#26
Re: StickWeld 140 AMP Stick Welder IGBT Technology Dual Voltage 110v/220v
There is a 5 year parts and labor warranty on all of our units, if you need any additional information or details on this unit please be sure to give us a call at our toll free number (877)566-4462 to speak with one of our technicians, thank you for your time and have a wonderful day.
Best, DP
LONGEVITY Welding www.longevity-inc.com Phone: 877-566-4462 LONGEVITY is Hiring! All Positions. Send resume to: jobs@longevity-inc.com |
#27
Just checked the word doc for this unit, there is a typo.
Someone needs to change the polarity layout for the electrode.
Semper Fi Jesus may have been a Carpenter, but his dad was a Millwright " A grinder and a can of paint, will make a welder what he aint' " I've done so much, with so little, for so long, that now I can do anything with nothing! Last edited by skelley521; 09-25-2011 at 11:43 AM. |
#28
Thanks for catching the error skelley. We will change and correct the manual on Monday. Our manuals will be revisited shortly as the new website launches.
This change should be made Monday. Thanks Simon
#29
Is this the same as the everlast 140ST minus the lift arc function? It has identical insides to the everlast unit which I just reviewed. If so, its a nice little machine but needs larger diameter cables and better ground clamp.
Airco 330A/BP. Lincoln SP250 W/ spoolgun, GoWeld x2 TA Predator, ESAB 300AVS Feeder ESAB 875 plasma. . Bernard Cooler. Evo 355. OA Demo: Longevity Tigweld 200SX, Forcecut 42i Everlast 140ST.. On loan to friend/sale pending |
#30
It is not the exact same but there are some similarities between the two units.
Best, DP
#31
Made in the same factory??
#32
Yes, it is made at the same factory. We originally came out with it several months prior, but they also had ordered the same model with the addition of the tig capability.
Now, our units will also be tig capable. We also got some other models coming similar to theirs and some newer models that no one has yet to see. I would like for you to test the stickweld 250 when it arrives. Thanks, Simon
#33
On a side note, Lincoln claims the V205T runs 6010 rod but unless you are running in the top of the amp range of the rod the arc breaks and goes out very easily... Not very impressive for $4000 Lincoln.
#34
I think you will be pleasantly impressed with our StickWeld 250 - this model has been tested by our team, our distributors in Latin American countries, and our team in Canada. All have been very impressed thus far. It will definitely run a 6010 rod smoothly! We sold out of these models quickly and the new orders should arrive shortly. Once they do, the testing will be yours and we will cover all shipping costs for testing. Thank you for the opportunity! Simon
#35
I was wondering, any idea when the tig capable version of this welder might be available?
Also, if it is tig capable, would it come with a tig torch like the everlast 140st? I have been thinking about getting the everlast but if longevity is also coming out with something similiar I would like to keep my options open until I know some more about it. |
#36
#37
Why couldn't you tig with the current model? What's different?
Lincoln Handy mig Longevity Stickweld140 Hobart Handler 210 |
#38
sure you can TIG with it doing scratch start. Lift Arc just means you don't have to sratch start. just lightly touch and lift the torch to start welding and it will ramp up the power itself. Seems like the Everlast is a better deal right now, same price and you get TIG setup and torch included...
#39
Hello Everyone, I have just received my Stick-weld 140 ! 2 questions, 1st what length are the stinger and ground cords suppose to be ? And does it normally come with a plug for AC ?
#40
The stickweld 140 leads are short to save on cost. I believe the current length is 3ft each cable. You can purchase longer leads if you wish to do so.
In the future, we will offer longer leads as well, but I am not sure if the price will remain at $229.99
#41
What is the max thickness on the 110v for steel and max in 220v steel. Also will it run fine on a honda generator 8750 running watts. Thanks i am looking for a more portable unit for on the job site.
Thanks Aaron, |
#42
At 110v, you are running about 100amps. The unit has an auto switch inside depending on how it is wired. The maximum thickness on 220v is 3/16", and on 110v you can do about 1/8" - these machines serve a good purpose and fit well in tight places. The generator you have is plenty of power.
LONGEVITY Welding www.longevity-inc.com Phone: 877-566-4462 LONGEVITY is Hiring! All Positions. Send resume to: jobs@longevity-inc.com Last edited by longevity-inc.com; 01-05-2012 at 07:20 PM. |
#43
I was considering ordering a Stickweld 140 for some very light duty/portable applications. However I noticed the photo images of the machine on the Longevity website do not match those in the manual nor any of the demonstration videos on You Tube. Have the specs on this machine been changed?
#44
They have been changed externally. Also, the model is now operating at 60% duty cycle instead of 35%.
It also works better on 110v than the competitors and our previous model. Comes with a power cord adapter to switch between 110v and 220v.
#45
Does this welder come with a carying case? I've seen some people say yes, and others say no.
#46
Hi Adam,
This one currently does not come with a case. We do have them available if you wish to purchase one separately. I believe they are around $40 per case.
Cheers ![]() Phone: 877-566-4462 x 201 Email: simon@longevity-inc.com Web: www.longevity-inc.com Email for any questions about LONGEVITY! |
#47
using 1/8 inch electrodes this machine can do unlimited thickness with multi pass welds on 220v
using 3/32 on 110v
Miller Syncrowave 250 TigWeld 250 PowerArc 140 ST Smith Gas Mixer AR/H LA City Certified Structural WeldingTradesman (Demo/Testing) Longevity ProMts 200 with spool gun Forcecut 42i Tig is my Kung Fu Laying down dimes and weaving about |
| Tags |
| 110v stick welder, longevity, longevity stick welder, stick welder, stick welding |
| Thread Tools | |
| Display Modes | |
