My first welder
Hello there
I'm just starting out in welding and I was thinking about purchasing a "Lincoln Invertec 170s" (with TIG func.) as the first welder. What do you think about this machine? Does this machine allow me to weld aluminum if i need? By the way, what do you say about "Solter" brand compared to "Lincoln"? Thanks for your eventual attention. Greetings From Portugal |
Re: My first welder
Lincoln does not list a 170 on their website, so either its an older model or one that is only available overseas?
I have used both the Invertec V350 Pro and the V205, both of them were very nice machines. If it is AC/DC you can weld aluminum with it. As far as I know, the V205 is the smallest inverter with AC that Lincoln makes here in the U.S. The 155 and 160 are DC only. |
Re: My first welder
"From Portugal"
![]() It sounds like a small machine, but it should be very efficient. My transformer tig machine is rated at 165 amps, and is ok for small projects. ![]() I am unfamiliar with Solter Brand.
City of L.A. Structural; Manual & Semi-Automatic; "Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore." Job 28:1,2 Lincoln, Miller, Victor & NKJV Bible Danny
Re: My first welder
From Google it looks like that outfit is in Spain....
Drink a Guinness Draught.... Millermatic 140 Do you still remember December's foggy freeze -- when the ice that clings on to your beard is screaming agony. |
Re: My first welder
"The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt |
Re: My first welder
Thanks everyone for the answers.
Yes, the Solter brand is Spanish but here in Portugal they says it is a very good brand. Sandy shared the link of the exactly machine im talking. Quote:
One more time, thank you all. Last edited by caxuda; 05-20-2012 at 08:43 AM. |
Re: My first welder
You need AC to tig weld aluminum.
Lincoln makes a lot of DC only machines. Make sure the model you are looking at has AC/DC at the end of the model name. |
Re: My first welder
Lincoln did make a V300 but not anymore, that is one of the machines I learned on. I don't know if they used to make a 270, if so, it would probably be a fairly old machine.
Re: My first welder
I thought TIG without AC allowed to weld aluminum. I read it on THIS website Quote:
Greetings |
Re: My first welder
I find the word "overkill" to be "under rated." Conversely, "under powered" is a word I'd rather never need.
"Steel is weak. What is steel compared to the hand that wields it?"- James Earl Jones miller 225 w/ 3035spoolmate, Lincoln sq wv 275 w/radiator, hypertherm 600 plasma cutter, other stuff Last edited by badknot; 05-27-2012 at 10:17 PM. |
Re: My first welder
the thickest aluminum 170amps will do is 3/16, tops.
Re: My first welder
Hello
![]() ok i understand, thanks Sorry, but what does "3/16" means? Is the electrode diameter? If i can weld aluminium with 3/16 diameter electrode this machine is excelent for me, at least that's what I think now . Geetings Last edited by caxuda; 05-29-2012 at 06:12 PM. |
Re: My first welder
"They"..... also told us that Opel and Yugo was a "good brand."
Lincoln Power Mig 216 & 140C Lincoln AC/DC-225/125 Miller 625 X-Treme Plasma Miller 211 Milwaukee Hilti Dayton Delta Makita Victor Ingersoll-Rand Baileigh |
Re: My first welder
Greetings |
Re: My first welder
caxuda,
You will not be able to weld aluminum using the TIG process with the 170s. and for all practical purposes you will not be able to weld aluminum using the Stick process either on the 170s http://weldingweb.com/showthread.php?t=32124
Ed Conley http://www.screamingbroccoli.net/ MM252 MM211 Passport Plus & Spool gun TA 185 Lincoln SP135 Plus- (Gone to a good home) Miller 125c Plasma 120v O/A set SO 2020 bender Beer in the fridge |
Re: My first welder
Re: My first welder
Hello there
I decided to forget the aluminum, because the machines AC / DC or MIG are much more expensive. I think i'll buy the lincoln 170s, we'll see. Ok, ![]() I will give you news as soon as possible. One more time, thanks all for the help. Greetings |
Re: My first welder
Hi again my friends
I have good news. I've bought my first welding machine, it's a solter ICON-1970 PRO CEL, HERE's the link. Came a good deal and I did not refuse. This weekend I was in my farm, in a different and a bit far city, and I started my first welding project. I decided to do a basketball board (4ft x 3ft). Take this opportunity to say I did a pretty **** welding, I do not care, machine's fault. ![]() Greetings ![]() edit: I'm soooooooo stupid................ I was reading things on the internet about welding and I found the torch was attached to the wrong pole (positive)..... Did this brings any problem for the machine, or does it had any welding influence? Greetings Last edited by caxuda; 06-17-2012 at 07:17 PM. |
#19
It won't hurt the machine. In fact the leads are switched depending on if u do flux core or gas shielded (mig)
Sent from my SPH-D700 using Tapatalk 2
Airco 330A/BP. Lincoln SP250 W/ spoolgun, GoWeld x2 TA Predator, ESAB 300AVS Feeder ESAB 875 plasma. . Bernard Cooler. Evo 355. OA Demo: Longevity Tigweld 200SX, Forcecut 42i Everlast 140ST.. On loan to friend/sale pending |
#20
Re: My first welder
Oh thank god... Im just doing normal, flux core, right? How do i have to connect? I've been using 2.5mm but i think they are too thin. What electrodes should i buy for my project? By the way what is the maximum size that this machine (180 amps) can handle? Thanks for the fast answer. |
#21
Re: My first welder
Sorry to be pulling up the topic.
Been a while, in 2 days I go to my farm, so I would really like to have answers. Thank you for your possible availability. Greetings |
#22
Re: My first welder
should say in the manual which i'm sure is available from dealer or online. we are talking about a wire feed machine here, right? the wire is the electrode. the "tip" is the part at the end of the gun and should be matched to wire size: .023, .030, .035, .045. it's been a long time since i've used flux core, it makes for ugly welds, but probably well suited for repairing rusty farm equipment on the fly. just be sure to chip as much of that slag off the weld when ur done, it's corrosive. with ur machine, I think probably .035 flux core should allow u to weld up to 1/4" steel maybe more w/ technique?
"Steel is weak. What is steel compared to the hand that wields it?"- James Earl Jones miller 225 w/ 3035spoolmate, Lincoln sq wv 275 w/radiator, hypertherm 600 plasma cutter, other stuff Last edited by badknot; 06-25-2012 at 09:03 PM. |
#23
Re: My first welder
although i couldn't quickly locate them, there's some good instructional articles and videos on this site as well as others.
http://www.millerwelds.com/resources...tips/MIG_tips/ good luck!
"Steel is weak. What is steel compared to the hand that wields it?"- James Earl Jones miller 225 w/ 3035spoolmate, Lincoln sq wv 275 w/radiator, hypertherm 600 plasma cutter, other stuff |
#24
Re: My first welder
Thank you very much
My manual does not say much thing cause my machine is off their professional line of inverters. Other lines has a manual more user friendly. I'll study that. Thanks again Sent from my HTC DESIRE using Tapatalk 2 |
#25
Re: My first welder
Guys the link he put up is to a stick machine not a wire feed from what I can tell.
. No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan |
| Thread Tools | |
| Display Modes | |
