Old 07-02-2012, 09:08 PM
pushrods pushrods is offline
cutting stainless for exhaust
I'm curious what everyone here would suggest for cutting 304 stainless 16g 3" tubing. I've got a tiny 1.5 car garage that doesn't have much room for a. Stationary bandsaw, so I've been eyeballing an Evolution 14" Rage 2. Chop saw for the occasional stainless exhaust work on my friends cars or my truck and turbo build. The main use will be for chopping exhaust tube and maybe some mild sch 40 peices for a turbo maifold.
Hobart Handler 187,
Craftsman drill press,
Smith torch setup,
Htp invertig221,
Milwakee portaband saw w/Swagoffroad V3.0 table kit
Old 07-03-2012, 02:10 AM
rabidchimp rabidchimp is offline
Re: cutting stainless for exhaust
I've heard those saws don't do too well on the stainless, but I've cut plenty of similarly sized material on a regular chop saw, $179 will get you a nice Ridgid 14" saw.
-Aaron
Hardinge HC Chucker Lathe --- Jet 17.5" Drill Press
Lincoln 175 MIG, 175 Square Wave TIG, Power Mig 256
Dewalt 14" Chop Saw - Victor O/A Setup
Jet 7x12 Horizontal ---- Jet 17" Vertical
https://www.facebook.com/#!/RabidChimpPerformance
Old 07-03-2012, 02:58 AM
DougAustinTX's Avatar
DougAustinTX DougAustinTX is offline
Agreed on the chop saw. I just finished a 4" stainless dual exhaust on a '69 Camaro and all cuts were made on the chop saw. Then outside edges were trued and deburred on a stationary belt sander, while inside edges were deburred with a carbide burr. I mig a few spot welds in place while under the car to get the angles right, then remove to tig.
Miller Syncrowave 350
Millermatic 252/ 30A spoolgun
Miller Bobcat 225g w/ 3545 spoolgun
Lincoln PowerArc4000
Lincoln 175 Mig
Lincoln 135 Mig
Everlast 250EX Tig
Century ac/dc 230 amp stick
Victor O/A
Hypertherm 1000 plasma
Old 07-03-2012, 10:38 AM
Albie Albie is offline
Got a Rage 2 last year. Cuts square tube 2"x1/4 and same same angle great. Still using the supplied blade, which is kind of a universal. Have to get a better blade for steel and a blade for stainless. Needs a dedicated blade for certain materials. To me, it is way better than a abrasive type saw. Opinions will differ.
Old 07-03-2012, 12:18 PM
Donoharm's Avatar
Donoharm Donoharm is online now
angle grinder + cutting disc 1mm + wraparound
www.inoxworks.eu
Old 07-03-2012, 12:36 PM
fortyonethirty fortyonethirty is offline
Abrasive is the way to cut thin stainless. Stainless will dull the carbide blades very quickly. And on the thin stuff the carbide blades tend to "grab" the material and deform it or fling it across the shop.
A disc sander works well for squaring the cut ends, belt sander also works well, but I prefer the disc.
Ian Tanner
Kawasaki KX450f and many other fine tools
Old 07-03-2012, 01:58 PM
Jürgen's Avatar
Jürgen Jürgen is offline
I have a Makita LC1230 dry cut saw with a blade for stainless. The blade is about $200.
Not a cheap solution, but the cuts are perfect with no sparks.
Old 07-03-2012, 07:07 PM
I've read some reviews on the Evolutions chop and you can get them for 309 shipped online with a multi metal blade. Some of the automotive fab guys on Honda-tech use them in their shops and have nothing but positive things to say about them. I've also been keeping an eye on craigslist for a used ridged or Millwakee chop saw and just picking up a 14" blade for stainless. I've used chop saws at work for cutting metal studs and they worked fine, I just disliked changing the abrasive blades.
I've built a 2.5 to 3" stainless y pipe and full exhaust for the stainless headers on my 95 Dakota sport using just a cut off wheel and a hacksaw and it sucks. Then I still need to fab a downpipe for my turbo ecotec project and my buddy's turbo cavalier build as well and I'm not going to spend forever hacking away and swapping blades every 2-5 cuts.
Hobart Handler 187,
Smith torch setup,
Htp invertig221,
Old 07-06-2012, 11:49 PM
Well I just picked up a milwakee porta band deep cut for 150 so this will hold me over till I get a chop saw.
Hobart Handler 187,
Smith torch setup,
Htp invertig221,
Old 07-07-2012, 10:45 AM
VPT's Avatar
VPT VPT is offline
I was just going to post to look for a portable band saw. They aren't as versatile as say a sawzal but they do a great job!
Old 07-07-2012, 11:00 AM
Showdog75 Showdog75 is offline
Now buy yourself the fixture that swag offroad sells for a port a band and you will have yourself a nice set-up.
Old 07-07-2012, 07:47 PM
Thanks for the input on the fixture I'll look into that.
Hobart Handler 187,
Smith torch setup,
Htp invertig221,
Old 07-07-2012, 10:17 PM
Showdog- that is one cool add on for the portaband......I'm going to order one shortly. Thanks again for the tip.
Hobart Handler 187,
Smith torch setup,
Htp invertig221,
Old 07-07-2012, 11:01 PM
walker walker is offline
I bought one of the Evolution hand held metal cutting saws. I won't buy another Evolution product. I also agree with either the zip wheels or abrasive for what you are doing.
Old 07-12-2012, 12:02 AM
Thanks fo the input guys, I'll use my 4 /2 cutoff wheels and my porablt milwakee band saw. I just placed an order for v3.0 poraband table and can't wait for it to arrive.
Hobart Handler 187,
Smith torch setup,
Htp invertig221,
Old 07-12-2012, 07:09 AM
OffshoreNDT OffshoreNDT is offline
thanks for the recomendation to swag offroad awesome stuff on there
Old 07-17-2012, 10:13 AM
Just n update, my swag offroad v3.0 table came in on Saturday and it kicks some ***. I love how easy this simple add on made things for me in the garage. I took some 16g 3" 304 stainless tube and made a tight radius 90degree bend for my turbo cavalier build after work tonight. Went very well andhere are some pics.
Hobart Handler 187,
Smith torch setup,
Htp invertig221,
Old 07-17-2012, 12:53 PM
Nice work there. I never liked cutting tube on a vertical band saw. I need to get a metal cutting blade for my vertical Jet. Its a big bastard I got for super cheap when a local wrecking yard went outta business. They used it for cutting down radiators.
-Aaron
Old 07-19-2012, 09:43 PM
VPT's Avatar
VPT VPT is offline
Sorry for the small pic but there is also this attachment for the band saw essentially turning it into a horizontal band saw. Also a very nice deal and great for a small shop. Helps 100% to make pipe cuts like you want to do.
Old 07-19-2012, 09:44 PM
VPT's Avatar
VPT VPT is offline
In fact now that you have the tools you could probably make that attachment.
Old 07-23-2012, 01:44 AM
VPT I did see that pic and actually the bandsaw case has a small booklet with parts and whatnot and that is listed in there but way to pricey for me. The Swag table fits the bill perfectly for now.
Hobart Handler 187,
Smith torch setup,
Htp invertig221,
Tags
chop saw, evolution, rage2
HTML code is On
