sent me one for M6 threads.....of course, that made a lot of sense considering I ordered M10 inserts.....I sent it back and will copy Toms idea.
Oh yeah, plus the tool they sent isn't a multi fit....No siree....Each one made to fit one size only....cunning mongrels.
CIG 320SP pulse mig
Mitech ACDC315P
Hypertherm 85
Etc, etc,etc.
www.snapncut.com
HTML code is On
